MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
0 Members and 6 Guests are viewing this topic.
MiniSimp
toybuilt
You should put a drop box on the front of your truck.
1983 Toyota Turned Chevy
crawlerdan
MiniSimp
Quote from: toybuilt on August 07, 2005, 05:14:41 PM
Why? All that would do is lift it more. I'm trying to avoid that.
AlaskaToy
Quote from: MiniSimp on August 07, 2005, 06:20:29 PM
Loose the shims.  Tie rod contact to springs will worsen when turning.
droppnig the front hanger does some important things:
1. improves pinion angle
2. when combined with flatter spring packs,
     A.  yeilds the same or less lift, and
     B.  reduces nose dive when braking.
1-ton Toy
Loose the shims, it will gain clearance with the tie rod.  I took my shims off my front springs and didn't feel a different.  I would say build a drop hanger too but it isn't needed.  The build-up is going good.  does it feel goo to finally get a bunch of stuff done on the truck?
MiniSimp
Quote from: Hyena on August 07, 2005, 07:09:37 PM
Feels great! Mainly happy to get tires under it again.
MiniSimp
crawlerdan
MiniSimp
Quote from: crawlerdan on August 07, 2005, 09:34:30 PM
what shakles are those?
Came with the extra chassis I got with the truck, probably skycrapper or procrap.
They were the right length, so I used them.
MiniSimp
Tube doors are almost done, just need to come up with a latching system...
MiniSimp
Yota4life
6.72:1
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
RHG
Hey mini how thick of metel did you use to plate the steering bumpstops? Did you add the gusset to your balls...uhm bells, you know WTF I am talkin bout!
6.72:1
Inquiring minds must know. Plate thickness on bumpstops? ".25?
[email protected]
MiniSimp
Quote from: rocks hurt good on August 19, 2005, 12:18:32 AM
0.25, it's what I had laying around, I probably could have gotten away with 3/16" though.
Quote from: rocks hurt good on August 19, 2005, 12:18:32 AMDid you add the gusset to your balls
No, my balls are just fine, if they bend I plan to replace them with full width Toy/D60 Diamond Axle.
CTENG in KS
Bah...D60 straight up if the toy housing fails...JUST DO IT!! :biggthumpup:
RHG
 :yesnod:  Thanks Mini. Your running 35's? Hmm I am going to be running 37's, I wonder if I should gusset my balls. Nah, if it breaks then I'll go big.......yeah baby yeah D60's front and rear. I hope thats after I hit the lottery.
Willy Mammoth
All this talk about balls has got me worried. I am running 38's, but I think I am light enough it won't matter. Besides I don't plan on jumping this thing. :crossed:
Sorry for the jack Mini, keep up the good work and now it's time to go bug Mike.  :yupyup:
MiniSimp
Quote from: CTENG on August 21, 2005, 12:55:09 AM
The reason to go with the Diamond housing with D60 knuckles over the regular D60 is you get more clearance at the 3rd.
MiniSimp
Ok, so finally an update!!!
Feels like forever since I've worked on my truck.
Fixed my front spring pack touching my tie rod by removing the degree shims and 1 leaf, so now it is a 5 leaf pack and still around the same height.
I also mounted my duals, but used the stock crossmember until I can get the FROR crossmember/skidplate.
On to the pics....
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
