MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
0 Members and 25 Guests are viewing this topic.
*** YELLER ***
I saw your mounts and they looked good  :thumbs:  just remember to gusset them for added strength :yesnod:  we used an old drag link and pannard bar with rubber bushings left on each end , so the transfer can still move a little :eyebrow:  will have more pics. tommorow
except BACON
Ramrod
if you guys take this out to holister for the first run let me know i join in
*** YELLER ***
ok :greengrin:  here ya  :biggthumpup: go all done :eyebrow:  more pictures later of all the work when MINI gets home, including video of it  :driving:
except BACON
MiniSimp
whiteman
Ha Ha Ha!  Thats great Mini glad you got it done, you know, I dont think I have seen one pic of you without a smoke. :smoke: :laugh:
*** YELLER ***
MINI  :beerchug: nice work this weekend :woohoo: I will finish up the welding on the crossmember this week :thpst: then maybe :dunno:  I'll go for a  :driving:  for you sound good :eyebrow:
except BACON
MiniSimp
Quote from: whiteman on February 05, 2006, 12:33:24 PM
Gotta stay relaxed when you are doing something you've never done before. :greengrin: This is my first build after all.
Quote from: oldyellercj on February 05, 2006, 07:31:34 PMthen maybe :dunno: I'll go for a :driving: for you sound good :eyebrow:
We'll talk about that one Dave, still gotta move the blue pile first. :yesnod:
MiniSimp
Here is video of it running a whole 2 feet after we mounted the crossmember...
Clicky
*** YELLER ***
except BACON
whiteman
Quote from: MiniSimp on February 05, 2006, 08:27:36 PM
Gotta stay relaxed when you are doing something you've never done before. :greengrin: This is my first build after all.We'll talk about that one
Yea I know how it goes, my shits it being built by a high schooler :laugh:.   Makes ya wonder how long it will hold up :rofl2:
I get by with som fresh cope!  :drooling:
CTENG in KS
Quote from: whiteman on February 03, 2006, 01:47:49 AM
shirt!  Mine suck compared to that.
X2...but all that matters is they hold...and you can cover them with lots of paint.   :gap:  :yesnod:
MiniSimp
Gained a little bit of clearance :greengrin:
Ramrod
I can't wait till they come out with the mco7-r10, that just looks sick
MiniSimp
It's really nice!
When we built the crossmember we had the cases jacked up so high it was pushing up the truck.
When we lowered it down they only dropped 1/8" so I was stoked.
whiteman
Hey Mini, on my truck I was going to weld on the platforms for the cross member in the position were it would lift the back of the t-case 1" higher than the stock mounting point.
My question is
1. Am i going to have enough clearance between the body and T-case if the T-case is that mush higher? (I have the body off so I cant tell)
2.  Do you think that that tilting my T-case up one 1" is going to hurt anything, I.E oil to motor, more stress on motor mounts... etc?
MiniSimp
Quote from: whiteman on February 06, 2006, 03:52:53 PM
If you have your body off, I would make your t-case 1/2" above the bottom of your frame and then cut out your tranny tunnel and build a new one. That way you can build a flat belly! :greengrin:
Loosen your motor mounts before you do it. Then retighten them after you have it positioned. I've seen people clock their entire drivetrain 10* to get a flat belly.
whiteman
Thanks Mini, I have been looking into a flat belly, but i have to set up my cross member, 4-Link, and Drivlines before i make the belly pan.
*** YELLER ***
except BACON
*** YELLER ***
I agree as long as they hold !!
FUNCTION OVER FORM  !!!
its not how pretty they are but the penatration, as long as its deep and even it will hold.
start with a clean surface and watch what your doing and you too can weld like the pros:yesnod:
Quote from: CTENG in KS on February 06, 2006, 06:44:12 AM
except BACON
MiniSimp
I just ordered me some sweet Marlin goodness :ladys-man:
I hear she comes with the doors....
