0 Members and 23 Guests are viewing this topic.
On my 98 Tacoma 3RZ engine the front sensor wires are White/Red - 12V For HeaterBrown - GroundRed/Black -Computer grounded for heaterWhite - Signal to computerThe rear sensor wires areWhite/Red - 12V For HeaterBrown - GroundRed/White -Computer grounded for heaterBlack - Signal to computer
Someone REALLY needs to bring a conversion harness to maket again now that ORS is gone. These swaps have so much to offer, but some of us are not vey electrically inclined (aka... me). Engine mounts seems to be easy, especially the ones that were made for Bevin's conversion.The Transmission conversion bellhousing is convered by marlin.The exhaust can be done by a local exhaust shop.EFI tanks and fuel pumps are pretty common and inexpensive.The oil pan poses an issue with stock height IFS, but it can be it can be modified to work.Its just the wiring that scares me.
Hey does anyone have any info on swapping a 97 taco dash into a first gen 4runner??I have heard that the entire dash fits with little modification, and simplifies the 3rz swap wiring.
I used the w56 clutch fork with my 3rz swap - the biggest issue is the throughout bearing when going this route. I think the bearing I used was from a 3rd gen pickup but can't remember for sure. I just know that the one that came with my w56 wouldn't work - I think it was too short and the w59 bearing from a tacoma had too big of a center bore - it looked about 3mm too big. My clutch grabs as soon as I let the peddle off the floor (and I've adjusted it to do the opposite) so I think when it comes time to pull the trans, I will replace the clutch fork with a w59 setup.
i had the same issue, but i just made a longer push rod for the slave cylinder
Hmm... that sounds easy enough. I wish I still had access to a lathe though.
its way simplier than that, just take a 12mm yota bolt that is 1/2" longer than the stock slave rod and round the ends off with a grinder.
The auto ecu works and runs fine it just throws on the check engine light. With the manuel ecu u will also need to hook up the speed sensor to your tcase otherwise it will throw a code too.
Hey I have a question, I am in the process of putting a 3rz in a 95 4runner. I want to do hydro assist, am I going to have to get a different power steering pump? Or is their a mod to make this one work?
Started by cruzila « 1 2 ... 32 33 » Rig Gallery
Started by yotaboy79 « 1 2 ... 32 33 » Chit Chat Camp
Started by BLACKDOG « 1 2 ... 11 12 » Chit Chat Camp
Started by Willy Mammoth « 1 2 3 4 5 » Chit Chat Camp
Started by Rocksurfer Chit Chat Camp
