MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
*** YELLER ***
Looks OK to me, the welds are good with equal penatration, the design for the shocks is triangulated, the mounts are boxed for strength, the bolts are grade 8, why is nothing good enough for you people ??? Hey I know lets go wheelin' and see what happens on April 22, We will post the pictures so ya'll can see what happened.....!!!!!
except BACON
IronClad
sorry for lookin out.. i know a thing or 2 about ripping shock mounts off frames.   all the good welds and triangulation doesnt mean SQUAT if it is not braced properly.
here you can see part of the outline on a patch piece that is on my frame.. thats a good 10" long tear.. it took out part of the top and the bottom of the frame with it aswell.  not because the welds were bad but because  it was not braced properly !
Annihilation  Fabrication
Do you need a Hammer?
BLACKDOG
Quote from: snohman on February 26, 2006, 11:10:00 PM
Wow...the design..the welding..the fabrication...all I can say is...unforgetable.. :hahaha:
I'll see you on the side of the trail...broken..
At least he'll be prepared :thumbs:
Quote from: MiniSimp on February 27, 2006, 11:37:34 AM
This is what I currently carry, can you guys think of anything else?
I have pleanty of room to fit all this and more...
Axe
Axle, complete front left
Axle, complete front right
Axle, complete rear left
Axle, complete rear right
Bolts & Nuts
C-Clamp
Channel Locks
Clamp, Hose
Clamps, Battery
Come-A-Long
Drill, 12V, 1/2" Drive
Extension, Socket, 1/2"
Extension, Socket, 3/8"
Fire Extinguisher
First Aid Kit
Flat Repair Kit
Fluid, Antifreeze
Fluid, ATF
Fluid, Brake
Fluid, Brake Cleaner
Fluid, Carburater Cleaner
Fluid, Gear Oil
Fluid, JB Weld
Fluid, Oil
Fluid, PB Blaster
Fluid, Radiator Stop Leak
Fluid, Silicone
Fluid, Water
FSM
Fuses, 5-30A
Gloves, Leather
Gloves, Rubber
Gloves, Welding
Grease Gun
Hammer
Jack Stands
Jack, Floor
Jack, Highlift
Jumper Cables
Knife
Magnet on a stick
Oil Filter
Oil Filter Wrench
Pliers
Pliers, Lock-Ring
Pliers, Needle Nose
Pry Bar
Puller, Pitman Arm
Puller, Tierod
Punch, Brass
Rubber Mallet
Saw, Portaband, Battery
Scale, Knuckle
Screw Driver, Flat
Screw Driver, Philips
Serpentine Belt
Shackles
Shovel
Socket Adapter, 1/2"-3/8"
Socket, 1/2"
Socket, 1/4"
Socket, 10mm
Socket, 11/16"
Socket, 11mm
Socket, 12mm
Socket, 13/16"
Socket, 13mm
Socket, 14mm
Socket, 15/16"
Socket, 15mm
Socket, 16mm
Socket, 17mm
Socket, 18mm
Socket, 19mm
Socket, 3/4"
Socket, 3/8"
Socket, 5/16"
Socket, 5/8"
Socket, 54mm, 3/4" Drive
Socket, 7/16"
Socket, 7/8"
Socket, 8mm
Socket, 9/16"
Socket, 9mm
Sockets, Hex Head
Strap, Ratchet
Strap, Tow
Strap, Tree
Tape, Duct
Tape, Electrical
Tarp
Tire Deflators
Tire Iron
Tire Pressure Gauge
Tire, Spare
Transfer case main shaft & gears
Vice Grips
Welding Rod, 6011
Wire Crimpers
Wire Cutters
Wire Strippers
Wire Terminals
Wire, Bailing
Wood Block
Wrench, Allen combo
Wrench, Combo, 1/2"
Wrench, Combo, 1/4"
Wrench, Combo, 10mm
Wrench, Combo, 11/16"
Wrench, Combo, 11mm
Wrench, Combo, 12mm
Wrench, Combo, 13/16"
Wrench, Combo, 13mm
Wrench, Combo, 14mm
Wrench, Combo, 15/16"
Wrench, Combo, 15mm
Wrench, Combo, 16mm
Wrench, Combo, 17mm
Wrench, Combo, 18mm
Wrench, Combo, 19mm
Wrench, Combo, 3/4"
