OVRAROK. My 87 4runner
OVRAROK
Sent from my SM-G955U using Tapatalk
redneckcustoms13
It always hurts me to see these nice not rusted trucks get cut.  :moon:
01 double cab hunting truck
06 tacoma street truck
cbeers
Looks great Dave!!
I've seen double rear shackles before but double hangers?
How do they work?
:gap:
CB
redneckcustoms13
Quick change wheelbase option. Only available on certain year models.
OVRAROK
Quote from: redneckcustoms13 on May 29, 2018, 05:59:20 AM
That area of the truck has been beaten with a 3lb sledge hammer, its actually is more aesthetically pleasing to the eye now
Dingman.
Looks good as always Dave!
always clean well thought out work. dig it
OVRAROK
This morning I cut passenger rear fenderwell, and made the filler plate.
OVRAROK
Both rear fenders trimmed, first view of the summer tailgate on the 4runner.
mudmaster
Time to go wheelin!
OVRAROK
Quote from: mudmaster on June 08, 2018, 12:35:28 PM
Summer tailgate??
Yeah, basically gutted. Weighs much less then stock tailgate
helipilot77
Your giving me ideas Overarock. I have an extra tailgate.
OVRAROK
Front end torn down.
OVRAROK
Finished up the installation of new HP 529 ARB. Had to slightly modify my lubelocker gasket
megaphoneman
trucks looken great dave!
Sent from my iPhone using Tapatalk Pro
OVRAROK
Last night I received my High Angle front driveshaft. A big thanks to mike (dingman), he picked up my core from my house, and delivered it. This morning I installed it. Just need to break in the diff now. Most likely I'll go to Praire City OHV to get a couple heat cycles on it.
epantano
Quote from: OVRAROK on July 23, 2016, 11:42:31 AM
Toyota 4Runner Drive Cycle
A. Ensure to begin with your 4Runner having 1/4 to 3/4 tank full of gas, and after it has been sitting overnight. The engine must be cold before you begin the drive cycle. Also make sure the check engine light or MIL is not illuminated. If the check engine light is on, do not perform the drive cycle. Visit a smog check repair station for diagnosis. The check engine light must be off in order for the drive cycle to initiate.
B. Release the pressure in the fuel tank by removing and then reinstalling the gas cap. Start your 4Runner's engine and let it idle until it reaches normal operating temperature. Coolant temperature should reach 167F or above. If the temp gauge is near the center, you may continue on with performing the drive cycle.
C. Increase idle to 3000 rpm for 10 seconds. Allow the engine to return to idle, then turn on the A/C. Let the engine idle with the A/C on for 30 minutes.
D. Turn off the A/C and begin driving. Drive your 4Runner at 40 to 55 mph for 3 minutes, then decrease your speed and drive for 16 minutes, fluctuating your speed between 35 and 45 mph. It is very important that you accelerate and decelerate smoothly between 35 and 45 mph, during the 16 minutes.
E. Stop your vehicle and allow the engine to idle for 2 minutes or more. Begin driving once again. Drive your Toyota 4 Runner between 40 and 70 mph for at least 3 minutes. Be sure to maintain engine speeds between 900 and 3,200 rpm. Stop the vehicle and allow the engine to idle for 10 seconds or more. Begin driving again at 25 mph for one (1) minute. Be sure to maintain engine speed above 900 rpm. Stop the vehicle and allow the engine to idle for 10 seconds or more. Perform steps "E" ten times. This portion of the drive cycle is not easy to perform on public roadways. If you feel you are unable to perform this drive cycle safely please seek repair assistance from a Toyota certified or smog check repair certified center.
F. Drive cycle complete. If the above Toyota 4Runner Drive Cycle did not make all the emission monitors READY/COMPLETE, including the EVAP, CATALYST, O2 SENSOR, and O2 HEATER, perform drive cycle steps A through E again.
How can you do this on a swap with no A/c?
OVRAROK
Quote from: epantano on October 09, 2018, 11:03:07 PM
Skip "C" and half the first sentence in "D".
OVRAROK
New 3rd. First coat of primer
OVRAROK
Couple coats of black later..
mudmaster
Rut roh I didn't paint mine......
Time to go wheelin!
cbeers
hey Dave did mc put the abs freeze plug in or you?
I'm trying a different approach on mine.....we'll see if it works
:hammer:
CB
OVRAROK
Quote from: cbeers on October 12, 2018, 06:36:21 AM
:hammer:
CB
I installed myself. Had 1 playing around. The 3rd came from summit. Had 500 summit bucks that I used.
Dingman.
:hammer:
Go to pick and pull and steal an abs plug off a 4runner. OR...   a wine bottle cork fits in there if you have one of those laying around. Yes, I have actually seen that done
OVRAROK
mudmaster
Mine came with the freeze plug although I had to install it.
Time to go wheelin!
cbeers
hah!
that yotamaster plug is great and I've essentially made a poor man's version
CB
redneckcustoms13
I guess I'm lazy. I just put the sensor in and cut the wires.
:)bestgen4runner
I went to Napa less than $1.00 for the correct freeze plug.  :twocents:
I am 1/5th of Perfect Fit
