OVRAROK. My 87 4runner
0 Members and 13 Guests are viewing this topic.
:)bestgen4runner
OK, GIVE ME A BIT AND I WILL BE BACK
I am 1/5th of Perfect Fit
OVRAROK
Quote from: :)bestgen4runner on June 03, 2016, 12:20:27 PM
thanks so much bestgen4runner, its a running
blackdiamond
Quote from: ovrarok on June 03, 2016, 01:26:33 PM
Running as in vroom vroom?
OVRAROK
Quote from: blackdiamond on June 03, 2016, 01:28:29 PM
yeah sir, you tube vid downloading
OVRAROK
so my only issue is no incoming power from 40 amp fuse, I'm thinking since there is nothing on fused side of 80 amp, just pigtail from fused 80 amp to power in at 40 amp. ive been using jumper this whole time trying to diagnose. a big THANKS BRO to bestgen4runner, helipilot, hogcanyonhopper, sqwadoosh, and megaphoneman for any input, help, or just plain moral support
OVRAROK
helipilot77
 :woohoo:
She sounds like a real sweetheart.
helipilot77
helipilot77
Quote from: ovrarok on June 03, 2016, 01:38:50 PM
There should be a heavy gauge white wire coming off the 80A feeding the 40A
OVRAROK
Quote from: helipilot77 on June 03, 2016, 02:02:53 PM
So what was the issue?
no power at 40 amp fuse in engine bay, and 7.5 ignition fuse. since I just learned that there is a piece of exposed metal on front of fuse, while I was patiently waiting(not) for bestgen4runner to give me my next thing to check, I started testing all fuses, before I just looked at them, it looked good but apparently wasn't good, after I found fuse, I put it all back together and she fired.
OVRAROK
Quote from: helipilot77 on June 03, 2016, 02:05:34 PM
there is not, the feed wire going into 40 amp is in original loom, I peeled back original tape a little to check for broken wire, but didn't find any, so do you think I should cut this white wire and attach to empty fused 80 amp circuit, or just tap into wire, I'm just afraid ill lose something else, and there not a lot of room to work right there
OVRAROK
First pic is of empty side of 80 amp, second pic is white wire coming from loom to feed side of 40 amp
Sent from my HTC One_M8 using Tapatalk
:)bestgen4runner
Let me look at mine when I get home.
I would like to recommend a forever fix that you never have to worry about in the future.
Just want to see how mine is then we just reproduce that.
No body knows better than Toyota.
:)bestgen4runner
Any Idea how this problem happened.
this is part of the original vehicle harness that worked fine before. doesn't make sense to me
OVRAROK
Quote from: :)bestgen4runner on June 03, 2016, 03:03:50 PM
I haven't got the slightest clue, ive searched around looking for said missing wire, cant find anything. I'm pretty meticulious about setting parts in piles for each item. all engine stuff in 1 pile, all bellhousing and tranny stuff in another, and so on and so on. I don't know, I'm just dying to go drive it, but ill wait for you to look, thanks again
:)bestgen4runner
What is current set up for alternator?
Your jumper is currently running from what to what?
What happens when jumper is removed?
were you able to get a hold of the guy you got your harness from?
OVRAROK
#677
Quote from: :)bestgen4runner on June 03, 2016, 10:57:58 PM
Stock alternator on 3rz.  high output soon, I'm touching positive on battery to spade going out of of 40 amp . Nothing happens with key off. Turn key to run. Everything on dash comes on . When I remove jumper , nothing lights up on dash, key doesn't do anything
:)bestgen4runner
Wow, You wake up early ovrarok.
I will try to look at mine tonight for you.
:)bestgen4runner
Alright My friend took my truck apart for you.  :turtle:
Here are pictures.
I even took one of the cover so you know what is where from now on.
would you like one of the inside cover? (drivers kick panel fuse block)
look it over and we move forward.
I left it apart in case we need more pictures and or info.  :crossed:
Going fishing in the morning with My two youngest boys so wont be back on until 11 or noon.
SqWADoosh
Quote from: :)bestgen4runner on June 04, 2016, 10:24:17 PM
Here are pictures.
You don't have a 3rz swap though.... :headscratch:
:)bestgen4runner
On the last picture ? You do have those two connectors plugged into the top next to fuses correct?
:)bestgen4runner
Is you relay/ fuse block differant that mine on your 3rz swap trucks?
1985CRAWLER
Hey Dave I'll be down in your area tomorrow, I'll come by and see if I can do anything , when I did my swap I left for the most part my factory 22re fuse box alone besides extending the main power wire but where my no start problem was coming from was my ignition wire / starter relay , my truck had a push button start and the 3rz swap I did did not like that and I had to wire it back to the factory ignition source
1985CRAWLER
Quote from: :)bestgen4runner on June 04, 2016, 10:28:17 PM
Generally speaking they are the same when you use the factory 22re stuff , I'm not sure if Dave put the 3rz fuse box in but I don't think he did
:)bestgen4runner
Based on the pictures he sent me I believe it is the same as mine.
hey dave, haven't noticed this yet, can you compare it to the other truck? the wiring should all be the same or close.....
SqWADoosh
Quote from: :)bestgen4runner on June 04, 2016, 10:34:21 PM
If it is the same then how could the problem be there? As he had a good running truck before the swap?
:)bestgen4runner
That is a question I also have asked?
Does not make sense. We will get to the bottom of it.
OVRAROK
Quote from: jimbo74 on June 04, 2016, 11:08:20 PM
other truck is carbed, so no efi
