The Official 3RZ Knowledge and Database Thread
Started by BigMike, January 03, 2006, 08:44:17 AM
0 Members and 32 Guests are viewing this topic.
D-nAsTy-MaX
Quote from: SFD4x4 on April 09, 2011, 11:29:11 PM
EVAP
I know what vacuum lines you are talking about.  I will take some pictures tomorrow morning when I get off of work.
hey guys i've read over this numerous times but not seen much info. on my issue. i used a 96' taco 2.7l 3rz 5speed 4wd taco trucks engine, cab, rear axle, and taco gas tank/lines ect... put it all on my 84' pickup chassis! engine is distributor style. i replaced cracked cast manifold with later style oem mini tube header, i did hook up 02 sensors on exhaust spaced apart correctly though there is no cat only a muffler. right after swap truck was overheating(only overheating no tick/rattle) so i ordered cometic hg arp headstuds oem thermostat, ect.... did that job, while doing it replaced numerous gaskets fuel filter ect... did the works, spent forever getting it timed in(nightmare). well gotit to stop overheating but not for long then this curent issue started. sidenot: when swapping everything over my guy pulled the ac/heat stuff because i chose to not need it. in that process a lot of random vacuum stuff was pulled and some left... i think this could be what is causing my truck not to run right, current issue symptoms: (truck starts idles normal even would drive normal but this is only for about 5 mins then idle drops major loss of power gets ticking rattle sort of sound, after about 10mins of this will begin to overheat(pushes coolant out overflow) then starts trying to easily stall out and die and once it does it wont start back for few mins acts like dead battery at that point... header gets chalky white sparkplugs are white chalky at tips)
the evap canister box in above pic is off the truck though most the sensors(vps, vsv for vps, vsv for evap) on/around evap box were left on truck plugged in just not hooked up still.... currently have valvecover off everything looks fine still, timing still looks correct but dam these engines are tough to time.... pulled oilfilter going to cut it apart see if any metal is in there rule out major issue. going to hook up scanner and timing light ect... next few days check all that.
any info on what could be my issue? how tofix?  and if i just need to unplug remove and cap off all the left over vacuum stuff, or collect parts and reinstall it?
thanks a ton!
kevin
TacoRunner
So I've got the 95.5 model year tacoma engine, it has a distruibutor. Which can not be timed. What I mean by that is, its computer controled. it only allows you to move it so much. You dont need to mess with that thing at all. Personnaly I think you should put everything back to stock and work your way through the codes one at a time. You may have a cracked head.
www.4WHEELUNDERGROUND.com
[email protected]
D-nAsTy-MaX
Quote from: TacoRunner on September 21, 2011, 07:42:31 AM
yeah i agree i would believe me if i had stock oem parts.... head was checked when it was decked for the cometic headgasket.... dont see how it could be cracked now havent even drove it because its been doing this since i did the headgasket... i have not used a computer to time it just lined up cams n timing chain as manual says and then moved distributor gear one tooth at a time. going to use timing light tomorrow and scantool to check things out... oil and oilfilter checked out clean! pulled rest of evap stuff that was left on today although the line coming from tank back to what woulda been going into evap box is still on and just open at evap box connection end...
TacoRunner
As for the timing, I tried messing with mine and didnt' like it. It was years ago that did but if it runs then I'd say you're fine with that. As for the head, it may not be a crack but the head could be warpped.
[email protected]
D-nAsTy-MaX
that may be it was checked when decked but i dont know that they checked for being warped....
D-nAsTy-MaX
well turns out my balance shaft bearings let go all but the very front one had let go ticking sound was from balance shaft bouncing around... bearings were in pan beat to hell... motor was fighting locking down which caused the loss of power and overheating all that money waisted on doin topend rebuild with arp's and all new oem toyota parts.... just to need bottomend rebuilt now.... good new is i have a extremely clean like new 40k mile distibutorless 2.7liter 3rz coilpack style motor just need harness and computer....
D-nAsTy-MaX
can anyone tell me if there is a balance shaft delete kit for the coilpack style 2.7liter? or if this issue has been solved in the later design?? seems to be alot of 2.7ls out there with bad balance shafts searching the net.
R.DesJardin
A choice of fuel tanks.
So doing a 2RZ swap and I have the entire wiring harness, fuel system including fuel tank from the donor truck, this is all goin in my '82.
So I obviously need an EFI type tank so after pulling my '82 tank and comparing it to the 22re tank and the 2RZ Taco tank I'm looking at which will be the easier swap.
Using the:
RE tank will allow direct bolt in from the looks of it, then a modified fill tube and connecting the wiring to the Taco harness.
RZ tank will allow use of the Taco wiring and fuel lines, and is too long to fit.
So that leaves using the RE tank splicing in the RZ wiring pigtails. So now all I need to do is:
1: Figure out which wires are for what. That shouldn't be too difficult.
2: Figure out if the RE fuel sender will work with a Taco fuel gauge.
3: Bolts right up!?!?
Pics for the readers pleasure.
