MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
0 Members and 21 Guests are viewing this topic.
MiniSimp
Only got to work on sunday, so not much done.
Finished rebuilding my front axle, installed tie rod, degree shims and bushings for the front springs.
MiniSimp
#241
Updated To Do List
-Install MC08-R10 Adapter
-Install shims in front springs
-Install new bushings in front springs
-Rebuild front axle
-Install tie rod
-Install welded 3rd in rear axle
-Cut out tunnel for 2" drivetrain lift
-Install Dual Cases to Transmission
-Build new tunnel
-Box rear of chassis
-Install receiver hitch
-Weld tow bar mounting brackets
-Buy FROR Crossmember
-Install FROR Crossmember
-Buy twin stick shifter
-install twin stick shifter
-Install Front Suspension
-Install Front Axle
-Mount 35's in front
-Build front shock towers
-build front axle shock mounts
-build rear axle shock mounts
-build top shock mount for rear shocks
-build bump stops for rear axle
-build bump stops for front axle
-mount rear shocks
-mount front shocks
-buy IFS steering box
-plate/gusset frame for steering box mount
-mount steering box
-mount drag link
-mount steering stabilizer
-design belly pan
-build belly pan
-install belly pan
-buy receiver hitch tubing for front driveshaft
-build front driveshaft
-shorten rear driveshaft
-weld in roll cage
-incorporate roll cage into chassis with 90 deg elbow & sleeves
-move computer in to glovebox
-linex the interior cab
-replace oil pan gasket
trailhunter
well..................that is one of the most depressing to do list Ive ever seen.
Get to work!
vxrich
I dont want to write mine out for fear of it looking like your list but Im shure mine would be longer.... :yikes:  :heavy:  ::Dont really know what the meal Icon means just wanted to use it. :meal:
MiniSimp
Just made a shift knob for my High/Low box....what do you guys think?
Yota4life
is it just me or does that look really big? ???
crawlerdan
motorcycle piston?? its cool, different, but cool :cool:
MiniSimp
Quote from: Yota4life on August 04, 2005, 12:00:21 PM
Not that big.
Quote from: crawlerdan on August 04, 2005, 12:18:55 PM
Piston from a Honda 2500W generator.
crawlerdan
MiniSimp
MiniSimp
 :tantrum: The damn springs hit the damn tie rod!!!!!!! WTF!!
MiniSimp
MiniSimp
Updated To Do List
-Rebuild front axle
-Install tie rod
-Install rear axle
-Install rear brake lines
-Build new tunnel
-Install Front Axle
-mount rear shocks
-mount front shocks
-mount steering box
-mount drag link
-design belly pan
-build belly pan
-install belly pan
-weld in roll cage
trailhunter
that rock your using to sop up the oil on your shop floor is alittle big isnt it ;)
MiniSimp
Quote from: trailhunter on August 07, 2005, 12:08:49 AM
And sharp, and uncomfortable, and and and.... :shake:
RHG
I love the beer cap fill plug on the axle :rofl2:  :beerchug: Thats a pretty sweet shift knob too. Can you come pimp my ride too?
MiniSimp
Sure, I'll build your whole rig up for the right price! :greengrin:
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
