OVRAROK. My 87 4runner
0 Members and 17 Guests are viewing this topic.
OVRAROK
Quote from: SqWADoosh on August 02, 2016, 12:53:35 PM
There is a couple different threads on pirate about doing it. It involves getting a donor panel from another truck. Custom wheel wells and much more.
my dial up doesn't like pirate, takes almost a half hour to load a page, looks like all they did was move opening of rear fenderwell rearward
SqWADoosh
Quote from: ovrarok on August 02, 2016, 12:56:10 PM
Sounds very simple but there is a lot more to it than that to make it look that clean.
OVRAROK
think I'm going to move rear axle back 1.5" :think: then re assess the rear departure angle, I'm just tired of rear bumper dragging
OVRAROK
any of you guys that have done 3rz swap on 1st gen 4runner have pics of heater valve? what year valve did you use? did you have to bend mount, move mount?
:)bestgen4runner
Quote from: ovrarok on August 02, 2016, 01:01:06 PM
I like it when My rear bumper drags   :moon: .
I am 1/5th of Perfect Fit
blackdiamond
Quote from: liveoak on August 02, 2016, 12:45:36 PM
not suggesting that you do this, but have you seen a runner with the wheelbase extended? I'm not sure if I like it
After wheeling my bobbed 85 extended cab and now my 4Runner this looks to be the ultimate solution. If you have the skills (I suspect you do), do this. 4Runner interior with a longer wheelbase. Perfect!
Call it the "CJ-6" mod.
I thought you already had the correct heater valve?
cbeers
Look up Zidaro's build on this site.  I think he calls his 4runner Gumby.
:thumbs:
CB
OVRAROK
So I noticed that my chilkat mounts aren't perfect. Passenger side needs to be raised a tad, my solution was these
Sent from my HTC One_M8 using Tapatalk
:)bestgen4runner
Quote from: ovrarok on August 20, 2016, 08:39:12 AM
I don't know what it took to make those, but you should make more. I bet there are a few boys on the forum that would love a set. $$
OVRAROK
Quote from: :)bestgen4runner on August 20, 2016, 09:12:52 AM
they took about 20-30 minutes
redneckcustoms13
Was that enough to do the trick? That was the first attempt for me as well.
01 double cab hunting truck
06 tacoma street truck
OVRAROK
Quote from: redneckcustoms13 on August 20, 2016, 06:23:35 PM
will be installing tomorrow morning, ill update when I'm finished
OVRAROK
So... As it turns out, these shims didn't work as expected, but there are these tabs that the motor mount rest on. they are on the frame side of motor mount, was able to loosen bolts, lift motor, and play with these tabs, ended up pushing passenger side up, and got a lot of movement from banging down drivers side, motor settled in nicely. And you always have to have a helper
OVRAROK
Started gathering trail spares for the 3rz
OVRAROK
My water temp gauge and new oil pressure line showed up
Rockcrawlintoy
Quote from: ovrarok on August 23, 2016, 11:32:58 AM
Could you describe to be what the water pump gasket looks like??
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
SqWADoosh
SqWADoosh
Throttle body as a trail spare eh? Thats a new one for me. What else is pictured besides water pump, throttle body, and starter?
OVRAROK
Quote from: SqWADoosh on August 23, 2016, 05:14:28 PM
Crank sensor, oil pressure. I'm hunting for maf right now. I may be bringing spare 23 spline t case just in case, have stock front axles stashed under rear seat delete, trying to make a functional compartment under rear seat delete. There's a lot of wasted space under there .Hoping to hold all my spares, shy of t case and third
SqWADoosh
Quote from: ovrarok on August 23, 2016, 05:30:41 PM
I've thought the same thing. Interested to see what you come up with.
OVRAROK
Quote from: SqWADoosh on August 23, 2016, 05:31:48 PM
I didn't know you had the rear seat delete plate.Nice find, took me a few years to hunt one down
SqWADoosh
Quote from: ovrarok on August 23, 2016, 05:33:48 PM
I don't. Keep an eye out for one for me.
OVRAROK
Quote from: SqWADoosh on August 23, 2016, 05:34:58 PM
I'll find you one
1985CRAWLER
Dave you in for a fordyce run Labor Day weekend ?
OVRAROK
Got mechanical water temp gauge in
John Doe
I did the same wheel base stretch that was previously mentioned. Mine is not as pretty as others but it works! Gave me a 112WB, with a much more manageable departure angle. I highly suggest this if you have the skills/ time!
SqWADoosh
Quote from: John Doe on August 24, 2016, 04:25:14 PM
Would love to see what you did. Pics?
John Doe
#808
You can see some of it in my build on page 19. Not the build process but some of the after. I had grafted a donor panel onto the existing body and moved the axle back +/- 6"
You are welcome to take a look at it in +/- 3 weeks  :biggthumpup:
OVRAROK
mechanical oil pressure hooked up
