OVRAROK. My 87 4runner
0 Members and 6 Guests are viewing this topic.
OVRAROK
Finally got my 4runner cleaned up, nice day out
Sent from my HTC One_M8 using Tapatalk
SqWADoosh
Hey buddy I'm wondering if you can point me in the direction of where you got your cutting board for your tailgate? Looking to do the same with mine.
OVRAROK
Gathering parts for 13 gallon potable water, thinking of recirculating water back to tank , this with my on board shower, on demand hot water
throttle
84_yota_4wd
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
OVRAROK
carved out some interior panels passenger side done
OVRAROK
started and finished drivers side,
Dingman.
those should sell like hotcakes lol
1985CRAWLER
what dingman said! ill take a set :thumbs:
nice work dave!
OVRAROK
Finished up my tool roll, this thing came out pretty nice, it 45x30 when folded out, three zipper compartments.
SqWADoosh
OVRAROK
thanks buddy, trying to find the material a little cheaper to make them affordable
OVRAROK
Have almost 2 of theses done, 75 shipped
redneckcustoms13
Do you run a trim shop or something? You do very nice work.
01 double cab hunting truck
06 tacoma street truck
OVRAROK
so do you have a rough shape in mind? how many bottles are we talking about?
OVRAROK
so it sounds like you want same shape as chair case just shorter, when you same semi rigid, are you talking like a hard floor in it
OVRAROK
Quote from: liveoak on November 20, 2015, 10:18:22 AM
ok, i put more thought into it. 6 bottles around(3 on top of 3) and 5 bottles long. total of 30. yes a hard bottom maybe a strip of plastic sewed in 3 bottles wide and the full length if that makes sense. almost a full length zipper with a shoulder strap where the zipper begins and ends or wherever it ends up being most stable. maybe a small strap at the ends for pulling out of the truck
I just put 6 bottles together,looks like 7 would make for more of a rounder shape, I'm drawing sketch right now, but I'm thinking 8" round 40" long 35 bottles total
OVRAROK
OVRAROK
could go same style but square, 8" wide 5.5" tall, with floor being thin plastic sewn between fabric, double layer, rip stop fabric on outside, maybe thermal silver looking fabric with 1/4 of batting between the two fabrics, I'm going to town this weekend, ill go look for inside fabric
blackdiamond
On my last Moab trip I just bought a flat of water bottles and then just left them under the plastic until I wanted to put a few in the small cooler.  This is way more OCD...
Maybe some D-rings on the ends to tie it down with?  :gap:
SqWADoosh
Quote from: blackdiamond on November 20, 2015, 11:34:23 AM
Every trip I do the same thing. I buy a flat of 40 from Costco just like LO is talking about, however I utilize them as my ice for my cooler. I freeze about 25 of them solid and they make the base of ice in my large cooler. Works great because you get double duty out of them. They will stay frozen for 3 days or so and if you run out of non frozen water bottles you simply need to pull a couple of the frozen ones out and let them thaw.
Nation
Quote from: ovrarok on October 20, 2015, 05:11:51 PM
very nice!
OVRAROK
OVRAROK
Happy turkey day everybody
OVRAROK
Made this bag for liveoak bag is fully insulated, has flexible 1/8 sheet plastic floor sandwiched between material
redneckcustoms13
OVRAROK
redneckcustoms13
mudmaster
Time to go wheelin!
OVRAROK
Got my powertank filled and mounted
