0 Members and 20 Guests are viewing this topic.
EVAPI know what vacuum lines you are talking about. I will take some pictures tomorrow morning when I get off of work.
So I've got the 95.5 model year tacoma engine, it has a distruibutor. Which can not be timed. What I mean by that is, its computer controled. it only allows you to move it so much. You dont need to mess with that thing at all. Personnaly I think you should put everything back to stock and work your way through the codes one at a time. You may have a cracked head.
So that leaves using the RE tank splicing in the RZ wiring pigtails. So now all I need to do is:1: Figure out which wires are for what. That shouldn't be too difficult.2: Figure out if the RE fuel sender will work with a Taco fuel gauge.3: Bolts right up!?!?
Or maybe this-Put tank on left side of truck, build new mounts, make hole in box for filler, run the Taco fuel lines down the left side away from the exhaust and to the correct side of the motor. Run exhaust down right side and not worry about a crossover pipe clearing everything.
I did more measuring today, even laid the Taco fuel lines in place. Yes, this is the way I'm going to do it.
If you are in CA call the smog referee first. So many nit picky laws.
I have a 96 Taco 2RZ, it has a round steel EVAP canister. Where does the vent line coming out of the bottom of the canister go?
This may have been covered but Im not about to read through 22 pages of 3rz stuff. Im looking for a custom wiring harness for the 3rz like offroad solutions used to make. anything???
Finally finished my 3rz swap into my 85 4runner. I went to start it tonight and the starter is binding. The motor is out of a 98 taco and the bell housing came with it. The starter is a reman from o'reily's. It bolts on fine but when I turn the ignition it turns a few times and makes a slapping sound like its not fully engaging the fly wheel then binds up.I removed it and replaced it twice, trying to line it up but same thing happened each time.Has anyone had this happen to them, any suggestions?
Started by cruzila « 1 2 ... 32 33 » Rig Gallery
Started by yotaboy79 « 1 2 ... 32 33 » Chit Chat Camp
Started by BLACKDOG « 1 2 ... 11 12 » Chit Chat Camp
Started by Willy Mammoth « 1 2 3 4 5 » Chit Chat Camp
Started by Rocksurfer Chit Chat Camp
