OVRAROK. My 87 4runner
LittleSteve
I found sliders that will extend to 1500mm and hold 150kg. When I get a truck again.......... :smack:
Refusing to fit in or comply.
Easy is not worth anything.
OVRAROK
Picked up 2 top shift t cases from a fellow turtle... couple before and after pics..
Sent from my SM-G975U using Tapatalk
toyodaaddict
How did you get those so clean?
OVRAROK
Quote from: toyodaaddict on February 26, 2021, 04:59:11 PM
I used a plastic putty knife to scrape excessive mud off. Then 000 steel wool to get it down to aluminum, then etched and primed, then 3 light coats of eastwood aluma blast...
toyodaaddict
Quote from: OVRAROK on February 27, 2021, 05:13:52 AM
Looks real good.
Ive got a dual case setup that I plan to fully rebuild and install 4.70's. I'd like to get the cases looking nice. I remember zippo had some cases anodized and they looked pretty good.
OVRAROK
Quote from: toyodaaddict on February 27, 2021, 11:25:42 AM
Looks real good.
Shy of a little elbow grease..im 25 bucks in it for paint..another 65 for toyota bolts and gaskets..
LittleSteve
Quote from: OVRAROK on February 27, 2021, 02:44:18 PM
65? :pokinit: that's cheap. From Toyota or somewhere else, asking for a friend..  :sly:
OVRAROK
Quote from: LittleSteve on February 27, 2021, 02:51:47 PM
Toyota...I get a discount for being part of cal 4wheel drive association
OVRAROK
Rear fenderwells getting trimmed today. It's the lower line if you where wondering...
OVRAROK
One down, one to go...
OOPS
What do yuo use to cut your sheet metal so nice??
OVRAROK
Quote from: OOPS on April 13, 2021, 11:50:54 AM
4.5 inch cut off wheel.  thanks...
LittleSteve
Quote from: OVRAROK on April 13, 2021, 11:33:02 AM
Are those 63's?
OVRAROK
LittleSteve
OVRAROK
Just need to cycle rear suspension before I weld it up..
toyodaaddict
Would you mind posting up some details on how you weld/seal things up. Looks great as always.
OVRAROK
Quote from: toyodaaddict on April 14, 2021, 03:07:26 PM
Sure will.. the plan is to make a template with some posterboard.. then transfer to 18 or 20 gauge sheet metal.. then slow going tack and walk away.. repeat...
Dingman.
Nice work as always Dave!
OVRAROK
OVRAROK
So I'm adding a renogy 50 amp dc-dc on board battery charger with mppt. Im in the process of making a new rear side panel,  with a cubby hole for the unit.. couple pics of the project from thought to almost finished.
OVRAROK
Couple pics of today's progress..
OVRAROK
Should have this side buttoned up by tomorrow
swilson
Scott Wilson - TLCA #5261
1966 FJ40 [sold] - Click for Build thread
1988 3RZ 4Runner - Click for Build thread
1964 FJ40 TBD
cbeers
Wainiha
What 63 inch brackets did you use?  I used Ruffstuff in the past.
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
King resi C/O
and Total Chaos UCAs
OVRAROK
Quote from: Wainiha on May 04, 2021, 09:36:55 AM
I'm using a low range offroad kit.
OVRAROK
Pick up this today, from a local.. thanks sue...
Wainiha
spool gun?  What are the needs or advantages of these vs.  Regular spool in the welder?  I'm still learning.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
King resi C/O
OVRAROK
Quote from: Wainiha on May 05, 2021, 07:43:49 PM
24v trail welder.. uses 2 batteries.. welds 1/4".. gets you off the trail..
