OVRAROK. My 87 4runner
OVRAROK
Started making template for rear bumper. I used 3/16 foam board. This pic is of 1st trial fit.
Sent from my SM-G998U using Tapatalk
OVRAROK
Template is finished. Just need to go to metal mart for some steel
D3vilduck
#1532
Looking good. The foam board is a great idea.
I can't remember how the 4Runner frame compares to a pickup, but if possible I would suggest adding a couple mount points to the underside of the frame. They will help prevent the bumper from slipping on the mounting bolts and pushing up in to the body.
Something like this:
OVRAROK
Quote from: D3vilduck on January 09, 2023, 05:41:14 PM
I learned the hard way with the last rear bumper. Damaged my tailgate. Ill be welding this one to frame
D3vilduck
OVRAROK
Found a guy pretty close by with water jet for frame to bumper brackets.
Making a little progress.
Rockcrawlintoy
Quote from: OVRAROK on January 29, 2023, 05:15:15 AM
Too bad you were not closer to chicoZ my bro has a plasma table and needs projects to learn the programming
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
OVRAROK
Quote from: Rockcrawlintoy on January 31, 2023, 05:23:01 PM
My template is in foam board. I could mail it to him
OVRAROK
I'm taking advantage of this 70° weather, was able to prime and paint my 5lb propane mount. Ordered some powertank rollbar mounts.
OVRAROK
Well, my patience was running dry.  Every lead I had to have brackets made, all seemed to be dead ends. 1 guy wanted a dfx. File. The rest where just blowing smoke.
So I decided just to purchase 1/4 sheet of 1/2" A36.
Should have plenty of bracket material..HAHA..
OVRAROK
Making slow progress on bumper brackets..
OVRAROK
Done for the day, should have these done tomorrow
OVRAROK
Just need to drill out holes.
Maui86
OVRAROK
Holes are drilled. Just need the weather to let up for a half day, so I can get bolted into frame to take measurements.
I'll most likely sandblast them just to get that coating off..
Ritchie
I like your consistent quality needs... I do the same thing.
Great bracket work.
'03 Step side Pre-runner, F/R 4WU 3 linked, F/R Diamond axles, F/R ARB's w/5.29's, F/R Fox 12" CO's, ShrockWorks front bumper, self made rear bumper, WARN M8000S w/ remote, 4.7 Inchworm Lefty, MC sliders that hold air & a bunch of other stuff.
OVRAROK
Was able to test fit into frame. Fitment was more then acceptable. Didn't like the square-ness around the 7/8"holes. Decided to round off..
Ran them through the sandblaster, then 120 grit. Good to go..
OVRAROK
Making progress..
OVRAROK
My rear bumper is done, just needs paint.
a1gemmel
Are you going to add any triangulation to avoid it being tweaked to the side from a hit or off-angle recovery pull?
1981 Pickup - 35s, 5.29s, W56, dual ultimate, e-locker front, grizzly rear, 22R stroker, 3 linked on airbags
OVRAROK
Quote from: a1gemmel on March 20, 2023, 12:51:59 PM
The brackets are 1/2" thick. 2x3 main bar is 3/16. 1/2" plugs at the ends. Im not to worried about it. I mainly built because I need a trailer hitch.
I think the bumper will take the abuse.
OVRAROK
Primered. And painted. I used rustoleum professional primer, and semi gloss black.
cbeers
it came out great Dave!
:beerchug:
CB
OVRAROK
Bumper is on. Bolted, and welded. Just need to paint weld from bumper to frame. Tailgate opens with 3/8" gap.
Cheesemaker
Sick bumper.   :thumbs:  I want one like that for my truck.  I have been looking for a hitch for my truck, but most of the aftermarket stuff hangs way too low.  I tow alot with my stock bumper, and one day, I am pushing my luck with it.
OVRAROK
Had this transfercase laying around, today just seemed like a good day to R&R this thing. New toyota parts where necessary, .., gaskets, seals, o rings, bolts. Input bearing replaced.
OVRAROK
Half doors are painted, just waiting on new door seals for them..
mudmaster
Time to go wheelin!
:)bestgen4runner
Just caught up on this build thread. WOW! Such great work and skills on display.
Can't believe all the changes. Great job!  :thumbs:
I am 1/5th of Perfect Fit
OVRAROK
Quote from: :)bestgen4runner on May 01, 2023, 12:21:34 PM
Thank you Sir.
