Making Of The Willy Mammoth
Started by Willy Mammoth, November 18, 2004, 08:06:16 PM
InstaGator
Hey Mark, where do you get your raw materals? I been gong to a local welding shop but I am sure I can get a better price elsewhere. Thanks.
Lator.....
Nissan's need Marlin too. Won't you help?
blackwolf00
MORE POWER !!! ::gunts:: Tim "The Toolman" Taylor  :respect: :rofl:
They invade our space, and we fall back. They assimilate entire worlds, and we fall back. Not again. The line must be drawn here! This far, no further! And I will make them pay for what they've done!
Picard about the Borg.
Lady Di
Quote from: InstaGator on May 01, 2006, 08:13:22 PM
Lator.....
He gets them at Alro, Mike. There is one in Longwood right off of 17-92 just N. of 434.
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
blackwolf00
Willy Mammoth
Quote from: 79Coyotefrg on May 02, 2006, 06:05:35 PM
:sofa:
:worthless:
Work has started on the new pulley.
After finding a 41mm socket to get the front crankshaft nut off, the pulley just pulled off by hand.
I chucked it up on the lathe and turned the front groove off and made s shoulder to center the new pulley.
Willy Mammoth
Next I had to cut off a 1" disk from the piece I bought yesterday.
That only took an hour to get through.
Willy Mammoth
Then I found it was too big to grab with the outside jaws on the lathe. I had to drill the center out on the mill and then bore the hole to fit the center on the pulley.
Willy Mammoth
After fitting it to the pulley, I put it on the lathe and trued it up.
Tomorrow I will recess it to fit farther over the pulley and drill for the bolts to hold it on.
Then comes the groove for the belt.
unclejpl4x4
wow  dam      nice   :drool:   great job mark.......
so can you make me a goblet  a :king: needs a goblet 2 drink :beer: out of.
So how are the 2 pullies gona  mount 2 echother ?   3 bolts in the center ?
Willy Mammoth
#1390
Quote from: unclejpl4x4 on May 02, 2006, 06:50:53 PM
There is going to be at least (6) 6mm 1.0 bolts holding them together. You will see later if I can get back on it tomorrow.
skipnrocks
Hello,  I have a couple of questions for ya.
What wheel base are ya running, and whats your trackwidth?
What sort of flex did you get on the ramp?
And do you wanna come stretch my tub for my jeep?
:therethere:
Thanks
WillyNilly
WILLYNILLY
RockSlayer
Did you make a new frame, or stretch what you had? I am looking to stretch mine 20 inches. I am tossed between the Matkin's frame, or building it myself out of 2" tubing.
Willy Mammoth
Quote from: skipnrocks on May 03, 2006, 10:14:32 AM
:therethere:
Thanks
WillyNilly
WB = 100"
Track is same as mini truck with 1.25" spacers and offset wheels.
I can get between 24" to 30" under one wheel (for now).
No, but I could make the needed panels you would need to fill in the gaps.
Willy Mammoth
Quote from: RockSlayer on May 03, 2006, 10:25:39 AM
I did build the frame from scratch, it is way back in the first few pages. It is 2x4 11 gauge sq tube and 2x3 11 gauge sq tube.
Willy Mammoth
Ok just got in from slaving away in the garage and things are taking shape.
Willy Mammoth
Following what Reklund said before, I found myself making things so I could make things.
I had to make bushings and attachments for the pulley to mount on the rotorary table so I could drill the holes in perfect circle and the proper spacing.
Willy Mammoth
Here is the almost finished product.
All that is left is to cut the V groove and reinstall.
reklund5
Mark-
Looks GREAT!!!!  That should really help that blower cram some air into the engine!
It'd prolly be on the Jeep and operational if you didn't have to make stuff to make stuff....but thats half the fun of these projects!
Once Again, GOOD JOB  :beerchug:
Ryan
gabriul
Amazing work Mark.
Now all i need is my Mill and garage. :)
Inspiring work.
Questions for ya, is there a harmonic balancer on your diesel? Also why so few ponies on the rig? it would be pretty cool to have a nice Cummins or something dropped in there...of course, then the suspension would be whammo. But, it'd be sweetness.
unclejpl4x4
looking good mark :wave: from the other side of the world  im in cali !!!!!1
Willy Mammoth
#1402
QuoteQuestions for ya, is there a harmonic balancer on your diesel? Also why so few ponies on the rig? it would be pretty cool to have a nice Cummins or something dropped in there...of course, then the suspension would be whammo. But, it'd be sweetness.
No harmonic ballancer as in a rubber ring in the front pulley.
There isn't much for choices in a small 4cyl diesel and this is what I have to work with at the moment.
That would be nice to have all that power, but that would only cause things to brake and would be way too much weight. This engine is half the weight of the cummins and is fine off road.
I will be happy with a little faster acceleration and the ability to get up to hwy speed without having a line form behind me.
Lady Di
The new frame build starts about here http://board.marlincrawler.com/index.php?topic=6472.msg78662#msg78662
Quote from: unclejpl4x4 on May 03, 2006, 11:32:32 PM
:wave:  Hey UncJ, can you hear me now? Glad to see you're able to keep in touch. Don't forget :snapshot:
skipnrocks
Hey,  So I have to ask you,  because of your impressive skills,  why did you go with leaf suspension rather than a coil,  or air :dunno:.  Seems like you could have whipped up something pretty professional looking in an hour or so.   :flamer:
WILLYNILLY
i believe he did it that way for ease of repair
skipnrocks
Thats true,  they are fairely simple and easy to repair,  but this man has skills like nobody i have ever seen before.  He could have widdled that jeep out of a solid piece of aluminum if he wanted.  I have never been more impressed by any other project,  most people do a little then hire someone else to do the rest.  Anyways,  I am sure your right!
WILLYNILLY
Lady Di
Quote from: 79Coyotefrg on May 04, 2006, 08:07:18 PM
ding ding ding we have a weiner.  :king:  Not that he hasn't thought about other options, but there are/were more pressing things to be concerned about as it was being built.
Not that things won't change there either.
Quote from: skipnrocks on May 04, 2006, 08:59:14 PM
He would have whittled it out of styrofoam and then cast it out of aluminum if he could have melted enough on the grill.   :yesnod:
:rofl:
Quote from: MrsWillyMammoth on May 05, 2006, 04:37:51 AM
:rofl:
Well if he got about six or seven grills and had a bbq for your old club (I hear they like bbq's) then had them tend each grill as the aluminum melted and poured one fender at a time............
....... I think he should start etching a wooly mammoth's head on his creations like Marlin's turtle. :gap:
Willy Mammoth
#1409
I am all excited now, I just took it out for a quick test drive and it is showing potential.
It is now blowing 12 psi and likes to accelerate in high gear.
Here is the last pictures of the pulley before I put up the video of the test drive.
And one of the mess I made of the rocks in the front of the house doing a little burn out before putting it in the garage. :disturbed:
