Official NEW Project *Work Hard, Play Hard* FOR SALE!
Started by Shamb, November 29, 2008, 07:05:19 PM
What spring setup would you run?
4" marlins in the rear 3" TG in front
4" Marlins in the rear 3" Alcan in the front
63" Chevys rear RUF in the front
Other specify below
Bacon!
MiniSimp
If you need me to hang on to those spare axles in the back of your truck for you I will. :gap:
Shamb
Quote from: MiniSimp on August 25, 2011, 07:23:54 AM
Those will be going in SOON  ;)
Shamb
 So i've got two sets of springs in primer right now... I planned on using the rear springs that where on the 4runner because I thought they were stock but i'm pretty sure they're an aftermarket spring. Much thicker than a stock rear. I'll post pictures tomorrow... I started tearing down the rear axle as well, getting it prep'd and painted.
Cleaned up and primed all the front end parts for the post part today.
I'm trying to locate some replacement parts for the springs like the clamps that hold the ends of the springs in place. I had to cut the one's that were on there off because they were all rusted up and would have been way to short for a 6 leaf pack. Center pin i'll just use a grade 8 bolt.....  also there's the clip in plastic pads at the end of each spring.. i'd like to replace those as well if anyone know's where I can find 'em that would be great.
I'll try and get a few pictures up tomorrow of the progress.
John Doe
For the centering pin, make sure to get a "socket Head" bolt. As for as the Teflon pads at the end of each spring, Trail gear is the only source I know of. Might as well replace the bushings while your at it.
Shamb
yea I plan on replacing the bushing as well, do you know where I can get the clamps?
it's a pinned clamp that's on the third leaf that wraps around the upper two leafs. I need one that'll fit atleast a 6 leaf pack.
I have to drill the old one out.....
i'll call trail gear or maybe alcan tomorrow and see if they can help me.
Shamb
Busy work week, haven't had much time to work on the rig like I had hoped.
I have a 5 day weekend starting tomorow to look forward too, hopeing to get the front end back under the truck and finished. I'm going to start assembling the axle tomorrow.
I'd post some progress pictures but photbucket is being lame as usual.
Fo-runna
Have you thought about shaving your drainplugs?
kdub0013
Quote from: Shamb on August 31, 2011, 07:17:09 PM
When I get back from Fordyce I will try and come by if you are around and look at the runner.
Shamb
Fo-runna, yea I think i'm just gonna get Marlin's low pro plugs.. i've never really had an issue w/ that like alot of other people *knock on wood*
I don't want to put ALOT of time and effort into these axles because I have plan's on going diamonds eventually. One of the reason's i'm not shaving 'em either.
I'll be around kdub, stop on by and have a cold one.
MiniSimp
Shamb
today didn't go well... we'll just say that...
anyone know if I can purchase these seperate or if i've gotta get the entire KIT to get one of these?!
for some reason while putting on the passenger side outer spindle seal it started bending..... now it's all F'd.....
Shamb
I found a full FSM online.
http://www.functionalfab.com/resources/toyota%204runner.pdf
Today's objective :
1. Finish rebuilding axle
2. Go to PnP to get some stock rears and 63" chevys
3. Remove shock towers, stock spring hanger and springs from the front.
MiniSimp
Quote from: Shamb on September 01, 2011, 07:19:55 PM
Not sure how that happened, but that sucks! You might be able to find somebody that has one, other than that, kit. Maybe dealer?
Shamb
yea when i called around today, everyone said dealer which means cha-ching $$     i'm just gonna run it and see how it goes...
Axles complete ready to go and my garage got a much needed clean up. Suck's that tomorrow's Saturday.. I wanted to hit pick n pull for some springs...
Tomorrow we've got ppl coming over for a BBQ so I don't think i'll get much done. I'll probably clean/paint the lock outs on the hubs and maybe start cutting the shock towers off the front along with pulling the front springs
Fo-runna
I've got a bunch of that stuff. Unfortunately I'm still in my sleeping bag at the bottom of winch hill 1 right now. I'm not sure if I'm coming out today or tomorrow yet. I'll let you know and get the parts to you ASAP.
Shamb
I just put it all together and i'm gonna run it, see how it goes. Wish I was up there right now!
