Making Of The Willy Mammoth
Started by Willy Mammoth, November 18, 2004, 08:06:16 PM
0 Members and 37 Guests are viewing this topic.
Personally I keep looking for the little elves, I know they are there somewhere. I carefully check every picture you guys post to see if one didn't get out of the way when you snapped the picture.
He must have some little helper's.
unclejpl4x4
LoL it's the garden gnomes i tell you
Shamb
post up your experiances with those internal beadlocks, im curious to see how well they work under pressure. Havn't heard to much hype about them yet.
Btw nice work  :thumbs:
:sofa:  got any pics of progress??
Lady Di
#1354
OK, here are some progress pics. Mark got the supercharger on there, plugged up the oil hole, filled some oil in it,  then redneck engineered a temp hose on it.    :o
Kids don't try this at home, Mark is a crazed trained professional!
He'll have some vid a more of a writeup on it later.
And RS, I have NO idea what you are talking about!!  :whistle:
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
unclejpl4x4
nice
  whats the flat plate for ? oil  and if so  did U make pasagges for the berrings  or is the whole casting full of oil?
Lady Di
that's a bracket UncJ, it does kinda look a pipe going into it.
unclejpl4x4
:smack:  ya i need a :beer: I see it now     from the angle i looks like a hose with a nipple.
It did not even register in the pic above it.
maybe a size bigger pully, to step it up a notch
unclejpl4x4
I do have a ? tho  whats he using 2 lube the barrings with.
i'll bet he runs a oil line to one end  under pressure with a return line from the other end, remember the supercharger itself needs oil too  unc
Lady Di
The in the supercharger? He put oil in it after temporarily plugging the oil line hole.
Willy Mammoth
The bearings in the SC are lubed by engine oil (when I get to it) and the front bearing in the nose cone is self lubed, like an idler bearing.
As far as pullies, I can't go any smaller on the SC so I will have to take the ballancer off and machine the stock grove off and make a center shoulder, drill and tap bolt holes so I can make a larger pully to bolt on.
The pullies are 2" and 4". I think I am going to make a 7" pully for the crank and see what happens.
unclejpl4x4
dam  thats a loud moter.      sweet tho
has it always blown black smoke ?
I know your nabors love U
Willy Mammoth
Quote from: unclejpl4x4 on April 30, 2006, 04:04:56 PM
It was always loud and it only blows black smoke cause it is getting more fuel and not enough air.
I turned the fuel rate up a while back which makes it smoke. Now It needs more air.
Quote from: Rocksurfer on April 30, 2006, 04:13:14 PM
So how much more power ???
Some, but it only blows 5 psi at redline or more  :yikes:
I need to play with the pullies to get more boost at lower rpm. Here comes some more custom machine work. :_order: more on that later.
unclejpl4x4
ya 5 psi at redline is not a lot.
InstaGator
So what is that thing doing for your top end? Looks like that thing has some grunt to it now. I've been meaning to ask, what do the OJC guys say about the Nissan power plant motivating your Jeep?
Lator.....
Nissan's need Marlin too. Won't you help?
Willy Mammoth
Quote from: 79Coyotefrg on April 30, 2006, 06:42:16 PM
yea  we need 5psi  at 1500
5 psi @1500 would be ok so long as it comes up to 15psi@ 2000 and 25psi by 3000.
Quote from: InstaGator on April 30, 2006, 07:38:01 PM
Lator.....
So far it seems a little quicker through the revs, but doesn't show any boost on the gauge driving it. Can't stay at redlline long for fear of having a rod come loose.
I don't think the rev limiter is working like this or it is just now getting up to it's setting.
The engine is rated for 65hp @ 4000 rpm and I bet it is turning close to 5000 now.
The TOJC group thinks it is a locomotive.  :yupyup:
yea  you def need a different pully set up,  yea,  5 at 1500, 10 at 2000,
4000 about 30psi would be good
Quote from: Willy Mammoth on April 30, 2006, 08:12:27 PM
Duffil
I wanna know, what work does the Great Green Gazoo do for ya? :haha:
Willy Mammoth
Quote from: Duffil on April 30, 2006, 09:14:48 PM
:headscratch:
I picked up the new lower pully today.  :yupyup:
8" x 4" disk of aluminum.
*FFC*
Quote from: Willy Mammoth on May 01, 2006, 06:05:29 PM
:headscratch:
:eyebrow:
Lady Di
:yikes:  Oh no!! He didn't disappear in time!!
IronClad
:headscratch:
how much did that run you?  i need to buy a chunk of aluminum  to machine a dual tranny adapter out of. and it will be roughly around that size but in rectangle or square
Annihilation  Fabrication
Do you need a Hammer?
Willy Mammoth
Quote from: IronClad on May 01, 2006, 06:16:11 PM
That's about $48 worth of aluminum clasified as usable drop.
