Chim at it again!
Started by chim, February 27, 2011, 08:58:22 PM
chim
The you got a SUPER smokin deal!!!!
83 Crawler
230k out of 97 4unner im pretty happy :) the wiring is going to be the scary part
chim
Mines a 98... So our wiring should be similar... I will try to take some notes
83 Crawler
Going to hook everything up to factory dash?
chim
Yeah, only difference should be under the hood visually :) fingers crossed! Wiring is definitely scary!
83 Crawler
This place called toyonlyswaps.com sells stand alone wiring harness for 550 for carb trucks so they might sell something for efi
chim
I have all the wiring its just interpreting the diagrams that I need to do... 550 seems like a ton of money!! Did you not get the wiring for your swap with the engine?
83 Crawler
ya i have the wiring a ecu,
chim
Let the work begin...
Time to say goodbye to 22RE
Had her out in about 1.5 hours  :thumbs:
chim
22RE Bell housing
3RZ / 22RE Bell housing comparison
3RZ Housing all bolted up... doesn't get much easier than that!
83 Crawler
yes the good stuff!!! keep it coming! :eye:
chim
Instead of trying to re-bend my existing clutch line I just bought factory 98 Tacoma clutch lines and bell housing bracket... made the clutch line mod super simple and clean!
Oh yeah, new slave cyl..
chim
New clutch.. resurfaced flywheel.. pretty self explanatory..
chim
Then we worked on the fuel line....
The factory fuel line will not reach to the other side of the motor to where the factory 3RZ fuel filter is mounted....
So we modified again.... we moved the 3RZ fuel filter towards the rear of the motor and re-bent the line that feeds the fuel rail....
You can see the filter sticks out just past the block in order for the fuel line to cross over the bell housing and connect.
Then a home made heat shield was added to protect the fuel line from the exhaust EGR crossover tube...
So here you can see how the fuel line was bent and fed towards the drivers side.
chim
Needed to make a new battery cable to reach to the drivers side...
This is a piece 8'-4" long... (4g)
Then wrapped it around the engine bay.. should have used black.. oh well..
Got the motor installed...
83 Crawler
what motor mounts you using?
chim
Used Chilkat motor mounts.. then drilled a hole in the side to support the dipstick and manifold brace...
Power steering was easy... pressure line threaded right in, just needed to curve the line a little... non-pressure line was trimmed and fitted...
83 Crawler
how long have you been working on it?
chim
I thought I could just bend the throttle cable bracket for the 22RE cable but there was a little bind and I didn't like it..
So I added a little spacer plate and now it works like a champ..
chim
Quote from: 83crawler12 on March 19, 2012, 10:10:13 AM
My buddy and I have about a day and a half into it so far
83 Crawler
Quote from: chim on March 19, 2012, 10:13:29 AM
not bad started on wiring yet?
chim
Started cutting parts to get the intake figured out..
chim
Got the LCE swap header in... will actually need to be tweaked a little since it just barely comes into contact with shackle bolt.. will get more pics later..
chim
Now the wiring part... ugh...
The two different computers..
Paperwork... lots of it...
The process of identifying and labeling..
chim
So we ended the night with cranking it over and it cranks great, it just wont fire... fuel is circulating but no spark.. we really need better diagrams for the 4runner ECM plugs on the body side.. the diagrams on TTORA don't really show it.. any help would be appreciated!
I will post more pics next weekend of the progress... radiator hoses, exhaust, more wiring, etc.. :)
83 Crawler
i cant wait to get started on mine!!!
chim
Quote from: 83crawler12 on March 19, 2012, 10:25:16 AM
Its going pretty smooth so far.. just lots of little tweeks and stuff that add up in time... I will try to document most stuff :)
83 Crawler
o are you doing all the smog stuff? or getting rid of egr and stuff?
chim
I want to get this EGR block off kit
http://www.lceperformance.com/EGR-Block-Plate-Kit-2RZ-3RZ-5VZ-p/1016017.htm
and for now I will be running the evap box until I can figure out how to eliminate it without engine codes..
