MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
0 Members and 6 Guests are viewing this topic.
MiniSimp
Um....rear flex?
MiniSimp
Little better.
MiniSimp
House Flex
MiniSimp
House Flex
MiniSimp
House Flex
MiniSimp
Low profile rear spring hangers #1
MiniSimp
Low profile rear spring hangers #2
MiniSimp
Low profile rear spring hangers #3
MiniSimp
Low profile rear spring hangers #4
MiniSimp
Low profile rear spring hangers #5
MiniSimp
They were fabricated by a friend of mine.
they are made from 3.5"x3.5"x1/4" square tubing and 1/4" flatstock.
MiniSimp
Today I half way mounted the 63" Chevy springs. Used tempory shackles until I make up my mind what I want to do. Right now as it sits the shackle is at a 40* angle, as soon as I add any weight to the truck the angle will only get worse. I'll probably make the factory shackle longer, maybe 6" also, and that should take the angle to 50* unloaded. BTW, Marlin's U-Bolt flip kit works perfect with Chevy springs. :thumbs: :turtle:
MiniSimp
Going to have to do something about the E-Brake cable, any ideas? :dunno:
MiniSimp
These springs are extremely long!
MiniSimp
Here you can see the shackle angle, no bed, no spare tire, no weight at all.
MiniSimp
18.25" from the top of the axle to the top of the chassis. Unloaded it is 1.25" higher. Loaded, should be the same as stock! :thumbs:
MiniSimp
Well, with the Chevy's on it gets around 14" of verticle travel, not bad.
MiniSimp
Here is at sitting height
MiniSimp
This is maxed out.
MiniSimp
Score one point for the Toyota, I'll get it back though! :tantrum:
MiniSimp
Tested out the rear flex with the hi-lift. Put my larger tool box on.
MiniSimp
The front tire is about 8" off the ground. Time to build the rears up front packs.
MiniSimp
The tire touching the chassis is limiting my flex. Time for 1.5" spacers in the rear.
MiniSimp
Made a spiffy little bracket to mount the fuel filler hose to the tool box.
MiniSimp
Put my :turtle: sticker on :thumbs:
MiniSimp
Found some tempory ghetto shocks to put on so I can still drive it.
MiniSimp
Put on some removable mud flaps for the police. :stopit:   :mad: VC27600
MiniSimp
#57
Built my spring pack for my "Rears up front"
They should be nice compared to my currently reversed springs.
Opened up the clamps. Need bushings.
Specs:
1st leaf: 85 1st leaf
2nd leaf: 85 2nd leaf
3rd leaf: 85 3rd leaf
4th leaf: 85 1st leaf cut down
5th leaf: 85 3rd leaf cut down
6th leaf: AAL
MiniSimp
One of the most important mods so far, the bottle opener! :beer:
MiniSimp
#59
Just ordered Johnny Joint Shackles for the Chevy rear spring shackle. Decided to not go with the double shackle set up, as I want this to be a multi-purpose truck. Should be here by the 11th.
