OVRAROK. My 87 4runner
OVRAROK
Broke down the leaf springs. Cleaned up, primered. Waiting on new spring pins. Will assemble, then paint semi gloss  black.
Sent from my SM-G998U using Tapatalk
OVRAROK
Frame is done. Just waiting on parts at this point.  Got my axle perches set.
cbeers
this trailer is getting the attention
your 4Runner may be jealous!
looks great Dave  :beerchug:
CB
a1gemmel
I'm kind of late here, but what are your thoughts on adding a 2" receiver to the back that ties through to the shock crossmember? I've seen it done on other offroad trailers, gives you the option to add a bike rack or other accessories, as well as having a rear recovery point for you or for pulling the guy behind you.
1981 Pickup - 35s, 5.29s, W56, dual ultimate, e-locker front, grizzly rear, 22R stroker, 3 linked on airbags
OVRAROK
Quote from: a1gemmel on October 06, 2023, 08:08:20 PM
Sounds like a great idea. However, past that part of the build. Definitely something to think about in the future.
OVRAROK
Made some more progress. Just need to weld shock mounts on rear axle. Tear down  Prep and clean rear housing..  seems a little tall. May have to pull overload spring. Looks like 8 inch travel shocks will be ideal.
Snowtoy
Looks like the shackle angle changed, did you reuse the 2wd springs or another set?
OVRAROK
Quote from: Snowtoy on October 08, 2023, 11:37:36 PM
I re used the original springs. I think im going cut rear shackle frame mount off, Move forward an inch and a half. If you look in a few pics when I first got it, the shackles look about the same. I did shave approx 25 to 30 lbs of unnecessary stuff off.
OVRAROK
Made 2 shock mounts. Had 2 ruffstuff  shock mounts here. The shocks I purchased where the cheapest I could find. 13.61 each. This way I could set shock mounts. Got upper and lower mounts welded on. Primed, and painted rear housing. Waiting for it to dry. Just need new seals and o ring for axle, and some gear oil. Hoping to use it by monday.
OVRAROK
Almost done. Just need to get some chains.
OVRAROK
Got the chains welded on to the trailer. Took it to the lake today.
helipilot77
Another incredible project my friend. I can't wait to see what is next.
OOPS
Are you going to put a different hitch set-up on it, pintle or 360? That is what I see on off-road trailers!!
OVRAROK
Quote from: OOPS on October 28, 2023, 12:57:55 PM
Yes, in the near future. Needed to make a couple dump runs, so my main priority was getting it cleaned up and usable.
OVRAROK
I re purposed my old bed frame.
OVRAROK
Making those rubber pieces that fill the gap between frame and body. Only had 1 side, used as template Purchased some 1/16" thick rubber.
OVRAROK
Sometimes I just make things..the base is a rear drum, then a vented front rotor, then a rear solid rotor. The vented rotor pulls air. Just need to make a door for it
OVRAROK
All tack welded. Just need to finish welding, clean up and paint. Can't wait to get it indoors
OVRAROK
I think it need additional air flow from lower axle housing. Just doesn't seem to burn hot enough. Going to add adjustable air flow at lower axle tube. Go from there.
a1gemmel
A small air pump would do wonders. That's a darn cool use of an old housing.
OVRAROK
Finished up the main stove. I have a flange off the axle that I'll use to attach exhaust pipe.  Painted with wood stove paint.
OVRAROK
Night time shot.
Slabzilla
Your trailer is both awesome and beautiful,  mine sucks big wind by comparrison, I'm hiding mine for a while out back under a tarp for a while.  Not your fault, just not happy with mine at the moment.   :_oops:
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
helipilot77
I feel your pain Slabzilla. We all can't beas cool as Overarock.
OVRAROK
Picked up another t case for a reasonable price. Tear down and cleaning has started. Ordered seals and gaskets from MC.
Sent from my SM-S928U using Tapatalk
OVRAROK
Finished transfercase.
OVRAROK
T/C off to it's new owner. Picked up a 23 spline adapter from AA. Building a set of duals. Mocked up my kayak rack for the trailer.
OVRAROK
Balance shaft delete showed up, and I almost finished a set duals. Just need to clean up shifters.
OVRAROK
Found another.. needs 2 bearings, new gaskets, and seals.
