OVRAROK. My 87 4runner
OVRAROK
Quote from: excabswap on June 21, 2016, 10:32:42 AM
Are you not getting enough torque? What size is your exhaust?
Sent from my LG-H830 using Tapatalk
Since the swap, I feel like it has to get up in rpms to get to that sweet spot .Exhaust pipe is 2 1/4" 16 gauge
OTO Phil
#721
That's pretty small pipe.. are you running an aftermarket cam?
OVRAROK
Quote from: excabswap on June 21, 2016, 10:40:57 AM
2.25" isn't small on a 4 cyl
OTO Phil
I've got a 2.5" from the header back, no cat, flowmeter 40, and it feels a bit restricted.. it's a 22RE with ENGNBLDR's 261 cam and Doug thorley Tri y header though so that might make a difference
SqWADoosh
Quote from: excabswap on June 21, 2016, 11:29:56 AM
Shouldn't feel restricted. Toyota motors love 2 1/4 exhaust so you should have too much flow especially with no cat and a flow 40.
OTO Phil
Quote from: SqWADoosh on June 21, 2016, 11:50:06 AM
Perfect answer. Yotas love 2 1/4" exhaust, so you shouldn't need to install this flange to increase back pressure.
I'm curious what kind of compression you have now..
OVRAROK
I can feel this power in the pedal, before starting swap, it felt great in donor vehicle. the donor had stock giant muffler, I made my own exhaust system, used a muffler my buddy is selling, it may not have enough back pressure, that's the only thing I can think it could be. I also used mandrel bends, which will free it up a tad as well :greengrin:. I figure if it makes it better, great!, if not, I'm out 15 bucks w/gaskets. I'm more curious then anything :headscratch:
emsvitil
Put a cable on it, and you can adjust on the fly........................
  :turtle3:   Page 26 ownage    :turtle3:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OTO Phil
That'd be cool to know. Gonna have to find a dyno and test it
blackdiamond
Quote from: excabswap on June 21, 2016, 03:28:13 PM
:moon: dyno will be what he uses most likely...
your original 22 was rebuilt, not too long ago right? I wonder if the new engine just isn't as as robust as the one you built, and that is the difference you are feeling
redneckcustoms13
A stock 3rz vs a 22re is a major difference. I think what he is feeling is te nature of the 3rz engine. It has torque at low rpm but not the same torque as a 22re. I have had both vehicles still have a few of each. The 3rz doesn't really do much until about 3k, once you reach it there's no doubt it's rolling along then.
01 double cab hunting truck
06 tacoma street truck
Dingman.
He drove my tacoma with a 3rz. So im sure he can somewhat compare it.  Eventhough his is on 35"s and 4.88's but Dave should have a rough comparasion.
HogCanyonHopper
He needs to go 5.29's  :burnout:
redneckcustoms13
My 98 taco with 4.10 and 31s was nothing at all like my 83 with 4.56 and 33s. A friend has a 96 taco with 4.56 and 32s. All different games to be played. None really feel as if they have a dead spot though. Might just need a little more gear dave.
OVRAROK
its more power then I had, for sure.  :driving: I can get 70 mph in 3rd no problem, it pulls 4th gear pretty hard, I have a lot of hills here, so I can definitely feel the difference. its probably just me  :hammerhead:
OVRAROK
Picked up a spare ecu
Sent from my HTC One_M8 using Tapatalk
OTO Phil
Time to send it out for programming?
helipilot77
I bought some thermally conductive epoxy for waterproofing Electronics. I was going to fill up my ECU so it could go swimming. Haven't gotten around to it though.
OTO Phil
you could seal it in a container of baby oil haha
OVRAROK
Quote from: excabswap on June 30, 2016, 09:39:26 AM
who perform this kind of work
Quote from: ovrarok on June 30, 2016, 11:34:39 AM
You might try Holmes Hobbies, I know they epoxy pot RC car electronics.... you can probably also do it yourself with corrosion x
OTO Phil
I think he was talking about sending out his computer for programming. I don't know who does it personally, but megasquirt is a company that makes ECUs for the 22RE
OVRAROK
OVRAROK
decided to pull spark plugs, found #1 and #2 to be finger loose. found a tear in #3 plug wires, looks to go halfway through. ordered some ngk tx67 wires, and picked up 4 plugs from Toyota. got new plugs in, and snugged, waiting on wires  :turtle:
:)bestgen4runner
I know they are expensive but I would have recommended the factory Toyota wires.
I have used the Ngk wires for customers. they fall apart when age gets to them.
The Toyota wires last for almost ever.
I am 1/5th of Perfect Fit
OVRAROK
Quote from: :)bestgen4runner on July 12, 2016, 12:26:50 PM
sounds like what I'm going through,lol
:)bestgen4runner
You personally, LOL or Your old plug wires? :outtahere:
OVRAROK
Quote from: :)bestgen4runner on July 12, 2016, 12:44:13 PM
as a youngster, I treated my body like an amusement park, not a temple, lol. just paying for it now. re: plug wires, motor have bosch wires on there now, #1 wire, is almost broken at metal at plug, #3 has a tear almost halfway through. I'm sure they (ngk) will be better then whats in there now. dealer wanted 101.00 for wires