Kinda stuck right now because I need to get another set of stock rears and 63's, nothings open for the next two days..... so I don't have alot to do..
I'll probably cut the shock towers off today and the front spring hanger.
Shamb
not much progress, how ever this axle is finished. few pictures.... hope to get springs this weekend and order rims   :crossed:
I do plan on painting the lock outs red.
kdub0013
I dude I just checked out that 1-ton you built, fawkin sweet dude! So you around this week? I will cruise by and check the progress. Fordyce was awesome as always and at least my driver side door is still straight, everything else is roached :driving:
Shamb
yea hit me up, I work today and tomrorow but i'll be home Thursday,Friday and Saturday... suppose to go pick up a winch on Saturday.
Shamb
picked up another stock set of rears today, couldn't find any 4 leaf 63's. i'll have them tore down and primed by tomorrow. maybe go swing by scrap and steel to pick up some 3/4" flat bar and some counter sunk screws/bolts from fastenal to start assembling everything.
I still gotta pull off the driver side shock mount and cut the stock spring hanger off.
Ordering new rim's this week, was hoping to score some used 15x8's but i'm not having any luck so i'll probably just order 'em off 4wheelparts.
Also was going to be heading to Sacramento to pick up a winch but that fell through, hope to pick it up the following weekend.
Shamb
 set of stock rears got tore down and cleaned up today, also got the stock shock towers cut off. I still need to order rims, having a hard time finding 63" Chevy springs. If anyone see's a pair of 4x4 4 leaf 63's let me know.
Shamb
just ordered my rim's, was hoping to get some used but got tired of waiting...
got a set of pro comp series 98 rock crawler wheels, 15x8 w/ 2.5" BS
kdub0013
Quote from: Shamb on September 10, 2011, 08:45:15 AM
That's what I have, well soft 8's they are all the same
Shamb
 :maddest:  f*$king 4wheelparts calls my wife today. She doesn't answer because she's home sick... they immediatly call back again so she answers and they ask if i'm there. She tell's them "no" so they hang up. Immediatly call back again, by then she's pissed and tell's them AGAIN "I already told you he's not here quit calling!"  .. dude on the phone apologizes and tell's her to have me call them because they apparently don't stock the wheels that I ordered and they have to make them?!  (WTF?!)   they told her it will take 4 to 6 weeks.... I called as soon as I got home and left a message with the dude... we'll see what he has to say hopefully tomorrow.
If they can't get them here any sooner i'll probably order the wheel's from someone else.
I've been trying to make it over to the local scrap n steel to get everything I need to finish my springs but work blows right now.. I can't get even a second to do anything.
Dingman.
I know if you try to order 2.5" bs wheels from schwab or america tire company they say that they are custom wheels that have to be made and take 4-6 weeks
Shamb
yea... kinda lame they don't have a set or two premade. not enough people purchase them i suppose?
oh well, meeting up w/ bigarm's on Thursday to pick up a spare. also getting a hi-lift from Blingn hopefully sometime this week...
tomorrow's another day, hope to get some material to finish these damn springs.
John Doe
MiniSimp
Shamb
Quote from: MiniSimp on September 13, 2011, 01:30:12 PM
In case of emergency - http://www.stocktonwheel.com/
I bet they're pretty expensive...
So although I didn't get much work done on the rig today it was still pretty productive. Cruised over to Yuba to pick up the steel I needed to finish the front springs, got all my grade 8 bolts for the front springs. Shot up to Grass Valley and meet up with bigarms to pick up a soare 37" MTR. On my way home I stopped by O'Reilly to get new hardware for my calipers. Heard from kdub that a local "pick n pull" had some 63's so I swung by and picked up a set.
Wanted to setup my RUF tomorrow and continue cutting off stuff I didn't need but the wife wants to go fishing because it's suppose to be around 80* tomorrow... and Saturday i'm BBQ'n for my work..... so we'll see how it goes.
Getting real anxious to start slapping on all these new parts and getting the 4runner rolling again.
Shamb
Let see if this works.... not much work on the rig yesterday. Went up to Little Grass Valley and caught some rainbow trout.
http://www.facebook.com/media/set/?set=a.209657415765190.53679.100001628008683
