OVRAROK. My 87 4runner
OVRAROK
megaphoneman
OVRAROK
this is where I'm at, got new rearend perches off, marlin full diff cover on, old rearend out, have third setting up(gasket maker) in new rear. Tomorrow will get axles in, on it's own weight, set pinion angle( 2 degrees lower than shaft angle). Tack, pull axles, then weld perches on. Fab some bracket to hold e brake lines. Should be running tomorrow, then all that is left is weld bumpstops.
OVRAROK
Got rearend under truck,axles in, tires on,on it's on weight, zeroed pinion and driveshaft, they at 15 degrees, then set pinion at 13 degrees, tack perches on tore all down, have rearend housing out,getting ready to weld
OVRAROK
Well. Just took it for a spin around the block. Feels good. Just need to install bumpstops and rear shock mounts on axle
megaphoneman
1985CRAWLER
thats awesome man! good work. fix that rust!
how to u like the 35" kevlar mtrs? im gonna cave and sell my 37s and get a set of those real soon here
OVRAROK
the rust give me motivation on trimming fenders, wanna do tube from rear bumper to rear of rock slider
OVRAROK
measuring for bumpstops
megaphoneman
Did i miss something or are you running a first gen front end?
OVRAROK
First gen headlamps and center grill, I just like the look
1985CRAWLER
SICK!
i wanted to do that once but couldnt find a decent 1st gen grill.
OVRAROK
I bought the grill on ebay for like 40 bucks
OVRAROK
1985CRAWLER
nice! i have the same shock bar, took him a month to mail it but i like it,
u arnt worried about your shocks botting out when loaded down with gear, my 12s did i had to go to 11s
OVRAROK
im going to take it back to the forklift tomorrow, my bumpstops are adjustable, I used 2" dom and 1 3/4 dom, a little sanding and they slip together welded 2 inch on u bolt plates, if needed ill adjust them
OVRAROK
Fully loaded shy of ice and me
1985CRAWLER
Nice! u have alot of room still.
wanna check this rig out, hopefully i run into u.
OVRAROK
Was bored today, so I made some gussets for front hanger. Before after
megaphoneman
Thats nice dave!!
Blaaaahhhhhhhh
1985CRAWLER
thats sweet! i need something like that on my stock front hangers.
OVRAROK
Finished welding, and paint
Nation
Somebody get this guy some more turtle points!!
daniresch
Quote from: NATION on September 01, 2014, 09:55:04 AM
right?! haha watching this!
OVRAROK
Cb mount,from idea to pre-paint
chim
Your runner looks great! Do you have a pic of what you did for a dual battery tray?
Nation
I'm looking forward to the shower build  :shhh:
OVRAROK
Quote from: chim on September 16, 2014, 10:27:11 AM
battery tray is angle iron, I made two at separate bottom trays, then welded them together, I getting ready to relocate batteries to under bed.
chim
Quote from: ovrarok on September 16, 2014, 10:50:41 AM
Let me know if you are looking to get rid of the mount. I am looking to do the same setup as what you have now..
OVRAROK
I can make you one, only take about an hour if that
