MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
MiniSimp
Make sure you file down any burrs on the piece.
MiniSimp
Line it up, and draw in your square
MiniSimp
I used a Portaband saw for the initial cuts, then get closer with the grinder.
MiniSimp
MiniSimp
The templet piece slides on like O.J.'s glove. :greengrin:
MiniSimp
RHG
....and if it breaks, grind it off and re-weld it!
MiniSimp
MiniSimp
MiniSimp
Started installing the roll cage this weekend...
MiniSimp
 :greengrin: Front drivers side plate top and bottom
MiniSimp
 :greengrin: Passenger side plate top and bottom
MiniSimp
I didn't like where All-Pro wanted me to mount the rear plates because it would have put them close to my head, so I built a new base plate out of 1/4" with the holes 5-3/8"x3"
I think their cage must be designed for an extra cab or something.
MiniSimp
 :greengrin: I had my uncle Dave do the welding, he is better than me with a mig.
MiniSimp
 :greengrin: I tried to push the main hoop as far to the rear of the cab as possible
MiniSimp
 :greengrin: Got the front two bars welded up in position, thats all for now
MiniSimp
Here is the AutoCAD drawing for the rear plates
MiniSimp
Just ordered a set of 3 red 8" extended brake lines from :turtle:  :thumbs:
MiniSimp
Damn! That was fast!
Thanks for the next day service Dave!!!!
MiniSimp
Just ordered the FROR frame brace! :gap:
MiniSimp
It really depends how you position the box, but it mounts kinda like this:
MiniSimp
Got more work done on the cage, now I just have to paint it and slap it in.
Now for the pics...
MiniSimp
My uncle Dave did all the welding...
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
 :ack: Good thing I don't give a :pokinit: about the interior. Caught the headliner and drivers side pillar on fire.
Don't forget to use sheetmetal in between your work and your vehicle!!!
MiniSimp
MiniSimp
