OVRAROK. My 87 4runner
0 Members and 25 Guests are viewing this topic.
twistedtoy92
Very nice work man! Looks clean!!! :beerchug: I really miss dual cases, been 4 years since Ive ran mine... :headshake:
toyodaaddict
The frame plating and steering box mount look real good, nice work.
OVRAROK
Transfer case out, new eco seal in made this plate for switches last night just got done making this . Lunchtime
OVRAROK
OVRAROK
gonna make square driveshaft today
OVRAROK
got one slider done this afternoon
OVRAROK
Square front driveshaft, at ride height ive got 5 in, 16 out
Dingman.
Is that cv clearanced for more angle?
If not you might want to hold it up and see how much angle you can get before it binds and think about running limit straps?  :dunno:
Clearanced vs stock.  It all depends on your angles your truck has
OVRAROK
thanks mike, once im done im gonna take it down to my local ace hardware, they have a forklift, ill check it out, is it hard to clearance? just grinding down? do I have to take about to do?
OVRAROK
Couple pics of slider, should have other done tomorrow, and I'm gonna clearance my cv. Found good write up at 4x4wire
OVRAROK
OVRAROK
Ok here's a few pics of cv clearance. clips out clearance the zero too . Finished back together
Dingman.
1985CRAWLER
i wish i had built my 4runner as quickly and clean as u did yours.
OVRAROK
thanks, all the rigs on here where my inspiration. Ive been stacking parts for almost 2 years, been working almost everyday for 2 weeks. just trying to make the round-up
OVRAROK
Sliders are on . Front driveshaft is in.
OVRAROK
Made a plate to cover hole for shifter then some insulating tape. Good to go
OVRAROK
Made battery hold down today
1985CRAWLER
what is that stuff u used to cover the plate down on the tunnel?
looks really good!
OVRAROK
Here's the stuff I used 1985crawler. I bought it at home depot. I've lined the inside of doors, inside of rear quarters,and rear floor. Quieted it down, also cooled floor temp
megaphoneman
AWW!! good stuff on that covering crap...im needing to do this right now..before i get the center console...
are you trying to make the round up?
OVRAROK
yeah im hoping,im registered. im waiting on rear driveshaft right now, then have to set pinion angle. have extra rearend with new perches ready to go, oh have steering stabilizer to mount, and bumpstops( should be here tomorrow)
megaphoneman
whos doing your drive shaft?
OVRAROK
megaphoneman
oh ok cool, the guys down at southbay have always worked well for me.
OVRAROK
Just received these in the mail to help out on rear sag
OVRAROK
Made some mounts for rock lights. I tapped a piece of 1/4 flat bar. Then tack those in place. Here's the rear in front of rear tire behind front tire. In front of front tire . I'll test to see light pattern tonight
megaphoneman
Hey i will txt you, but i had a bad weekend with my f150, the trans and rear end went out on some test runs, so i wont be going to livermore tommorow...
OVRAROK
Got my rear driveline last night, thanks dingman. Made some front bumpstops last night . They slip together, held in place with bolt,so that I can adjust if needed
megaphoneman
Get it!! thanks again for being a rad dude and driving over yesterday!