Wrench, Combo, 3/8"
Wrench, Combo, 5/16"
Wrench, Combo, 5/8"
Wrench, Combo, 7/16"
Wrench, Combo, 7/8"
Wrench, Combo, 8mm
Wrench, Combo, 9/16"
Wrench, Combo, 9mm
Wrench, Crescent
Wrench, Socket, 1/2" Drive
Wrench, Socket, 3/4" Drive
Wrench, Socket, 3/8" Drive
Wrench, Torque, 1/2" Drive
Wrench, Torque, 3/8" Drive
Zip Ties
              -Ronald Reagan
*** YELLER ***
I agree with you  :yesnod: and thanks for looking out  :biggthumpup: but :pokinit: fellas give a guy some cridit for creating a pretty sweet YODA :bowdown:  :clap2:
YEA its soap box time :snare:  so sit down :tantrum:  this build was not the fastest build nor was it the most expensive :shake_head: but it was fun and cool, I applaud critisizm  :clap2: and anything helpful to the build good or bad :thumbs:  hell look at the hits to this build and think how many others have used an idea from this build and then think....
Those of you quick to put it down should offer something helpful to the build :yesnod:  or do better  :dunno: and see us on the trail :eyebrow:  Hell you can watch it break and laugh at MINI too I'm gonna as long as it's not something I did.......
                                                     DAVE
except BACON
BLACKDOG
Quote from: oldyellercj on February 27, 2006, 06:12:25 PM
                                                     DAVE
Hell of a lot better build than I could do :yupyup:  I look forward to seeing you on the trail, if I ever make it out there mini.  :thumbs: no worries, I've got plenty of ideas that you will see copied, so make sure you don't go and patent anything :nonono:
              -Ronald Reagan
MiniSimp
Just ordered some essentials; benie to keep warm, TRE to replace the one I broke, and speedo extension cable to see how slow I'm going. :greengrin:
snohman
Quote from: BLACKDOG on February 27, 2006, 04:40:29 PM
I did'nt see a gas can(hopefully full of gas) and a bic lighter for a signal fire so the rescue party can find him..
83 Toy...original owner..Dana 60 5.89 Detroit front,Currie 5:86 spooled rear,R151f Turbo tranny,Marlin 23 spline 4.7 dual crawler t-cases,42" IROK'S, 272 to 1 crawl,Full Hydro steer,4-linked coil springs front & rear,LC Engr 22RE 185 HP stroker motor..
locktup
Quote from: snohman on March 02, 2006, 09:22:37 PM
To have a good fire you need lawn chairs.
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
www.LOCKTUPFABRICATION.com
Casey105
locktup would say...........................BURN IT             to the ground                           :moon:
LOCKTUP FAN CLUB
http://www.locktup4x4.com
Stinky
a little late w/ a comment...but on page 18 when oldyellercj said that welding on unprepped material is challenging and wat ever he meant about the wire bouncin before u get a puddle.......not to sound cocky or like a frickin know it all but im goin to school for a engineering dgree in welding and weld prep is prolly the most important thing next to a good smooth, well penetrating weld......especially makin a driveline mount..that takes allll the torque from the motor n the vehicle's weight fightint it.....that about the LAST place i would richard around with makin shirty welds.......imagine that comin loose on the highway at 70mph and the driveshaft binding n locking up...........
