MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
0 Members and 26 Guests are viewing this topic.
MiniSimp
 :yesnod: Now I need to buy a 60" highlift cause the 48" gets maxed out! :cool:
That is wicked looking, maybe you could limit the piviot by putting a small bumpstop on the outside edge of the platform. You could bolt it to the outboard ubolt nuts.
MiniSimp
Quote from: Rocksurfer on January 22, 2006, 10:25:13 PM
That is wicked looking, maybe you could limit the piviot by....
I'd rather move the tire out than limit the pivot, If it wants to flex that much i'll let it, just need to change something. :greengrin:
Quote from: MiniSimp on January 22, 2006, 10:29:11 PM
I now have had a vision, one of these days someone is going to have a truck with so much flex that when it rolls on its side all 4 wheels will still be on the ground.
:gap:
*** YELLER ***
except BACON
blackdiamond
Just think, if one were to use the piviot lift block, Jonny Joint pivot shackle mount & some AOR Orbit Eye Springs a kick stand might be required  :smack:
CTENG in KS
Well sheeooot Simp, who even needs springs.  You've turned her into a rocking horse! :biggthumpup:
Willy Mammoth
From what I can see you are going to have some side to side play in the rear. You could go back to a standard shackle or use a panard bar to keep the rear from moving from side to side.
:twocents:      Mini > :slap: < me       Mini Me  :rofl:
MiniSimp
I"ll find out on the test drive. There will be a lot of things to tweak on that day.
Willy Mammoth
Yea, I know how that goes. That may be why the tires hit the frame so bad cause the springs twist and bend and let the rear move toward the frame.  :headscratch:  :dunno:
MiniSimp
That is kinda the whole point of the JJ shackle though is to allow side to side movement.
I've driven it on the road at 55mph with no death wobble with the JJ shackles on.
I know those are fine.
What I'm not sure about is how the two will react together. :dunno:
blackdiamond
Quote from: MiniSimp on January 23, 2006, 03:49:55 PM
I didn't realize that you had JJ shackles...I was just kidding  :yikes:
Do you have AOR springs on order too?
This is post 1111  :blah:
MiniSimp
Hey Mini, because I am too lazy to look to see if you posted a picture of it, do you know how tall the pivot blocks are? I will be using them on the back of my truck this summer, so I need to figure out how much I'll need to lower the rear suspension to keep the truck level
Thanks
Mike
MiniSimp
3/8" Top Plate
3/4" Center Bolt
1/4" Wall Tubing
1/4" Bottom Plate
So....um....1-7/8" I think?
#437
1 7/8" or 1.875" (remember x2 wall)
MiniSimp
3/8" Top Plate
6/8" Center Bolt
2/8" Wall Tubing
2/8" Wall Tubing
2/8" Bottom Plate
=15/8
=1-7/8
:greengrin:
o ya, well i was kinda correct for what i was adding, i am still proud of myself  :)
whiteman
MiniSimp, does Dave's Offroad Outlet have a Web page, or is there a place on line to order the hinges?  ???
I also expect you to put a good whooping on them to determine their strength :biggthumpup:
MiniSimp
MiniSimp
Quote from: whiteman on January 24, 2006, 05:29:15 PM
Nope.
14361 Tuolumne Rd
Sonora CA 95370
209-588-1880
:yesnod: Without a doubt! :thumbs:
MiniSimp
blackdiamond
Quote from: MiniSimp on January 27, 2006, 10:46:18 AM
DS Xmember Mount
You might consider welding the pieces together.  :gap:
Why did you make the base plate so angular?  I have seen other braces (i.e. steering box frame brace) using a similar design, so there must be a reason.  Rounded corner result is much less stress in the welds.  Tight transitions/corners induce stress concentrations.
MiniSimp
It is angular so the frame has less of a chance of tearing, it's not likely to happen, but what the hell.
6.72:1
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
MiniSimp
whiteman
Hey MS,  I noticed back on page 7, 8, and 9 you had some problems with the tie rod hitting the leafs, how did you solve that?
  I am running rears up front with a five leaf pack and just ordered the Billet Hi Steer arms, so I will most likley have the same problem.
MiniSimp
Quote from: whiteman on January 30, 2006, 11:47:41 PM
They were hitting the leafs because of the degree shims I had under the pack. After I removed them, no problem.
