OVRAROK. My 87 4runner
0 Members and 28 Guests are viewing this topic.
HogCanyonHopper
how many wires? looks like A/T indicator switch. nothing to worry about
OVRAROK
Quote from: HogCanyonHopper on April 18, 2016, 07:57:40 PM
has 3 wires running to it
HogCanyonHopper
what colors? I'm pretty sure its for an auto tranny
OVRAROK
Quote from: HogCanyonHopper on April 18, 2016, 08:14:45 PM
black w/blue stripe, red w/blue stripe, and red w/yellow stripe, the connector is 10 pin w 3 pins being used
OVRAROK
OVRAROK
Black ceramic coated exhaust manifold
Sent from my HTC One_M8 using Tapatalk
emsvitil
Those won't work on my 22RE...............
:hammerhead:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
HogCanyonHopper
That's purdy Dave  :yesnod:
1985CRAWLER
Gonna run the oem heat sheild over that ? I shoulda painted mine like that , I left it all rusty and looked ugly , swap is coming along quickly !
OVRAROK
Quote from: 1985CRAWLER on April 26, 2016, 07:59:27 PM
Yes I am Mike, will be ordering next week, truck should be done in 3 weeks
1985CRAWLER
Memorial Day shakedown run ?
OVRAROK
Quote from: liveoak on April 29, 2016, 08:39:07 AM
those look like a good deal @ $5 each. too bad you have to buy 4 of the same. you probably saw this already but all the toyotas with the same discs are listed below. you can probably find some at a pick n pull dirt cheap
how was moab chris?
mudmaster
Quote from: liveoak on April 29, 2016, 12:02:16 PM
awesome. great group of guys here
Liveoak and his buddy Jim are great guys
Time to go wheelin!
OVRAROK
So I'm waiting on Toyota to call, let me know my egr studs and nuts are in, I got a little bored
helipilot77
Flames on your oil pan! Isn't that kind of bad symbolism?  :ha_ha:
OVRAROK
Quote from: helipilot77 on April 30, 2016, 03:56:17 PM
It was the valve cover, but for some reason, the paint didn't stick in a couple places, live and learn
he has flames on his arms too ;)
redneckcustoms13
I cleaned my spare valve cover with aluminum brightener and then hit it with high build primer, sanded with 220, then painted with a decent spray can. Turned out decent.
01 double cab hunting truck
06 tacoma street truck
Prismo
We scrubbed my buddies with steel wool & hit it with acetone a couple times & the paint stuck fine on his.
OVRAROK
I was able to get a nice base coat on, I think when I was making flames, my fingers are never really clean, always some form of grease or oil on them. I think my finger layed down a thin film of oil, when trying to push crepe tape down, going to sand, clean and paint, then try again
OVRAROK
Couple pics from today
all bolted in?
that's awesome!
mdtrail-toy
Moving along pretty quick. Lookin good :thumbs:
redneckcustoms13
Did the motor mounts bolt in?
OVRAROK
Quote from: redneckcustoms13 on May 03, 2016, 09:30:23 AM
yes, fell right into place, no problems at all, transfer case mounts look fine
OVRAROK
So , all that is left is heater hoses, need to incorporate my on board shower, high pressure fuel line, fittings should be here today, 1 more battery cable, need to fab exhaust, and figure out where my intake is going to go, change oil filter, put oil, trans fluid, and coolant back in. A little more wiring inside, then put dash back in, I did drill 2" round hole for engine harness, moved brake lines away from exhaust manifold, found a good spot for ecu
SqWADoosh
Looks like a good ole road trip is in order to break that girl in. Oh say in July to Washington?  :D
OVRAROK
#539
someone stole your cat!
oh yeah, AWESOME fuel line
