MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
0 Members and 10 Guests are viewing this topic.
MiniSimp
Got the front square driveshaft installed.
MiniSimp
MiniSimp
MiniSimp
Nothing like fighting dogs and 12 wheel drive  :hammerhead: Thats all for now! More work next Saturday.
MiniSimp
#364
Got a little more work done
Filled front axle
Filled rear axle
Filled Crawler case
Filled rear case
Installed :turtle: 26" Brake lines
Installed brakes
Installed  :turtle: Drag link
Installed  :turtle: low profile drain plugs front and rear.
Measured out front shock towers
Removed stock shocks
Now for pics.
MiniSimp
 :greengrin:
MiniSimp
 :greengrin:
MiniSimp
MiniSimp
 :greengrin:
MiniSimp
He he he, I snuck out to build!!!!
MiniSimp
 :greengrin:
MiniSimp
 :gap: Dave thinks he can fabricate :laugh:
MiniSimp
 :thumbs:
MiniSimp
 :pirate:
MiniSimp
 :greengrin:
MiniSimp
 :gap:
MiniSimp
 :thumbs:
MiniSimp
 :pirate:
MiniSimp
 :greengrin:
MiniSimp
Here is the latest to do list. (I think it shrunk a little.... :dunno: )
Bleed brakes
Build bump stops for front axle
Build bump stops for rear axle
Build front axle shock mounts
Build front shock towers
Build rear axle shock mounts
Build top shock mount for rear shocks
Buy FROR Transfer case center section
Buy IFS steering box
Buy new bolts for front shackles
Buy FROR 10 Degree twin stick shifter w/custom boot
Buy Marlin Cralwer Axle Breather Kit (x2)
Buy spare tire
Fill brake reservoir with fluid
Grease steering arm zerts
Incorporate roll cage into chassis with 90 deg elbow & sleeves
Install frame brace
Install front shocks
Install FROR Center section
Install new bolts for front shackles
Install rear shocks
Install receiver hitch
Install seats
Install spare tire
Install steering box
Install steering stabilizer
Install twin stick shifter
Linex the interior cab
Move computer in to glove box
Remove stock transfer case cross member
Replace oil pan gasket
Rewire brake lights
Shorten rear driveshaft
Torque front driveshaft bolts
Torque front spring hanger bolts
Torque front spring pack bolts
Torque front spring shackle bolts
Torque transfer case mounting bolts
Weld plate/gusset frame for steering box mount
Weld tow bar mounting brackets
*** YELLER ***
Yo MINI :king:  nice job  :biggthumpup: even though the work was cut short :sad2:  you do good work :disturbed: But you forgot the HI LIFT mount :twocents:  :beerchug:
except BACON
MiniSimp
Got a little work done today...mostly just :bull crap: work, but still work.
Here is the latest to do list. (I think it shrunk a little....  :mad:  )
Bleed brakes
Buy spare tire
Install frame brace
Install rear shocks
Install seats
Install spare tire
Rewire brake lights
MiniSimp
 :gap:
MiniSimp
 :greengrin:
MiniSimp
Pivoting lift blocks are done!
Thanks go to Dave at Dave's Offroad Outlet in Sonora (209) 588-1880
MiniSimp
MiniSimp
Got the FROR TCase center section, and the FROR twin stick shifter, so after christmas here is the latest to do list.
Bleed brakes
Buy spare tire
Install frame brace
Install rear shocks
Install seats
Install spare tire
Rewire brake lights
Hooch
Are your lift blocks installed yet? Do they weld onto perch? Can you use them front and rear or just rear?
MiniSimp
Quote from: Hooch on December 26, 2005, 07:00:22 PM
No
Yes, and bolt to the springs.
Not sure, don't want to try. :greengrin:
shad
#389
Quote from: BigMike on December 07, 2005, 11:48:06 PM
Hey Mini, did you install or build yourself a diff vent line breather kit? Looks like a ferreled (sp?) piece for your breather. I need to do that.....
You can also use a Nissan threaded manifold vaccum port to do this as well.
I used them on my axles and it threads right into the housing. 7/32 vaccum hose slips right on it.
The Nissan part number is 38323-C6010.
Those pivot shackles look pretty slick.
Minisimp get some ramp posing pics I want to see how much more flex they give.
Any concerns for additional axle wrap those might give?
Are you gonna do a rear traction bar as well?
86 Toyota 4 runner
My cardomain page
