MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
MiniSimp
 :gap: Here is how it sits with the 5 leaf pack
MiniSimp
MiniSimp
MiniSimp
Quote from: toybuilt on September 06, 2005, 10:22:10 AM
looking good, what suspension are you using for the rear
I'm using 63" chevy springs, 3 leaf right now, but I might be going down to 2 leaf.
MiniSimp
Begin Project: Square Front Driveshaft :greengrin:
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
 :pirate: Double Cardan side
MiniSimp
MiniSimp
 :pirate: Cutting off a small piece to trace out the square.
MiniSimp
 :pirate: Don't try to use paint to mark the square, it doesn't work.  :gap: Use a thin black marker.
I used a cutting wheel to grind off the edges so it would be flatter
MiniSimp
MiniSimp
 :pirate: The small tube will have a weld line raised in the tube, you must file this down. I used 2"x0.25" HREW for the smaller tube.
MiniSimp
MiniSimp
 :pirate: Little more filing needed
MiniSimp
MiniSimp
 :pirate: Clean the work before you weld
MiniSimp
 :pirate: Tack weld first and make sure it is square
MiniSimp
MiniSimp
 :pirate: Let cool in between welds so you dont fry your spider bearings
MiniSimp
MiniSimp
Part 2: Double cardan end
Receiver hitch tube is used for the outer shaft, it has no seam. 2.5"x1/4"
MiniSimp
MiniSimp
#329
Again, cut off a slice of tube to trace your square cut.
