Official NEW Project *Work Hard, Play Hard* FOR SALE!
Started by Shamb, November 29, 2008, 07:05:19 PM
What spring setup would you run?
4" marlins in the rear 3" TG in front
4" Marlins in the rear 3" Alcan in the front
63" Chevys rear RUF in the front
Other specify below
Bacon!
Shamb
I got some more parts ordered and on their way.
thanks nsmick16 for hooking it up with some extended steel braided brake lines and a front bumper.
I'll try and post some progress pic's tomorrrow, been sick w/ a sinus infection since Friday so I haven't been out of the house much.
Shamb
 Went and picked up some tools/parts today. I've got a set of doors that i'll be turning into half doors. If anyone needs any of the interior parts/glass for the doors PM me because I won't need it. Got a bench grinder, drill press, some 100 watt lights to mount on the front bumper and a ton of random tools.
Planning on cleaning up/painting the sliders and rear bumper that I pulled off today along with cleaning up the frame on the truck.
Shamb
replaced the battery terminals and power wire going to main fuse box today along with scoring a free jerry can holder, gotta jerry can just gotta clean it up.
I took the holder down to bare metal and hit it with some flat black primer.
Shamb
scored u bolt flip kit yesterday, all i need for the front is the rebuild kit and springs to start pulling it apart.
Shamb
I need some persuasion, I want the truck as low as I can get it without removing too much of the fenders/cab. It needs to flex well offroad but also have good/decent road manners.
What kind of spring setup would you run?  pro's/con's of each would be appreciated.
*** YELLER ***
not wanting to jack yer thread but 63's and RUF
and here it sits on the trailer with very lil lift
except BACON
Shamb
how's the road manners on those setup's?
I recall the 63's being really bumpy on my 82', id imagine the added weight on the 4runner will help...
*** YELLER ***
well as of right now I need to add 1 more leaf to the rear when we did MINI's we used 4 springs and an overload but for some reason we only used 3 and an overload on mine great for trail sux on road
except BACON
*** YELLER ***
Quote from: Shamb on July 04, 2011, 02:04:27 PM
is that a new or old school one cause I have a new style one and it ripped on the side ... keep an :eye:: on it
except BACON
Shamb
pretty sure it's old school, it's been sitting for close to 8-10 years probably.
86bobbedtoy
Wermz84
Just read the entire thread. Looking good, don't know how I missed it before now.  now i'm caught up.  :D
I'm curious, with 3" front springs, what length shock will you be running?
Edit: i'm the only one who voted 3" Alcans up front.  lol.
I like to Drive!
Shamb
 On Marlincrawler.com (and i'm sure alot of other places like PBB)  It tell's you the collapsed and fully extended length of the Bilstein shocks so once I get the springs under the truck i'll measure the distance between the top of the axle housing and roughly where the top of the shock hoop will be, that'll give me a rough idea as to what size i'll need. With a small lift i'd imagine they'll be 12's.. maybe 14's if I wanted to mount the top of the hoops up into the engine bay. i'll figure all that out after the new springs get mounted (one of the reason's the polls up)  so i can figure out which direction i'm going.
my main objective is to keep it as low as possible without major modifications and also keep the onroad/offroad ride as comfortable as possible.
Wermz84
Cool thanks.  Since I haven't lifted one yet, I have a ton of new questions now that I'm getting parts for my lift.  I'm trying to keep mine low as well, yet some flex on the rocks.  I also plan on the Bilsteins.
I like to Drive!
*** YELLER ***
For What Its Worth  I have 12"s in front and 14's rear Billstein 5150's
except BACON
John Doe
Well I voted Bacon :D  After all we already discussed what I have. I do think you can save a little $ by running RUF and fords or chevys. I would run fords so they dont hang out the back end to much though.
Yeller, what was your frame height?
*** YELLER ***
Quote from: John Doe on July 07, 2011, 03:37:51 PM
not sure I have rocks in my head and in my driveway so Its hard to say,  but I can check if ya want
except BACON
Shamb
Might be taking the 4runner into my buddies shop this coming up week to pull the front end apart. I could do everything from my garage but he's got alot more accessable tools.
Bought a fire extinguisher today, nothing big... still awaiting parts in the mail.
topar
Shamb
brain storming, instead of the typical square tube front hanger.. this is what i'm thinking.. cut off the stock mounts and run a piece of 1/2" across the bottom and down where the bolts will go through from the springs, gusset. Ta-Da!
It'll keep the front lift down. Input?
btw get used to my crappy pictures, i don't put much effort into them. just get the point across   :greengrin:
John Doe
It would defiantly keep the lift down. I have no clue about the strength though. If you did do that what I would suggest, get a hold of a press break and bend 90's at the red circles. For the inner parts of each spring hanger use separately bent 90's welded to the 1st piece then gusset the inner corner.
After all that get a piece of say 1/4" and make your own http://www.addictedoffroad.com/images/Products/FrameRefKit.jpg that ties into your new hanger.
May seem like alot of work and I may be over thinking it but I would rather it be to strong then not strong enough.
Shamb
in the first picture, the red circles your saying just make that all one piece, start with a longer piece of flat bar and bend 90's so it's all one piece no welds then just weld/gusset the inner mount?
that would work.. much stronger as well... i would enclose everything I could just for strength, i like to over do things most of the time.
John Doe
Correct. I drew another fancy pic to better show it, this time with more color.
3 pieces of steel
-1 long with 2 90 degree bends (the black piece)
-2 short pieces each with a 90 making an L (blue) which would be welded to the 1st and be the inside portion of the spring hanger supporting the bolt and leaf springs.
That would make for a strong front hanger with no extra lift from stock height.
In my previous post I linked a product from addicted offroad. I highly recommend it. It reenforces your front bumper mounts. My 1st trip out with my new bumper and winch I had to get pulled up a last section of a trail and turn around and do the same for a buddy. Well from those 2 pulls my stock bumper mounts were already tearing at the welds.
silence007
I have 2nd gen rear mains on my all pro 5in in the front and F 150 with 1 in blocks in the back, it is absolutely great on and off road, I can flex real good and it handles like a civic on the road.  Doesnt' feel like my truck is going to fall over.
A FRIEND WILL TELL YOU HE WILL BAIL YOU OUT OF JAIL, A TRUE FRIEND WILL BE SITTING NEXT TO LAUGHING WHEN IT DOESN\'T HAPPEN.
Jordan7118
If you have the skills and desire, I'd cut out the crossmember with the current spring perches and weld in a standard square tube spring hanger.
http://www.datinfab.com/toyotafrontspringhanger.aspx
Or, make your own custom hanger.
http://www.datinfab.com/frontspringhangerpockets.aspx
Problem may be where the body mounts tie in at the core support.
Shamb
Quote from: Jordan7118 on July 09, 2011, 09:49:02 AM
Thanks for the links, I like how they mounted the brackets flush w/ the square tubing. I've contemplated cutting it out and replacing it w/ something similar but my big concern was the body mounts... dunno if I really want to go that far or not. I've never messed with any of that....
Jordan7118
I looked at doing that when I swap to full-widths. The body mounts would need to be addressed, and that's as far as I got  :-\
*** YELLER ***
measured in my driveway on the rocks and it looks like about 23"-24" somewhere in there given the rocks and all :dunno:
except BACON
46&2
Little late here but I run the 63s and stock waggy springs and I love it. My runner sits almost identical to Yellers. Road manners are great, rides like a Caddy. :gap:
