0 Members and 6 Guests are viewing this topic.
I had originally planned on just using my 3 leaf stock rears and sandwiching them together with the 3 top leafs on the 87' pack.
How many leafs did you end up with total? you running a 5 leaf pack? because you've only got 3 on a stock rear to work with.
rear shackle through the framehttp://board.marlincrawler.com/index.php?action=dlattach;topic=8233.0;attach=105872;image
how did you determine where to put the holes? i'd imagine i'm going to have to tac/cut the shackle mounts a couple times to get the correct shackle angle.
took me an hour searching thru his thread but it all starts herehttp://board.marlincrawler.com/index.php?topic=8233.1740
Yes, each of my leaves is 6" shorter in overall length than the leaf above it. (3" each side)1 - 48"2 - 48" (wrapped leaf)3 - 42"4 - 36"5 - 30"Those are estimates, but should be pretty close to reality.
Didn't see the photo of your bloody knee in there...
I'm taking this from Minisimp's build, might do mine the same way. I'm not gonna cut anything first and adjust as needed. Chris i'm always around Thursday,Friday and Saturdays. Hit me up! Btw do you know the guy out in Wheatland that has a primer/sanded 4Runner? other than needing a paint job the 4runner's sick..i'm trying to get ahold of the guy so I can ask him some ?'s about his suspension setup.
Started by hacksaw Rigs For Sale
Started by thebeast8888 Project Research and Build-Ups
Started by mlatrella Toyota Pickup/4Runner Tech 1979-95
Started by YLWZX3 Rig Gallery
Started by AV8R TRANSPORT New Member Check-In!
