OVRAROK. My 87 4runner
0 Members and 22 Guests are viewing this topic.
redneckcustoms13
Don't part with it till yours runs! I learned the hard way and had to go to the junk yard for a few odds and ends
01 double cab hunting truck
06 tacoma street truck
OVRAROK
Quote from: redneckcustoms13 on April 05, 2016, 05:31:54 AM
what did you forget
OVRAROK
Quote from: liveoak on April 05, 2016, 06:47:06 AM
he's right, you should hold onto the donor till the swap's finished.
agreed, ill keep it around until its finished. today I will be pulling bellhousing, clutch master, slave and all lines pertaining to clutch, hard fuel lines from tank to engine bay, exhaust. all wiring, dash cluster.
HogCanyonHopper
chim
As if the Toyota's aren't cool enough I spy a 68 and a 69 Camaro!
redneckcustoms13
That's what I'm screaming. The weber grill is a nice touch too
I forgot the obd plug, throttle cable, and a few other junks
OVRAROK
End of day 2, removed all wiring, from headlights, to taillights, only thing left are hard fuel lines, and power steering hoses, and managed to put it all back together
Sent from my HTC One_M8 using Tapatalk
Nation
OVRAROK
Santa's sleigh must have broke down, some guy in a brown truck dropped this off
OVRAROK
draining fluids. Will pull old, and install new tomorrow
HogCanyonHopper
that is pretty nice looking for old ;)
emsvitil
I own page 17   :cheese:
Quote from: ovrarok on April 06, 2016, 12:56:35 PM
Oil Pan
Dip Stick
Oil Pickup tube / strainer  with gasket
Some bolts for what?
and
a tube thingie ?????
What's the tube thingie?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OVRAROK
Quote from: emsvitil on April 06, 2016, 07:46:04 PM
Oil Pan
Dip Stick
and
on the left of drainer is the block off plate, which requires 4bolts, for front sump oil dipstick tube thingy with rear sump pan, the tube thingy holds my dipstick in a different spot
heck, this motor is going to be in before I get up there :gap:
OVRAROK
More stuff
those are pretty.....
HogCanyonHopper
I have those mounts and pump bracket on my truck. legit  :thumbs:
emsvitil
What's the mount on top for?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
SqWADoosh
Quote from: emsvitil on April 07, 2016, 05:56:03 PM
Its the Chillkat Designs 3rz TC pump bracket.
OVRAROK
So, only things left on list of parts I need, is 17/32 freeze plug, Dorman # 555-007, and high pressure fuel line made to connect from 87 tank to 97 hard fuel lines, only 1 thing on the want list. Mini tube header off 01-04 3rz .I have 3 cast exhaust manifold with no cracks, so I should have some time to obtain oem header .Also need a couple j bend exhaust tubes, mandrel bent of course, to make crossover tube for exhaust
redneckcustoms13
Good luck with the install today. I hope your mounts work.
OVRAROK
Quote from: redneckcustoms13 on April 08, 2016, 07:47:09 AM
do to parts getting here late, I need to paint a few parts. Regarding mounts, I figured I could make a shim if needed. spending the day cleaning up the garage. I get flustered when I cant find a tool. so before I start install, I going to try to organize a bit
1985CRAWLER
Nice work Dave ! Coming along quickly ! I'm sure the thing will be way past done by memorial weekend .
I really liked my chilkat mounts , I was surprised I didn't have to do :pokinit: to them and motor sat perfect , that was using new 22re motor mounts too haha
Btw you have a buyer for your old 22RE yet ? What were you thinking of $ range ?
OVRAROK
#474
Quote from: 1985CRAWLER on April 08, 2016, 10:19:51 AM
id take 1300 for 22re, 16,000 miles, thats from air cleaner to exhaust tip. it has 261 cam, bored TB lc engineering header with 2.25 stainless steel exhaust. includes clutch too. never been abused, doesn't leak a drop of oil. all factory rubber hoses are all new, silicone vacuum lines, 130 amp alternator, was just rebuilt
OVRAROK
Oil Pan
Dip Stick
and
I just wanted to correct myself, the block that goes in the side of the oil pan which takes the 4 bolts, is a deflector for the oil dipstick
HogCanyonHopper
OVRAROK
just ordered my oem mini tube exhaust manifold, part #17141-75080, and gasket# 17173-75020  :yupyup:
Quote from: ovrarok on April 09, 2016, 09:27:44 AM
OVRAROK
Picked up a high pinion diff from dingman, thanks bro
