MiniSimp's 1985
Started by MiniSimp, January 30, 2005, 10:54:12 PM
0 Members and 9 Guests are viewing this topic.
MiniSimp
Drove in the new axle seals :greengrin:
MiniSimp
MiniSimp
Felt, rubber, metal ring :greengrin:
MiniSimp
MiniSimp
Cut down the break dust shield :pirate:
MiniSimp
CTENG in KS
Jesus, that grease looks like baby poop.
MiniSimp
Thats about it, just need to clean the rotor with an ozone depleating amount of brake cleaner :gap:
MiniSimp
CTENG in KS
Yup, nasty...I like the blue synthetic stuff, mostly because it is blue, I like blue.
MOB-40
THIS THING HAS COME A LONG WAY.NICE U GOT IT DOC HERE! :beerchug:
OI"
MiniSimp
Getting there, I thought I would be further along after having it for 7 months, but I guess finances dictate the actual build time.
CTENG in KS
Bah, I've had mine for a year and a half, I've wheeled it once, it has been in the progress stage ever since...but I think I see a light.   :thumbs:
MiniSimp
Quote from: CTENG on July 19, 2005, 12:38:04 PM
I'm forcing myself to see the light. By the next time I drive it, it will be trail worthy.
oddball
Yeah its looking good , Im getting jealous....everyone is progressing with there projects and Im going in reverse at full throttle
tanman2003
jeez whats with all the grease? are those regular birfs? cause im sure youll break one with 35"s and a locker.
and i wouldent want to change it in the field with all that grease in there.
MiniSimp
#196
Quote from: tanman2003 on July 20, 2005, 05:00:34 PM
That is how you are supposed to pack them.
Quote from: tanman2003 on July 20, 2005, 05:00:34 PMare those regular birfs?
Regular old birfs from 1985
Quote from: tanman2003 on July 20, 2005, 05:00:34 PMcause im sure youll break one with 35"s and a locker.
Not likeley, you will break birfs mostly according to your driving style, whether or not your steering stops are adjusted correctly, not just cause you are running 35's. I've known people with stock birfs and 37's and never broken them.
Quote from: tanman2003 on July 20, 2005, 05:00:34 PMi wouldent want to change it in the field with all that grease in there.
What would you rather do? Run no grease? Put one back in with out grease?
Edit: That is the lamest thing I've heard to date. :shake:
More grease means less heat when you do go to change the birf if you have to.  I packed my birfs with a great maount of rease.  Keeps the joint turning good and cooled.  Not bad to change it out with all that grease anyway.  That way you just grab the glob of grease on the broken birf and slam it on the new birf.  Don't have to carry extra grease!
MiniSimp
Quote from: Hyena on July 20, 2005, 08:52:33 PM
Exactly! :thumbs:
tanman2003
i just pack the cv and the knuckle bearings, all that extra grease will not get in there by itself, it will just sit there,  you wasted the grease for no reason. i just put about an 1/8th inch coating on the bell.
to grease the cv i put some grease in the cv spline and shove the axle in the splines to make it pack in there till its full.
that heat sink idea might work if you drove around town in 4wd.
its fine, its not gonna hurt anything,
i also diddnt say not to put any grease in there so
no, its not the lamest thing you ever heard,
its the lamest thing that you thought up yourself.
MiniSimp
To answer your question, this is from the FSM...
MiniSimp
#201
Here are the pics of my welded 3rd.
The spiders were welded together, then ground down to accomidate the 1/4" piece of steel to connect the spiders together.
The welder used was a Miller 225 Thunderbolt
Here is the specs on the rod available from Karr Products:
Bowman Weld
Tensile Strength - 128,000psi (Hardens to 180,000psi)
Yield Strength - 99,500psi
Hardness - 250 Brinell
Corrosion Resistance - Better than most stainless steels
Specific Applications - Armor Plating, Bucket Teeth, Crusher Rolls, Earth Moving Equipment, Pulverizing Hammers, Tool Steel
MiniSimp
MiniSimp
MiniSimp
MiniSimp
MiniSimp
 :greengrin: The threw a coat of drippy metallic grey on there just for fun.
RHG
yes! armor plating! I dont think youll have a problem with your welds. haha
MiniSimp
A guy on PBB made this, I'm still laughing!
MiniSimp
