OVRAROK. My 87 4runner
Dingman.
Now you need to link it and have the shock hoops poking through the hood too :bling:
OVRAROK
Steering is done. Just need to make another hole in hood. Have another hood on its way...
Sent from my SM-G975U using Tapatalk
mudmaster
Time to go wheelin!
OVRAROK
gnob
Can you seriously not fit the reservoir under the hood?
hold this. . .
OVRAROK
Quote from: gnob on July 02, 2019, 10:51:37 AM
I could fit it under, but the reservoir would be lower then pump.
OVRAROK
Hood is done...
gnob
Only the fluid level needs to be above, not the whole thing.
hold this. . .
OVRAROK
Quote from: gnob on July 02, 2019, 11:19:53 AM
Well shoot..
Now you have me thinking.., I may try and lower before hood gets here..
gnob
Check out swilsons 4runner
hold this. . .
gnob
I know its not an RZ, but how i did mine.
hold this. . .
mudmaster
Mine is under the hood
Time to go wheelin!
mudmaster
I had problems with the tube clamp sliding too. Mine is now welded on.
Time to go wheelin!
emsvitil
You could make a hood scoop.............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OVRAROK
After speaking with PSC. I decided for the time being. I will keep my reservoir where its at...   it works great, with no problems. He explained to be that the pump is great at moving fluid, but if its constantly has to pull the fluid. It will shorten the life of pump..after staring at it for awhile, I think that the chilkat PS pump bracket can be improved on.
OVRAROK
Here's a couple pics..
OVRAROK
My front driveshaft was hitting my exhaust. So I made another exhaust pipe.
LittleSteve
Quote from: emsvitil on July 02, 2019, 04:57:59 PM
I know a guy that used baking trays to cover up stuff poking through his hood, i can find pictures...
Refusing to fit in or comply.
Easy is not worth anything.
OVRAROK
Finally got around to installing new clutch hydraulic system. New master, and slave. Painted with brake caliper paint. Made a -3 AN stainless steel line for it.
OVRAROK
Just waiting on some ATE dot 4 fluid..
swilson
Quote from: OVRAROK on July 02, 2019, 11:04:49 AM
Hood is done...
What is going on here???
3-4" is not going to have any significant impact on the life of your pump... But totally destroys the clean look you had going
Sorry to be negative. I really appreciate clean rigs
Scott Wilson - TLCA #5261
1966 FJ40 [sold] - Click for Build thread
1988 3RZ 4Runner - Click for Build thread
1964 FJ40 TBD
OVRAROK
I'm making a new PS bracket. New one should allow pump to be mounted lower. So I can lower reservoir. Those pics are of my first attemp..right now reservoir is barely poking out.. :thumbs:
swilson
I just took a look through your build thread... You do great work!
1964 FJ40 TBD
OVRAROK
Quote from: swilson on August 31, 2019, 10:13:49 PM
Thank you sir...
OVRAROK
Moved my bank 1 o2 sensor..gained almost 3 mpg.
swilson
How/why did you decide to move it?  Did you dyno the truck to get the HP number?
1964 FJ40 TBD
OVRAROK
Quote from: swilson on December 19, 2019, 08:49:58 AM
When I built exhaust, I wasn't thinking to much about location..afterwards..I felt that my 4runner was running rich..I thought what the heck. I'm going to move it as close to exhaust manifold. As far as knowing HOW I know mileage has improved..is i have scan gauge permanently mounted where altimeter used to be.. I dont drive on hwy much..but I went from 13 mph avg to 16.8...
swilson
Best I can get on my swap is 14mpg...  Miles divided by gallons, not scan gauge.  I thought it would be a little better, not that it really matters. It'll go across the Rubicon twice in a tank or gas [emoji16] That's good enough
1964 FJ40 TBD
OVRAROK
Quote from: swilson on December 19, 2019, 09:12:20 AM
You on 37s?.. I'm on 15% left 35s..getting ready for new rubber..38s. Maybe I'll lose a few mpg,
swilson
Yes 37s.  3RZ does well with them, except for long hills at freeway speeds
1964 FJ40 TBD
