Chim at it again!
Started by chim, February 27, 2011, 08:58:22 PM
chim
I have always regretted getting rid of my 85 4Runner.. I had bought 2nd Gen runners in hopes of old glory but they are just not the same, and would require a ton of work!!
Old Runner...
But today I struck gold! I had just sold my Subaru Saturday in order to get serious about getting another 1st Gen runner.. so today I was checking craigslist every ten minutes for possible new ads when I found my new 4Runner...
Here it is... maybe the guy who built it will recognize it.. its an 86, 22re, 5-speed with a supposed 25k on rebuild.. time will tell.. it has a SAS, 6 shooter knuckles, 30 spline longs, trussed, armored, detroits front and rear, hi-steer, 5150 Bilsteins on all 4 corners, 63" chevys, 35 bfg mt's, and lots more...
Here are some crappy pics.. I have now been the owner for 4 hrs! It needs lots of little things, but is a driver as is. As always, I will document it all on here :)
Better pics to come.
blackdiamond
Welcome back to the world of being a Toyota owner!  What the spring looking thing in the first picture of the new runner?  I would guess air line if it had an ARB in the front.
scoutrunner
Goldrush
Quote from: blackdiamond on February 27, 2011, 09:34:48 PM
i was wondering the same thing, could be a air line or a breather..?
chim
They are just breathers.. it has detroits
83 Crawler
i see your from oregon.. what part? and sick runner  :biggthumpup:
94MtnYote
Score, looks great!
I totally understand checking cragslist every ten minutes for yotas, I think we've all been there lol!
Marlin 1200LB clutch
yoshaleng
Congrats on your new truck!
Nice score on that one looks like it has some good mods.
chim
It does have some good mods which is why I was so stoked about it....
BUT... not so stoked about the drive to work in it today! It has some funky engine issues that I need to figure out... the motor seems bogged down and idles crappy until I get my foot into the accelerator and then it seems to want to go.. but not until I really step on... It starts fine... shuts off fine... I am not sure what it is... maybe plugged EGR? Anyone have issues like this??
(22RE)
chim
Quote from: 83crawler12 on February 27, 2011, 11:00:19 PM
Thanks, I'm in Clackamas County
83 Crawler
Quote from: chim on February 28, 2011, 08:38:29 AM
same here... im in milwaukie tho.
H8PVMNT
My buddy had an '85 that ran like that and it had the timing chain off a few teeth.  We went though TPS and alot of other tings before we figured it out.
– Steve McQueen
chim
I don't think it would be a tooth when it has about 25k on it.. I'm going to try pulling codes at lunch today and see what that says... check to see if my knock sensor is still plugged in.. and go from there... I agree on the TPS though.. very well could be that too...
H8PVMNT
This one was a fresh rebuild too, the dummy before us put it together wrong...
– Steve McQueen
chim
I just went out and pulled the code... it was 5 flashes which says to indicate bad O2 Sensor... I have a header to the sensor is right before the cat... its a one wire sensor.. does this sound right?
chim
Another couple pics
Here is a quick interior shot...
The 5" tach is going to go.. I want to try to find a sr5 cluster with tach built in.. then get some factory door panels and factory seats.
bleakhorizon
i will trade yea that tach for a sr5 cluster...
also try disconnecting the TPS and seeing if it runs better.... Buddie down here did that and it runs good. so its been like that for year plus
Those are some huge welds!
Tillamook, OR
chim
Quote from: bleakhorizon on February 28, 2011, 01:48:46 PM
I want to try the o2 sensor tonight before I start unplugging things.. but I had thought about that as an option to try if this fails...
I would definitely trade you the tach for a cluster... pm and send some pics if you are serious :)
chim
I have some nice seats here if someone has some factory gray buckets they want to trade for... These ones make me sit too high... I'm 6'-4 and I have to bend my head down a little to see out the windshield more comfortable..
Cheesemaker
If I remember correctly, on the first gen 4runner (second gen p/u) the O2 sensor was mounted in the exhaust manifold.  The newer 2nd gen 4runners (3rd gen p/u) had the O2 sensor down in the pipe right before the cat.
Good to see ya back in the Toy Chim.   :thumbs:
chim
Thanks Cheese :) Mine ended being down right before the cat.. I have a header.. so it was super easy to replace.. just two bolts and one wire, and it was only $38.. so that was good.. and it seemed to help.. I think if could be better, but its definitely running better..
chim
I went over to my gramps' house last night and picked up a few things to collect for getting my interior back in order :)
I got a set of factory gray buckets... the passenger seat is taken apart but its there and with no rips... the drivers seat has a good back, but needs a new bottom if anyone has one they want to sell..
And then I need both headrests and gray seat plastics...
I also got two perfect rear side panels for the very back.. I still need door panels and passenger panels at back seat..
Then I got a new stereo bezel so I can get rid of the trio gauges..
79yota4x
sweet :thumbs: my dad has an 85 love these style of runners
Get oN iT anD Stay on iT
79 pickup doved, locked, half cage, boggers
88 ext pickup linked with fox airs up front, 39.5 iroks,Beadlocks, 5.29s, 4.7s, chromolys, 6shooters, hp arb,  spool and 56 chevys in the rear
4Runner_guy
Damn, nice rig. Wish I could afford a SAS on my 88' runner :(. All in time as I am enjoying my rig cause I just got a set of new 32x11.50x15 BFG KM2s!
chim
So I am still trying to get this thing running right.. There is still some sluggish response on acceleration, then its like it hits its power band and takes off.. its not all the time.. its pretty inconsistent...
Here is what I have done so far:
o2 sensor (because of engine light)
Cap, Rotor, Plugs, Wires, PCV valve
Adjusted TPS sensor,
Tested AFM
Disabled EGR
New Fuel Pressure Regulator
New Fuel Filter
New Fuel Pump
Going to check my engine grounds next.. any ideas, anyone else have this problem?
chim
Even though my engine is not completely dialed in and figured out I am still managing to get some other things done... cleaned the nasty headliner..
Before...
After...
Took the 5" tach out...
Getting ready to install one of these....
I just need to buy the right oil sending unit..
then I can get rid of all these and get my dash looking close to factory...
I actually want to make my dash look like my old 85 dash.. nice and clean...
blackdiamond
Make sure you get the gage cluster that has a full tank of gas!  :yupyup:
chim
Quote from: blackdiamond on March 17, 2011, 11:39:46 AM
True! But that one has about 80k more miles!
