OVRAROK. My 87 4runner
0 Members and 21 Guests are viewing this topic.
OVRAROK
My fully pneumatic 3 port switch arrived.
Sent from my SM-G955U using Tapatalk
OVRAROK
Compressor showed up, need to decide on where to install, planning on running -3 line throughout
helipilot77
That appears to be one of the higher output models. I'll be interested to hear what you think of it's performance.
OVRAROK
Quote from: helipilot77 on March 15, 2018, 04:24:47 PM
I will be using this solely for front ARB. I will be eliminating electrical solenoid.
mudmaster
I'm going to be embarrassed to have my rig next to yours.
Time to go wheelin!
OVRAROK
Quote from: mudmaster on March 15, 2018, 04:46:10 PM
Ha, I think it's the other way around
OVRAROK
Installed 130 amp alternator
mudmaster
That should be enough juice.
Time to go wheelin!
redneckcustoms13
Quite a pain in the arss to do on mine. How was yours? I'm still running the modified chilkat brackets. Maybe the tos are better for clearance on that bottom bolt?
01 double cab hunting truck
06 tacoma street truck
OVRAROK
Quote from: redneckcustoms13 on March 23, 2018, 05:14:55 AM
piece of cake, in and out in 5 minutes, There's enough room to get the nut off. just needed to get a shorter belt, because i went with slightly smaller pulley for better amps at idle
OVRAROK
T cases are out. Transmission is next. Working alone this was a better option spitting trans from cases
:)bestgen4runner
Why are we taking the transmission out?
I am 1/5th of Perfect Fit
OVRAROK
Quote from: :)bestgen4runner on March 29, 2018, 10:41:15 PM
New clutch, flywheel. Rear main seal
OVRAROK
Used a 2x4 inside the cab, that with a tie down strap, holding rearward part of trans. I little wiggle on the bellhousing, falls right out. Will reverse procedure going in
redneckcustoms13
I know it sounds dumb. But please change that pilot bearing. When I killed the 1st w56 on my 3rz swap I had about 18k on it. Clutch got warrantied just because but my lazy arss didnt change the pilot bearing because it wasn't that old. Bad idea. I ended up replacing it s few months later.  :hammerhead:
OVRAROK
#1005
I leave no stone unturned. I replaced rear main seal, as well as pilot bearing before installing new MC clutch, along with .026 step on flywheel. Transmission is back in. I used the bread trick to get pilot bearing out. With the help of bestgen4runner I was able to quickly clarify the flywheel torque specs, thanks chris. Tomorrow, I will install t cases.
OVRAROK
Installed my ARB compressor today
OVRAROK
So...., not wanting to buy oem tcase mount I did what most would do, order through Amazon. Bought 2 "Pioneer" brand. None of the holes matched up, go figure. Contacted amazon, they immediately refunded my money, I contacted company that was third party seller on Amazon to ask, what do you want to do about return shipping. Gentleman on the other side of the phone told me to keep them. So then I reached out to a somewhat local 4x4 shop, hoping that some QC would be better, I specifically asked if holes could be checked. Was assured they all where up to standard. Welp..., wouldn't you know it. Wrong again. So after doing my research I settle on another off brand, with great luck. They fit like a charm. I got t cases back in, and have almost 200 miles on new clutch. I was hearing a new strange noise. Ended up being rear leaf spring bushings. Banged out the old metal/rubber/metal bushings, and currently waiting on urethane ones to arrive. While I'm waiting on bushing I decided to make new center console
CrazyYota
The Marlin HAD mount works great. I have two in my 83.
mudmaster
I'm using a MC HD one without any issues.
Time to go wheelin!
AZ Rockit
82 Long bed, 22r with 83 celica EFI, 31s
84 Xtra cab, 22r, Chevy springs, 31s
85 4Runner, 3rz, R151F, 244:1, 37s
85 Long bed, 22re Performance Stage 2 engine, 32s
85 Short bed, 22r
89 4Runner on a 94 truck chassis, just a roller (Montana Runner)
cbeers
Sounds like you've got it sorted.
Wish i knew....i have 2 brand new MC HD mounts i got and won't be needing after all  :therethere:
CB
OVRAROK
Trucks is back on 4 tires.
OVRAROK
Little fender trim
that'd look money.
are those air bumps on your spring plates?
OVRAROK
Quote from: THK Matt on May 10, 2018, 01:55:50 PM
that'd look money.
Rubber. They are temporary, I'm looking into sumo spring for rear
redneckcustoms13
That wheelbase looks killer Dave.  :beerchug:
OVRAROK
Cut rear bumper off, time to trim the heck out of the rear
OVRAROK
1 side tacked
