OVRAROK. My 87 4runner
OVRAROK
Sent from my HTC One_M8 using Tapatalk
redneckcustoms13
01 double cab hunting truck
06 tacoma street truck
OVRAROK
So I started installing on board shower fender removed, I use a thread setter for mounting of homemade heat exchanger used the plasma cutter to cut hole test fitting hoses, and hole completedheading to parts store for hose and a few fitting, should have it wrapped up by tomorrow
megaphoneman
OCD
 :smokin: always wanted to so this... You should camp near us at round up and we'll trade you cold beers for hot showers! What are you useing for a pump on the shower side?
OVRAROK
The pump is a flo jet, pumps 1 gallon a minute at 35 psi, also made a plate with quick disconnects
OVRAROK
Got pump mounted using thread setter almost done
OVRAROK
OCD
 I'm a big fan of the nutserts, FYI you should look into the knurled nutserts in the future. They typically have a slightly larger flange and most importantly the knurled body really bites hard and prevents them from ever spinning. If you like the thread setter gun you should check out the studsert guns available...way badass! Just my  :twocents:
:thumbs: nice work!
Nation
AWESOME! been waiting for this for a while
Rockcrawlintoy
Looks good man I'm going to need to do this on the jeep
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
1985CRAWLER
looks really good! u always do clean work!
i hope that fender doesnt get crunched anytime soon!
OVRAROK
I figured driver side fender I could see the most
OVRAROK
So after reading the instructions, I realized I had pump upside down, flipped pump, and ran all lines, just need to plumb into coolant flow, and wire in switch
SqWADoosh
I have dreamed of doing this exact same thing to my rig. You sure are making it look easy buddy. I also just noticed you have a 1st gen truck grill  :smokin:
OVRAROK
Need 1 hose clamp to fill coolant and burp, now I need hoses for water side and shower, put fender back on , leaving black plastic off until checked for any leaks
Nation
Dingman.
Dave, what about bending some tubing and run a bar from your bumper to your sliders, inside of the fender?  Like the guys do with partial exo's.  It would strengthen your bumper and protect all the on board shower you just installed
megaphoneman
i know a guy who could do that..
Blaaaahhhhhhhh
Nation
this rig is seriously so clean and well put together! Great job man!
megaphoneman
i know im jealous!!!
Blaaaahhhhhhhh
OVRAROK
Finished up the on board shower, installed a 40 micron filter before the pump
Nation
OVRAROK
Slabzilla
Cleanest shower install I've seen.   :biggthumpup:
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
OVRAROK
The inside heater temp controls how hot water is
SqWADoosh
Would love to see some more detailed photos of the routing under the hood. Amazing job, Dave.  :bowdown:
OVRAROK
hard to see pics of plumbing inside engine compartment, came out super clean
OVRAROK
driver side pulled apart, cleaned inside ball, repacking bearing with grease from rcv, New axle going in shortly
OVRAROK
, back together, waiting on paint to dry, painted 2 half circle pcs of metal that hold felt in place, tomorrow I'll do passenger side