From to top to bottom, R-RE-RZ
And another view-from right to left RZ-RE-R
R.DesJardin
slabcs
Quote from: R.DesJardin on September 23, 2011, 05:34:54 PM
1. Easy.
2. Mine does.
3. Yep.
Relentless
R.DesJardin
#639
Or maybe this-
Put tank on left side of truck, build new mounts, make hole in box for filler, run the Taco fuel lines down the left side away from the exhaust and to the correct side of the motor. Run exhaust down right side and not worry about a crossover pipe clearing everything. :thumbs:
R.DesJardin
R.DesJardin
Quote from: R.DesJardin on September 23, 2011, 08:24:21 PM
Or maybe this-
I did more measuring today, even laid the Taco fuel lines in place. Yes, this is the way I'm going to do it.
R.DesJardin
R.DesJardin
I have a 96 Taco 2RZ, it has a round steel EVAP canister. Where does the vent line coming out of the bottom of the canister go?
R.DesJardin
Seeds
Quote from: R.DesJardin on September 24, 2011, 09:17:49 PM
If you are in CA call the smog referee first. So many nit picky laws.
Romans 12:2
R.DesJardin
Quote from: Seeds on October 01, 2011, 10:28:46 PM
Not in CA, never lived there never plan to. No smog police here where I live in the middle of nowhere.
R.DesJardin
gnob
Quote from: R.DesJardin on October 01, 2011, 09:49:07 PM
no where, it vents to atmosphere.
hold this. . .
HogCanyonHopper
Took my 3RZ swap to the ref. It failed in three areas: no brake signal to ECU (fixed), gas cap (replaced), and then the tricky one.....EVAP  monitor wont run. Should I replace all the hoses from tank to air box? Some of the lines are old. Make sure they are all clamped well to mitigate leaks. There is not a single DTC showing up on my scantool, no pending codes nothing......but the EVAP monitor wont run. If I can get that to work, I'll get my sticker :willynilly: Anybody got any suggestions?
R.DesJardin
Intake Air Temp Probe/sensor, how did you guys all mount yours? The pics in the early build threads are missing?
This is how my intake is setup.
R.DesJardin
rcbro
#647
NVM
gnob
hold this. . .
4rnnr33
Awesome thread Ive spent hours trying to read through everything. Im getting ready to swap a 3rz into my 94 pickup and I have a few questions about the gas tanks. 1. Does anyone know if the 3.4 tacos and 3rz tacos use the same tank 00-04 with the 4 lines. and 2. Does anyone have any pics of an EFI tank modified with the taco fuel pump and evap stuff? Thanks
ikaria
What would be the best transmission to throw into a 1st gen pickup behind a swaped in 3rz?
Here's some of what I've got so far:
1. W56 seems like a very popular option with an easy hook up to the 3RZ
2. R151F/150 sound like strong, easy fits with Marlin's bell housing
Pro's and con's? Is there a lot of cabin floor moding involved in these?
JustDSM
I might have missed it, but I'm looking for a picture that illustrates where the 10K ohm resistor is placed on the tach circuit. I'm swapping in a 3RZ into a 1st Gen (1983). The 3RZ is a '97 Twin Coil motor if that's of any importance.
bsi yota
 This may have been covered but Im not about to read through 22 pages of 3rz stuff.
Im looking for a custom wiring harness for the 3rz like offroad solutions used to make.
anything???
91 Xcab
3RZ w/ 2wd trans
Total Chaos Gen III w/ king c/o's, 62" deavers w/ FOA triple bys
tundra axle 5.29
35" KM2
R.DesJardin
Quote from: bsi yota on November 09, 2011, 10:38:36 AM
anything???
http://www.toyonlyswaps.com/
R.DesJardin
ohioyota
Finally finished my 3rz swap into my 85 4runner. I went to start it tonight and the starter is binding. The motor is out of a 98 taco and the bell housing came with it. The starter is a reman from o'reily's. It bolts on fine but when I turn the ignition it turns a few times and makes a slapping sound like its not fully engaging the fly wheel then binds up.
I removed it and replaced it twice, trying to line it up but same thing happened each time.
Has anyone had this happen to them, any suggestions?
rcbro
Mike who do we got to pay to get these pictures back online lol? thanks man!
rcbro
Hey Guys,
Finally got the funds to do my swap, so i'm ordering parts throughout the week.
I have a 2001 3rz with W59 bellhousing that I plan to bolt a W56 too. I've read there was some confusion on which clutch, fork, flywheel and throwout bearing to use. Whats the verdict on which I need to order? Thanks for your help!
I have the stock 80 radiator thats still in great shape. Is the 3 core needed/suggested or can I get away with the stock radiator. How about a electric fan? Any favorites?
smacaulay
Clutch, fork, flywheel, and bearings should all be for the 3RZ.  I've got a 3 core for the 3VZ w/ no shroud and mechanical fan...no problems w/ heat crawling on hot days.
smacaulay
Quote from: ohioyota on December 15, 2011, 09:14:53 PM
Was your 3rz from an auto?  There is a spacer (~3/8" thick) for the flex plate I didn't remove before installing the flywheel, which caused interference between the bell housing and the flywheel not allowing it to crank.
ohioyota
The 3rz is from a manual trans vehicle. The flywheel and clutch were attached when I picked it up.