Thanks to the wife!
AKDuramax
this has been a sick build but when will it hit the trail??
83' toyota sr5 long bed 31x10.5 bfg mt's -under construction-
86' suzzuki samuri 33x14.5 boggers, 1.6 tracker spap, 4.62's locked trackuri axles, 4.1 transfer, exct.
02' chevy 2500HD duramax 35x12.5 mt's fabtec 6", edge box,k&n intake, mbrp 4" duals, exct.  :)
MiniSimp
Quote from: AKDuramax on February 07, 2006, 10:05:47 AM
Will be on the trail by february 26th at the latest. :yesnod:  :crossed:
MiniSimp
#502
So, here are the final specs on the build:
1985 Toyota SR5 4WD Standard Cab
1985 & 1987 Frankenstein 22RE
1983 Front Axle
1986 Power Steering Box
106" Wheelbase
2.28 Crawler Box with stock shifter
2.28 Rear Transfer Case
48" High-Lift Jack With Mounts
Aussie Locked 4.10:1 Front
Black Rock Krawler Wheels 15x10"
Bucket Seats (stock)
Chevy Rear Springs (3 leaf + overload cut down)
Front Range Offroad Steering Frame Brace
Front Range Offroad Transfercase Center Section
Front Range Offroad Twinstick Shifter
Home Built Chevy Spring Hangers
Home Built Flat Bed
Home Built Gas Filler Hose Mount
Home Built Rear Pivoting Lift Blocks
Home Built Rock Sliders
Home Built Shift Knobs
Home Built Video Camera Mount
Interco Tire Superswamper Boggers 35x14.50x15R
Interior Roll Cage
Johnny Joint Rear Shackles
Magellan Meridian Color GPS WAAS Compatibility
Marlin Crawler 1.5" Wheel Spacers (Front)
Marlin Crawler 26" Brake Line 3 piece kit
Marlin Crawler Drag Link
Marlin Crawler Low Profile Drain Plugs
Marlin Crawler MC08-R10 Clocked Adapter
Marlin Crawler Pitman Arm
Marlin Crawler Rebuilt Knuckles
Marlin Crawler Steering Arms
Marlin Crawler Tie Rod
Marlin Crawler Transfer Case Rebuilt
Marlin Crawler Tube Doors
Marlin Crawler U-Bolt Flip Kit (Front)
Procomp ES1000 14" Travel Shocks
Procomp ES2000 Steering Stabilizer
Sliding Tinted Rear Window
Thales Navigation Swivel GPS Mount
Toyota 1985 Rear Springs Up Front (4 Leaf)
Trail Gear 2" Wheel Spacers (Rear) (and free)
Unleaded Gas
W56 5 Speed Manual
Weatherguard Tool Box
Welded 4cyl 4.10:1 Rear
Ramrod
All the time and energy into the front axle of that thing and no longfields.  Its gonna suck when you break a birf the first time out
MiniSimp
CTENG in KS
Don't worry mini, I aint got no longs neither...  :-\\
whiteman
You don't deserve Longs untill you brake an axle on the trail and have to limp home.
*** YELLER ***
YO MINI  :moon:  have drive line will wheel  :disturbed:
Thanks to Jim at
Blue Iron drivelines
Sonora Ca
(209) 533-8847 :biggthumpup:
Make you a deel  :yesnod: you keep the tube doors  :wink2: and I get her :eyebrow: for the Driveline. sounds fair all in favor say I :clap2:  :shhh:
except BACON
MiniSimp
Sweet! It's wheeling time!
Bolt it up for me will ya! :eyebrow:
*** YELLER ***
 :tantrum: There will be no :shakehead:  wheeling until OLYELLER is running
You can take it for a spin :driving:  but no 4X4 :biked:
Until WE :argue: finish OLYELLER :spankbutt:
Bleed Brakes
Build Shock Mounts
Thats it right ??? :woohoo: :acclaim:
except BACON