87 p/u SAS, 22RE, built, then cut up and scrapped
94 ex cab P/U, SR5, fully loaded, 3.4 swap, r150f, a/c, bumpers, 33s, glass fenders...sold
00 Stoopid Duty 250, ex cab, lariat, v-10,000
94 reg cab, 22re, duals, 38.5 boggers, sas, 4 link, tube bed, build underway... http://pirate4x4.com/forum/showthread.php?t=967836
88 Samurai, soa, buick 3.8, th350, zuki case, 1/4 done... anyone wanna buy it??
MiniSimp
Quote from: Stinky on March 07, 2006, 03:54:42 PM
If I make it past 30mph I'll let you know! :talkingn:
*** YELLER ***
Your right :clap2:  your are too late with the comment :thumbdown: the further you get in your class :smack:  you will learn that if the wire feed speed is turned up too much the wire will jump off the surface you trying to weld to :therethere: so when you git done with your D gree :bowdown: let me know how it goes in the real world. ' Cause I've been to a different school IT'S CALLED " LIFE " JUNIOR and I dont recal making a drive line mount ???  :confused: and while your gettin' that there D gree how about Gettin' some SPELLING LESSONS there mister I'm going to school for whatever, I have been welding a while and try my best to not make SHIRTY welds If there not good they get ground and replaced with the right welds this is the life of another person in my hands and I would not richard around with the life of my NEPHEW.
                                               OLDYELLERCJ :king:
except BACON
Stinky
well...if YOU can read u will note i said "NOT TO BE COCKY OR ANYTHING"...soo ya.....n say all u want about a d gree...but in the REAL WORLD employeres dont wanna hear, I LEARNED ON MY OWN, ITS CALLED REAL LIFE...they do wanna see a degree.....soo yaa....think before u speak....
MiniSimp
blackdiamond
I work as a structural engineer at a naval shipyard and I have co-workers that are engineering technicians (formerly production workers) and I work directly with the production workers (about 50% are welders).  I can tell you that practical hands-on knowledge can be far more valuable than an education.  I didn't learn many specific things in college that I use directly with my job.  I also work with several very knowledgeable weld engineers.  The biggest reason that we need weld engineers is to qualify new weld procedures and to help us how to figure out how to do difficult jobs while staying within the rules.  I know several people that do amazing welding outside of work, but the rules are so detailed that they are crippled while at work.
Obviously as an engineer I have great respect for education, but I also know 1st hand how much knowledge can be gained from hands-on experience.  It is one thing to prepare and weld something in a controlled environment, but it is a whole different animal when the welder is literally laying in a hole upside down welding with a mirror.  Sitting at my desk being proud of my education doesn't help in those situations.  As a result of being willing to "get dirty" I now know that I can fit through a 12-3/4" hole!
Just my  :twocents:
*** YELLER ***
Education is great I agree :therethere:  :beerchug:
except BACON
MiniSimp
blackdiamond
MiniSimp
LOL, ok then.
Well said BLDI :greengrin:
blackdiamond
Quote from: MiniSimp on March 10, 2006, 10:23:58 PM
LOL, ok then.
Hey MISI! I still have hair  :tantrum:
It is "bd" to you  :yupyup:
:biggthumpup:
:psss: BlackDog and I worked this out when I joined the board.
MiniSimp
MiniSimp
Here are some pictures of my 2nd set of 35" Boggers today. :greengrin:
Ramrod
where are the pics of you out there driving around in that crap
*** YELLER ***
Can I get that jelly filled???
except BACON
MiniSimp
Quote from: bigbluewillys on March 11, 2006, 03:37:29 PM
It's locked front and rear, wouldn't be very safe.
IronClad
why wouldnt it be safe?  i used to wheel  snow with  a welded front and rear rig..   i have a locker in the front and i hate it.. going back to a welded front.
Ramrod
Quote from: MiniSimp on March 11, 2006, 06:53:51 PM
ever heard of snow wheeling?, spinning doughnuts, having fun?
MiniSimp
Quote from: bigbluewillys on March 11, 2006, 07:36:56 PM
If I wasn't 160 miles away from my truck, I probably would. :gap:
BoMXtreme
Thats a lot of snow you got.  Its been so cold we even got snow in central cali.
Looking for 35s in SLO later summer time, like august.  Swapping Tires??
toybuilt
I live in Auburn and we got at least 3 inches on Sunday, it rocked! :yesnod:
1983 Toyota Turned Chevy
