OVRAROK. My 87 4runner
cbeers
sorry if i missed it....
hydro assist going in?  didn't you have a cooler too?
i didn't mount my cooler yet. i just put the system back stock and will address the cooler someday...
CB
OVRAROK
Quote from: cbeers on June 03, 2019, 04:20:49 PM
CB
Yeah.., hydro assist starts tomorrow. Cooler will be mounted roughly in stock position.
OVRAROK
Today progress; got steering box on, removed some metal to access new tapped fittings. Got cooler located. And bracket made. Just needs to be welded on. Clearenced the inside of my grille, to allow air flow around cooler. Also got pulley on steering pump and mounted.
Sent from my SM-G955U using Tapatalk
Quote from: OVRAROK on June 04, 2019, 11:05:54 AM
:worthless:
OVRAROK
Quote from: jimbo74 on June 04, 2019, 08:06:05 PM
:worthless:
The last couple days have been to hot for picture time  :yupyup:
:worthless:
Pics or it didn't happen 😝
OVRAROK
I made my housing bracket today, and glued it on...All that is left is to torque things I took off, bolt ram and P/S reservoir on. Make all lines, get a shorter P/S belt( trying to get feed as lowest as possible), bleed system...
Here's a pic to make jimbo happy.
OVRAROK
Summit racing just dropped off 5 quarts of this...
cbeers
how much fluid capacity will this system have?
CB
joeyf
Swepco is really good stuff. Any chance your going to run a filter in the system.
mudmaster
Quote from: joeyf on June 06, 2019, 07:34:04 PM
Good idea! I should probably add one.
Time to go wheelin!
OVRAROK
For me.., all hoses other then feed, have  -6 AN fittings. Only power steering filter would be from Hardin marine. As they make one with 3/8 female npt.
redneckcustoms13
I have spent a lot of money with Hardin marine lol
01 double cab hunting truck
06 tacoma street truck
emsvitil
I used a standard auto remote filter adapter on the power steering fluid return line.................
You can use npt to AN adapters on the filter adapter, then your choice of oil filter.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OVRAROK
Quote from: emsvitil on June 07, 2019, 06:48:00 PM
What micron filter are you using.., I've been reading up, and it seems there are different opinions.., I purchased -6 inline filter. And 3 different micron screens 30,80,and 150.
emsvitil
No idea on the microns.
It's a STP engine filter for a 2000 Harley Sportster.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OVRAROK
I'm waiting on oil filter, and 10 ft of hose pressure hose to get here. However..., I have a question for anybody running TC style power steering pump..
Question: can the feed -10 inlet be clocked at 6 o'clock, pointing straight down, this would help with reservoir placement. Any advice would be helpful  :beerchug:
Ritchie
Quote from: OVRAROK on June 06, 2019, 03:57:27 PM
If I weren't so lazy, I'd look for myself but, what did you pay for this?
'03 Step side Pre-runner, F/R 4WU 3 linked, F/R Diamond axles, F/R ARB's w/5.29's, F/R Fox 12" CO's, ShrockWorks front bumper, self made rear bumper, WARN M8000S w/ remote, 4.7 Inchworm Lefty, MC sliders that hold air & a bunch of other stuff.
OVRAROK
Quote from: Ritchie on June 13, 2019, 03:53:57 PM
10.50 a quart. Purchased through summit racing
Ritchie
Dang, that's cheaper than what I pay for it @ Howe Performance in Lakeside.
I'll check it out... thanks.
nwflyoda
I buy my swepco fluid from summitracing as well.  Plus, depending on where you're at from their warehouses, its super quick delivery.  UPS ground is 2 day shipping for me until i move.
84 Yota Pebble Pounder
Ritchie
Quote from: OVRAROK on June 13, 2019, 10:24:38 AM
Good question... I don't think that would be a problem, as long as the feed from the reservoir is higher than the inlet on the pump.
Got a pic of the pump?
OVRAROK
Quote from: nwflyoda on June 14, 2019, 04:53:52 AM
[/quote
If I order before 4pm, it will be here the next day.
OVRAROK
Quote from: Ritchie on June 14, 2019, 05:52:13 AM
So I called PSC. they told me 3 o'clock. I'll get pic soon.
OVRAROK
My 10 ft of high pressure hose came from PSC. This morning I installed the ram to box hoses. Just waiting on 1 -10 AN fitting to get here for the feed on pump. Couple pics of hoses. I also picked up a drivers door panel from recycle rd..
OVRAROK
Couple more pics..., painting new reservoir bracket. Hopefully back on the road tomorrow..
OVRAROK
Hood is cut...
You can check the level without popping the hood
cbeers
CB....I like it!  :greengrin:
CB
:)bestgen4runner
I am 1/5th of Perfect Fit
