OVRAROK. My 87 4runner
0 Members and 14 Guests are viewing this topic.
OVRAROK
OVRAROK
Finished cb mount, painted and installed
Nation
chim
Quote from: ovrarok on September 16, 2014, 11:11:52 AM
I can make you one, only take about an hour if that
It's all good, I can make one eventually. I was just curious if you were getting rid of yours. Thanks for the offer though I appreciate it!
wing nut
Awesome progress and clean work! How did it perform at mcr?
OVRAROK
ran great, only problem I had was some bolts from skys ifs hub spacer backed out, started hearing noises coming up Cadillac, when I got to staging area in Tahoe, fix it in 30 minutes, other then that flexed out well, had a blast
megaphoneman
Even made it up little sluice
Blaaaahhhhhhhh
OVRAROK
so I finally got around to fixing shaved bolts from mcr, buttoned up, repacked wheel bearings, New inner seals, good to go
OVRAROK
Started working on my ammo can/center console, cut one latch off of one side, welded hinge, also made sub floor, this is to house my vision x wires to 8 way black box that's part of kit, box will be semi permanently mounted to floor
GONZO97
Awesome clean build man, i too am a huge fan of the first gen front end, may have to do that same conversion soon too! :beer: :eyebrow:
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
OVRAROK
1985CRAWLER
sweet! i did the same thing with plywood. changing over to aluminum soon, need something that wont give me splinters .
megaphoneman
Dave i love that cutting board idea!
OVRAROK
a little sanding around the edges and install
Nation
OVRAROK
OVRAROK
oh yeah baby, 23 spline 4.7 marlin crawler gears
OVRAROK
here is transfer case for 4.7 gears.
OVRAROK
transfer case torn down, just need to clearance,and clean before putting back together
OVRAROK
First round of cleaning. Tomorrow I will give good cleaning and clearancing
if it doesn't, you might be able to take out a leaf?
it should settle though.....
looks awesome!
and...... I think you need some hub lockouts ;)
OVRAROK
clearanced box and here is final clean.
megaphoneman
OVRAROK
I have been slowly obtaining parts for on board shower. In pics are heat exchanger that I made. 2 inch diameter copper tube, with 3/8 copper, approx 10 ft of it, wrapped around 1 diameter pipe, then put in 2 inch tube, 2 quick connect fittings on 3/8 plate, going to weld plate onto front bumper, and a couple tees to tee off to coolant lines, have 14 gallon tank also
OVRAROK
just got back from picking this up 5.15 1st gear.
twistedtoy92
Super low 1st gear, outstanding!!! :beerchug:
OVRAROK
4.7 marlin crawler gears, ready to go, will take triple flanges off current case that is in truck
daniresch
Looks great!! Not sure if i missed it, are the running the original outputs or 30spline?
OVRAROK
OVRAROK
drove almost 1400 miles for this
