MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
Quote from: tanman2003 on July 20, 2005, 10:04:56 PM
that heat sink idea might work if you drove around town in 4wd.
And if you bust a rear u-joint or driveline and you have to drive around town in front wheel drive.  You would want all that grease in there to help with the heat.
MiniSimp
Well, There goes the "Budget"
I just ordered a MC08-R10 adapter!!!!!!!
I figure there's some things you have to do right the first time.
You gotta be kidding me.  I hate you, you know that?
MiniSimp
Quote from: Hyena on July 25, 2005, 09:54:35 PM
Jealousy is different than hate! :greengrin:
It's ok, I haven't gone tripples yet. :thumbs:
Not jealous, truely is hate, but in a good way  :)
MiniSimp
lilbuddy
Me too! I could barely afford my Aussie locker... Sucks being my age with a part time minimum wage job!
RIP Kyota.... you are the man
GET IT!!!
MiniSimp
Quote from: lilbuddy on July 26, 2005, 12:09:14 AM
I've been there man, makin $6 an hour bagging groceries at Safeway.
I had a 1988 Extra cab with a 3" body lift and 32's (it was all I could afford)
MiniSimp
MiniSimp
oddball
Quote from: MiniSimp on July 21, 2005, 01:26:50 PM
Here are the pics of my welded 3rd.
The spiders were welded together, then ground down to accomidate the 1/4" piece of steel to connect the spiders together.
The welder used was a Miller 225 Thunderbolt
Here is the specs on the rod available from Karr Products:
Bowman Weld
Tensile Strength - 128,000psi (Hardens to 180,000psi)
Yield Strength - 99,500psi
Hardness - 250 Brinell
Corrosion Resistance - Better than most stainless steels
Specific Applications - Armor Plating, Bucket Teeth, Crusher Rolls, Earth Moving Equipment, Pulverizing Hammers, Tool Steel
Sounds like some bad ass rod
MiniSimp
MiniSimp
Ramrod
well put that sucker in already and go wheelin
ozzy93xtra
Quote from: bigbluewillys on July 27, 2005, 01:15:20 PM
YAH MAN, I WANNA SEE IT WITH THEM 35'S TOO :beerchug: IT HAS COME ALONG, LONG WAY :usa:
M- I- S- S- I- S- S- I- P- P- I- B- O- U- N- D-
MiniSimp
Quote from: ozzy93xtra on July 27, 2005, 02:43:18 PM
Still have a while to go before I can wheel it.
Here's the list:
-Install MC08-R10 Adapter
-Install welded 3rd in rear axle
-Cut out tunnel for 2" drivetrain lift
-Install Dual Cases to Transmission
-Build new tunnel
-Box rear of chassis
-Install receiver hitch
-Weld tow bar mounting brackets
-Buy FROR Crossmember
-Install FROR Crossmember
-Buy twin stick shifter
-install twin stick shifter
-Install 4 degree shims in front spring pack
-Install Front Suspension
-Install Front Axle
-Mount 35's in front
-Build front shock towers
-build front axle shock mounts
-build rear axle shock mounts
-build top shock mount for rear shocks
-build bump stops for rear axle
-build bump stops for front axle
-mount rear shocks
-mount front shocks
-buy IFS steering box
-plate/gusset frame for steering box mount
-mount steering box
-mount tie rod
-mount steering stabilizer
-design belly pan
-build belly pan
-install belly pan
-buy receiver hitch tubing for front driveshaft
-build front driveshaft
-shorten rear driveshaft
-weld in roll cage
-incorporate roll cage into chassis with 90 deg elbow & sleeves
-move computer in to glovebox
-linex the interior cab
-replace oil pan gasket
Then I'll probably think of something else to add to the list :greengrin: maybe one day go wheeling.
Yota4life
hey stop typing and get it done! :joke: hey when this is all done its going to be a really sick rig man... When do you plan on having it done?
MiniSimp
Quote from: Yota4life on July 27, 2005, 05:55:57 PM
Wow, that's a hard question,..... I'm hoping to have it done by late October, early November.
I only get to work on it on the weekends, so that kinda slows me down.
Ramrod
#228
Quote from: MiniSimp on July 27, 2005, 02:55:05 PM
Here's the list:
-Build new tunnel
-Install Front Axle
-mount rear shocks
-mount front shocks
-mount steering box
-mount tie rod
-design belly pan
-build belly pan
-install belly pan
-weld in roll cage
Bust ass and you could be done in under two weeks. Plus you don't have to do all those things before you wheel. do it in phases.  look at my build up I just did. that was 5 days start to finish and that was just about as much stuff as you have left to do.
MiniSimp
Quote from: bigbluewillys on July 27, 2005, 08:00:10 PMBust ass and you could be done in under two weeks. Plus you don't have to do all those things before you wheel. do it in phases.  look at my build up I just did. that was 5 days start to finish and that was just about as much stuff as you have left to do.
Yea, I'm not that fast.
It's the cleaning that kills me, for some reason I have to clean everything I'm fixing.
Besides, I'm not even coming close to going on a trail until it is 100% ready.
Willy Mammoth
Quote from: MiniSimp on July 28, 2005, 10:24:25 AM
I'v heard that before. I still don't have my gauges hooked up and my brake / fuel lines are still tie straped to the frame.
You gota test it out before it's done, it's just not right if you wait till it is all done. :gap:
MiniSimp
Well, I got the crawler box mounted to the MC08-R10 today at lunch, so hopefully I'll be able to mount it to the TCase tomorrow at lunch. :greengrin:
MiniSimp
Well, I'm gone for the weekend to work on my rig, but i'll leave you guys with some pictures... :greengrin:
MiniSimp
MiniSimp
MiniSimp
MiniSimp
WV4runner
You remind me a lot of myself, HUGE detailed lists and must clean and paint every part.   :gap:
Rockdiver
Looks Good    Wish I had time for the detail stuff
vxrich
Looks great Im gonna try and order my cases this week  :crossed:  :turtle:
