OVRAROK. My 87 4runner
0 Members and 44 Guests are viewing this topic.
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Dingman.
You'll be stoked with the high pinion front.  Do an arb if you dont mine spending the extra money.  I LOVED mine!  You have a nice place where you are located.  Ill start moving my stuff in next week.  :gap:
megaphoneman
Dave, wanna do a third member/locker party...i dont have the confidence to install a locker in my third..
OVRAROK
Quote from: megaphoneman on April 11, 2016, 09:20:45 AM
unfortunately I'm saving up for gears and set up kits, I wish I had everything. with your brain, I have a hard time believing you cant do it, your a wizard
OVRAROK
I use vht flame proof primer and ceramic aluminum paint, used a piece of Saran wrap on backside, and used the old gasket to hold in place, used exacto knife to cut off excess
Sent from my HTC One_M8 using Tapatalk
redneckcustoms13
01 double cab hunting truck
06 tacoma street truck
megaphoneman
that looks good
Blaaaahhhhhhhh
OVRAROK
Weather cleared up, took 3 hours to pull
mdtrail-toy
I don't want to alarm you but I think someone stole the hamsters from under your hood :rofl:
megaphoneman
dave what was that cool brake we were looking at?
Blaaaahhhhhhhh
OVRAROK
megaphoneman
thank u! i couldnt remember it.. i get brain farts like that alot. im going to hit them up today.
Blaaaahhhhhhhh
OVRAROK
Quote from: megaphoneman on April 13, 2016, 08:54:36 AM
Blaaaahhhhhhhh
post back your findings, im seriously thinking of going this route.
mudmaster
Quote from: ovrarok on April 13, 2016, 08:58:26 AM
Yes, this is intriguing.
Time to go wheelin!
megaphoneman
Havent heard from them yet...but from what i have seen so far its a nogo.
OVRAROK
Quote from: megaphoneman on April 14, 2016, 10:36:17 AM
dislike, I think we can make ourselves.
redneckcustoms13
Ok dave, enough about brakes. Does it run yet?
OVRAROK
Quote from: redneckcustoms13 on April 15, 2016, 07:10:23 AM
waiting on a few parts to arrive
redneckcustoms13
Who's black 2nd gen with the hilift in the bedside do I spy in all the photos?
OVRAROK
Quote from: redneckcustoms13 on April 15, 2016, 07:26:02 AM
that's my 84 I built awhile back
redneckcustoms13
I like it. Got a thread on it?
OVRAROK
Finished clearing out dash. While I'm waiting on parts, going to mount 3rd gen instrument gauges into runner dash piece
OVRAROK
Can anybody tell me where this grey plug goes to, it's coming of engine harness, I can't find a plug that plugs into it on dash harness
helipilot77
That looks like ECU or ECT brain.
emsvitil
Might be nothing.
Toyota has a habit of using the same part for multiple apps.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OVRAROK
got a little more accomplished today, finally found a front trans input seal (preventive maintenance), got the seal in and front cover on, exhaust manifold showed up, then dropped off at the powder coater for some black ceramic coating. went to Toyota and picked up some new exhaust studs and bolts for manifold to downpipe, also picked up some new clutch pivot bushings, ordered new Asian clutch master. tomorrow ill get bellhousing on, and some thermo-tec heat barrier on firewall near bellhousing. afterward I need to get motor on engine stand for some clean up, rear sump oil pan, motor mounts. should have motor in by the weekend. then the wiring  :crazy:
OTO Phil
on the driver's side, there's a fuse panel... It looks kind of like the plugs that I remember putting in there when I was installing my harness..
OVRAROK
Quote from: excabswap on April 18, 2016, 07:35:19 PM
this plug is from 98 3rz engine harness, its only a inch away from the engine to dash plug, the main one. I went through entire dash harness plug for plug, couldn't find anything that it would plug into. there is no physical wires left in the donor so.... I believe its just an add-on for something that my donor vehicle doesn't have
