Making Of The Willy Mammoth
Started by Willy Mammoth, November 18, 2004, 08:06:16 PM
0 Members and 8 Guests are viewing this topic.
RockSlayer
Did you know that the Cummins 4BT weighs more than a small block anything.  :yesnod: And they definitely can be tuned relatively easily to put out massive amounts of torque really easy.  :driving: Forget running Toyota running gear.  :stomp:
and Mark already said he didnt want the 4bt
RockSlayer
Lady Di
 LOL!! Yeah, he doesn't want anything significantly heavy in it. :yupyup:
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
Mark, have you considered a 1kzte toyota diesel?  (have I mentioned this before?)  I'm pretty sure they come with an r151 tranny, but the biggest downside is probably the price.  Really good power, high redline (5,000 rpm I think) and a very good dependability record.
I know I've said it before, but it's worth saying again, you do amazing work Mark :thumbs: .... I don't think that little guy is big enough to prove my point!  You know, if we could just put your brains, your skill and my ....... my ........ well, your brains and your skills are enough!  I'm just gonna get in the way  :_oops:  :bolt:
Lady Di
Willy Mammoth
Quote from: kneedownnate on May 08, 2006, 11:46:34 PM
Is this a 4 or 6 cyl? and is it electronic or mechanical injection?
Racer-X
Willy Mammoth
MiniSimp
They came in Hilux Surf models.
Engine is available on EBAY
This might help:
http://www.toyotasurf.asn.au/techsite/24lt.htm
http://www.toyotasurf.asn.au/techsite/30lt.htm
Toyota 1KZ-TE: The 1KZ-TE is Toyota's turbocharged replacement for the 3L. This 3.0 liter engine is a new design from the ground up. It boasts high tech features such as electronically controlled fuel injection and engine and emissions management systems. The result is outstanding performance from a light weight engine, but for a pretty heavy price. The engine is not easily available in Pakistan at the moment, although that might change in the future. Most mechanics have no idea how to wire up this EFI engine, let alone make it work properly; the more conventional non-EFI 1KZ-T may be a better choice for the technically challenged, but it also makes a good deal less power.
1KZTE Specs: 96kW@3600; 343Nm@2000
Willy Mammoth
Quote1KZTE Specs: 96kW@3600; 343Nm@2000
:dunno: :headscratch:
HP / flbs that I understand. kilowhat? must be how much it takes to kill a newton.  NM must be one of those new fangled atomic meter thingy mo bobs.
  :slap: computer controled injection, only till you let the smoke out.  :thumbdown:
the 1kzt  i believe was a   mechanical injection
but you already have the bell for the td27
gabriul
Quote from: Willy Mammoth on May 07, 2006, 05:10:25 AM
Doh, It has to go on the exhaust side.  :outtahere:
you can route your exhaust to either side with some ceramic tape and a good mandrel bender.
Willy Mammoth
Look what the men in brown brought today.
Duffil
that looks like a schrader valve on there. You inflate it and it holds the bead that way?? :dunno: what's the straps for?
Willy Mammoth
Quote from: Duffil on May 10, 2006, 07:01:26 PM
That creates a chanel for the air to go around the inner liner to the tire from the valve steam.
InstaGator
Damn the men in brown! Can't they get it right? That was supposed to be delivered here! Damn them!! Maybe Fed Ex will slip.. I mean get it right next time  :eyebrow: Cool deal, let me know how mounting and balancing goes.
Lator....
Nissan's need Marlin too. Won't you help?
cancel
check out www.toyotadieselmadness.com for more on the toyota diesels like the K.
unclejpl4x4
ya!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Lady Di
OK, installing the beadlocks.
First he sucked the tire flat with his HVAC vacuum pump to break the bead. Then he had to find a way to secure it. Fortunatly we have stud holes in the garage floor to secure the bender in place.
The rest was cake! (6+ hours worth of cake!) I'll let him explain the process, here are the pics
After he did the first one, he sucked the tire down again with the vacuum pump so it would be lighter to put it back on the Mammoth.  :disturbed:
unclejpl4x4
Lady Di
The swamper donut on the mammoth! :haha:
More install pics  :biggthumpup:
Lady Di
#1465
Glen, it was a piece of cake with the vacuum pump, he sucked it down flat and just had to coax the bead a bit to get it to pop.
I remember him doing the tires years ago with a huge sledge hammer and 2x4, what a chore!!
Anyhoo...
He moved the valve stem location from the outside edge where it could get knocked off by a rouge rock. Hopefully the hardware he sealed the orignal valve stem hole with will hold.
Now Mark is :down: cause he has all this cool :bling: but nobody can see it!
They didn't even give us stickers! ( :turtle: Y :turtle: )
Geno
Looking nice, cant wait to see it in action again.
OFRD_GRL – as much as i appreciate strip clubs, i could never date a chic. they are all flopin crazy.
FYI running over the tire right at the edge of the rim with a heavy vehicle like a box truck (hint, hint) or even a Samurai (just takes several passes) will unseat the beads.  :yesnod:
Just make sure to let the air out by removing the valve core and leave it out while unseating the bead.  :disturbed:
InstaGator
Could the staun valve stem have been placed outside of the center section or does it have to go inside? I only ask becuase won't it be close to hitting the brakes? Looks cool, that would be a nice space saving idea for carrying a spare.
Lator....
Willy Mammoth
Quote from: InstaGator on May 13, 2006, 08:41:02 PM
Lator....
It depends on where the valve is in the tube. It has to be put where it doesn't pull on the stem.
