OVRAROK. My 87 4runner
Started by OVRAROK, July 11, 2014, 04:04:18 PM
0 Members and 32 Guests are viewing this topic.
redneckcustoms13
What did they do? Please tell me they cure the angle issue and the t case mount is no longer in a bind.
01 double cab hunting truck
06 tacoma street truck
Quote from: redneckcustoms13 on July 13, 2017, 07:27:05 AM
Yes, it looks much better at the t case mounts
Sent from my SM-G955U using Tapatalk
Had some time yesterday to finish making something to hold my cowboy wok that I made.
Dude! You could totally sew me some saddle bags for my bike!
redneckcustoms13
Quote from: OVRAROK on July 15, 2017, 01:50:36 PM
If you put an angle finder across the power steering reservoir is it level now?
Quote from: redneckcustoms13 on July 17, 2017, 07:02:47 AM
My driveway is slightly tilted, looks pretty flat
My truck started making a clunking noise 2 weeks ago, this morning I tore it apart, here's the results, time for 529s
SqWADoosh
Where do you think this happened?
Quote from: SqWADoosh on August 03, 2017, 10:59:09 AM
Not quite sure. Haven't been anywhere crazy in the last 2 weeks, however, I did use dynamat equivalent in rear quarter panels, entire rear area and trans tunnel. Started noticing noise when I pulled hard top, and installed half doors. It quite well have been making noise for a longer period of time
SqWADoosh
Quote from: OVRAROK on August 03, 2017, 11:11:30 AM
Ahhhh double edged sword that dynamat eh?
helipilot77
That's a significant amount of pitting on the gear teath faces.
Quote from: helipilot77 on August 03, 2017, 11:57:04 AM
It's on approx 7 teeth  middle 2 of 7 are the worst, sides gradually gets worse going to those 2 middle ones
While My truck is waiting, I drilled and tapped 28 holes in my summer tailgate in order to have access to lights, and latched
May as well do bearings
megaphoneman
you ever use rivnuts before dave?
Quote from: megaphoneman on August 08, 2017, 08:00:12 PM
Yeah, I just remember I have a whole kit, lol.
While im waiting on gears, I made this
BigRonDog
Quote from: OVRAROK on August 09, 2017, 11:41:38 AM
Those are great for setting up ring and pinion gears ! I like it
helipilot77
Quote from: helipilot77 on August 09, 2017, 12:15:24 PM
What kind of tap handle is that. I've never seen one before.
It's just a 3/8 ratchet. Made by williams, it's called " palmster"
Finished up, ups dropped off these
megaphoneman
Quote from: OVRAROK on August 08, 2017, 08:30:04 PM
seems like it would hav ebeen quiker then drilling and tapping..
:)bestgen4runner
I don't see the solid pinion spacer?
maybe in the little black box?
I am 1/5th of Perfect Fit
Quote from: :)bestgen4runner on August 09, 2017, 03:10:06 PM
yes, that's it
redneckcustoms13
You'll like those g2 gears Mr Dave. I love mine.  :driving:
Quote from: redneckcustoms13 on August 10, 2017, 06:47:36 AM
What is there to love about one brand over another as long as there isn't a failure?
Quote from: blackdiamond on August 10, 2017, 03:53:44 PM
gear noise
cost
pick one
:therethere:
Spent most the day cleaning work area, trying to be organized. Had to make a few tools. It's all torn down
SierraNevada4STR
What grata would you recommend for a 1988 22re? Looking to start doing stuff to my mostly stock 4Runner.
SierraNevada4STR
Quote from: SierraNevada4STR on August 10, 2017, 07:02:25 PM
Gears*
