OVRAROK. My 87 4runner
0 Members and 28 Guests are viewing this topic.
redneckcustoms13
Mine with 4.56 and 33s measuring 32.875 has never gotten over 14. Now on 40s and 4.88 gears it's still 14.
01 double cab hunting truck
06 tacoma street truck
OVRAROK
Picked up another rear axle..also picked up rear truss from ruffstuff..
Sent from my SM-G975U using Tapatalk
helipilot77
Dog photo bomb!
OVRAROK
New perches...just a bit more BEEF.
:)bestgen4runner
I must have missed it but why are You replacing the rear housing?
I am 1/5th of Perfect Fit
OVRAROK
I'm pushing my axle back another 2 to 3 inches..new rear truss. And some new paint..This way my 4runner isn't down but a couple hours..
mudmaster
What are the side plates on the perches for?
Time to go wheelin!
OVRAROK
Quote from: mudmaster on December 27, 2019, 04:07:48 AM
No more U bolts..
cbeers
NOW I get it....didn't know you were going ubolt eliminators!
interesred how you like them. i saw big mike did them on his 1st gen but for some reason I thought he went back?
suuuure pushes that axle back!
lookin' good sir   :beerchug:
CB
OVRAROK
Stripped down the rear housing.. made a little jig that allows me to set the perch angle..the nylon ratchet strap holds the housing..allows me to turn to whatever angle..and jackstands holding perches allow me to adjust angle..now to get measurements off current housing....
cbeers
would it be the same angle if you are changing tire size?
:dunno:
CB
dementia
Quote from: cbeers on December 29, 2019, 06:06:41 AM
:dunno:
CB
Lmao! retard alert!
swilson
Quote from: dementia on December 29, 2019, 09:36:17 AM
Lmao! retard alert!
Ok, or just a new guy trying to figure this stuff out.
I did get a chuckle out of the comment though [emoji23]
Scott Wilson - TLCA #5261
1966 FJ40 [sold] - Click for Build thread
1988 3RZ 4Runner - Click for Build thread
1964 FJ40 TBD
OVRAROK
I do believe that moving rear axle BACK...will come into play...with the U- bolt setup it was easy... I could tack weld perches..snug u bolts..then with 3rd member installed I could snap tack welds with floor jack..what worked for me was lining up rear diff with rear output on transfercase..then I moved diff 2° down..
The more I dwell on this..I may keep perches tacked..Jimmy up a u bolt temp gig..let everything rest on it's on weight with half my gear in it..then line everything up..and drop diff 2°...
Rockcrawlintoy
:dunno:
CB
Tires size doesn't change the pinion angle
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
toyodaaddict
Ive never seen offset perches like that, did you make them?
dementia
cbeers
Quote from: swilson on December 29, 2019, 09:45:35 AM
more that but happy to add a laugh.
:beer:
CB
dementia
Quote from: cbeers on December 29, 2019, 09:46:12 PM
:beer:
CB
New guy? Member since 2014??
OVRAROK
New tires are on... I had to make 2 trips to the tire store to pick everything up..when I was unloading first 2 new tires at home..I noticed that there was NOT any weights on them..so I called to make sure they balanced them..guy said yeah...all 4 tires have NO wheel weights..as far as ride...holy smokes these things are quiet...I mean ridiculous quiet..
Rockcrawlintoy
Quote from: OVRAROK on December 30, 2019, 03:12:59 PM
Those look great!!!
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Dingman.
OVRAROK
:)bestgen4runner
How deep are the tread lugs ? 16/32?
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
helipilot77
Now that you will be moving the rear axle back (which I think is a great idea) does that mean some sheet metal will be modified at the rear part of the fender flare? Any plans for a rear bumper in the near future?
OVRAROK
Quote from: helipilot77 on January 04, 2020, 07:53:22 PM
The plan is to push axle back... gain some departure angle..clearance body.. then Make rear bumper...
cbeers
 did your old bumper push up into the tailgate or was it just your pinion angle was off?
:gap:
CB
OVRAROK
Quote from: cbeers on January 05, 2020, 05:07:39 PM
:gap:
CB
The rear bumper was on my 4runner when I first bought it..The first year I went to MCR..I found out that is was just bolted down..it tweaked my tailgate bad..
warrpath4x4
are those Milestar Patagonia's? I am looking at getting a set in 35"
