A New Whatever - MCR14 Break in.
Started by Wermz84, May 07, 2007, 10:32:25 PM
Wermz84
#360
This is another block I already had.
Old and busted.
check out the grooves in the #2 and 4 cylinders.
NASTY!
I like to Drive!
Wermz84
Quote from: 70 Cam Guy on February 13, 2008, 11:42:26 PM
Can you pass smog with that SDS fuel injection here in CA?  I don't mean to pour salt on your cheerios but it's something to keep in mind around here if you'll be driving to the trails and back or using it to scare the hippies down there  :gap:
No.  I do not think so but thank you.      I like that "salt in your cheerios"  funny.
good times scaring hippies!   :gap:
I like to Drive!
Wermz84
#362
Fesh and Like new.  .030 over new!  :gap:
New pistons, rings, rods, and all bearings!
So far.  total investment parts and labor.  $1,000.
more to come later.   :D
I like to Drive!
you may be able to run the efi and not let anyone know about it.... im sure running efi will run cleaner than the carb did anyways....
Quote from: jimbo74 on February 13, 2008, 11:50:12 PM
I think the smog tech will notice.
damn that sucks it crapped out.... but it looks like youll have a much better powerplant in that beast.
ahhh i love not living in a Smogged state... the advantages... :eyebrow:
Tallchevy
I was checking out the SDS website. I think you would be better off & money ahead getting a 22RE or going back with the carb rather than adding the SDS  :twocents:
87 4Runner redo
Wermz84
Quote from: ImaHoToy87 on February 14, 2008, 12:17:39 AM
thanks.  and your Lucky.  I'm thinking about moving.  not sure though.
Quote from: Tallchevy350 on February 14, 2008, 12:30:31 AM
Why do you think its not that good tallchevy?  I'm tired of it dying on steep angles and all the other problems with carb.
I like to Drive!
Tallchevy
I know you live in an area you have to smog your truck. It does say it's 50 state or california state legal. It says to check your local laws but it also says that it is for off-road use only. You have to drill your manifold to use there injector rail(from what I read). Just sounds like to much to go through when you can buy a 22RE or the 2.7 & be legal  :twocents:
Taken from there site
If you can't use the factory carburetor and manifold or if it is a really crappy design, you may have to fabricate the entire manifold from scratch. On inline 4 cylinders, this is some work but not too hard. Runners can be made from steel or aluminum tubing and the plenum from a larger piece of tubing of around 4 inches in diameter. A throttle body from any EFI car can be attached to the plenum and a flange to mount to the head is made from plate stock. All of these pieces can be jigged to a scrap head and TIG welded to form a good flowing, lightweight manifold. Check out the Tech article on building manifolds on the Tech links and Aircraft Page for more ideas and photos.
87 4Runner redo
Quote from: Wermz84 on February 14, 2008, 12:52:23 AM
it has its disadvantaged too.
only vehicle regs here (on trucks and SUVs)
is Mud flaps, fender flares, and no Full Hydro.
otherwise just about all else is legal.
Tallchevy
Get the early 22RE from a 84 & older Celica. Those are the same as the 22R in the trucks if I remember correct.
87 4Runner redo
i thought the 22RE from the Celica and the 4x4, were two different motors...
different intakes and comp ratios.
Tallchevy
Quote from: ImaHoToy87 on February 14, 2008, 01:18:15 AM
I'm not sure but here's a link that might help. I'll have to go back & read it myself.
http://www.babcox.com/editorial/ar/ar400108.htm
87 4Runner redo
whats wrong with your current carb setup? you mentione it dies on steep angles, i forget how to do it, but there is some modicication you can do to the stock carb that gets rid of that issue
also, from what i have heard, the aisin carbs on the toyotas are actually really good as far as carbs go, you just need to tune it a little bit
Wermz84
Quote from: Tallchevy350 on February 14, 2008, 01:09:57 AM
this is good info.  thanks.  I did forget to mention that I have already picked up the Manifold, plenum fuel rail, and a couple of other stuff from an 86 efi yota.  And I checked my 84 head.  its the later style so it will bolt up.  :crossed:
I like to Drive!
Wermz84
Quote from: ImaHoToy87 on February 14, 2008, 01:13:46 AM
doesn't sound to bad.   :yupyup:
Quote from: jimbo74 on February 14, 2008, 01:40:31 AM
Nothing wrong with it, it runs Great, except slightly less power at altidude, and dying on off angles.  I Want EFI!
I like to Drive!
Tallchevy
87 4Runner redo
Wermz84
I like to Drive!
Tallchevy
Quote from: Wermz84 on February 14, 2008, 09:31:34 AM
Thanks for the good points.  :thumbs:
we need to go to HH..  :yesnod:
I went on my last wheeling trip last Sunday with the white 4Runner. I got another 4Runner that I'm starting to build. I might be ready when you get your engine done  :crossed: We will hit the trail then   :yesnod:
87 4Runner redo
Quote from: Wermz84 on February 14, 2008, 08:31:04 AM
its actually kind of nice.
I think Montana is the same.
man we have Montaners over here on a daily basis.. i sware all they drive is lifted toyotas.
youll appreciate EFI for that... but its a PITA to work on imo.
but easier then the 3VZE.
Duffil
just remember, when you fire it the first time, you need to pour sandblasting sand in the intake to get the rings to seat properly. failure to do this will make it burn oil really bad.
:gap:
If I were you, I'd go with stock EFI. :twocents:
MiniSimp
unclejpl4x4
Quote from: Duffil on February 14, 2008, 01:59:22 PM
SAY WHAT! :yikes:
MiniSimp
MiniSimp
Quote from: ImaHoToy87 on February 14, 2008, 02:36:26 PM
im still flabbergasted by the whole sand thing.
The sand rubs out any inperfections in the milling process. It's kinda like redneck blueprinting.
gotcha.
still weird..... i mean simply think about it.... sand in your engine :yikes:
Wermz84
:gap:
:funny:    :slap:
I will put no sand into all of my hard work.   Metal fillings!   haha.
Quote from: MiniSimp on February 14, 2008, 02:00:43 PM
Done yet?
Better get that thing runnin by April!
I'm working on it!   :gap:
I like to Drive!
Wermz84
Just got off the phone with a well known local maching shop for the head.  Not half as much as I thought it was going to cost.     Looks like I better decide and order my cam.  :yesnod:
I like to Drive!
