SqWADoosh's 85 Runner Build Thread
Started by SqWADoosh, December 03, 2014, 12:07:54 PM
Quote from: SqWADoosh on March 10, 2016, 07:26:14 PM
My soft top from Killer Toy Tops is arriving on Saturday as well as my ARP studs from FROR. Going to spend that day getting those installed and then I'm off to Walker Valley for a 2 year anniversary of the first trip out with the runner.  :smokin:
Don't poke a hole in that top on the first run! 🌲
SqWADoosh
Quote from: blackdiamond on March 10, 2016, 09:08:47 PM
Your confidence in me is soothing  :slap:
mudmaster
Time to go wheelin!
ChadStich
What power steering pump did you go with? Im doing a 3rz swap now and would like to get rid of the factory pump.
94 2wd extra cab sas, 3rz, 4.30 e-lockers f/r, dual stock cases with marlin adapter, longs, 35s, RUF, Chevy 63's
http://board.marlincrawler.com/index.php?topic=99269.0
SqWADoosh
Quote from: ChadStich on March 11, 2016, 09:31:02 AM
Get this one http://www.lowrangeoffroad.com/toyota-off-road-parts/79-95-4runner-hilux-pickup/steering/psc-motorsports-tc-style-power-steering-pump-1600-psi-4-5-gpm-psc-sp1200x.html
Its the one I should have got and I will be upgrading my upgrade to  :smack:
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
SqWADoosh
Quote from: RockcrawlinJK on March 11, 2016, 10:54:24 AM
I thought you returned the one you got an ordered the PSC pump instead
I was going to but at the last minute decided not to.
Quote from: SqWADoosh on March 11, 2016, 07:36:00 AM
I have never run my top off road in WA so have not had to contend with trees much with it.  Just one more thing to watch for.
SqWADoosh
Quote from: blackdiamond on March 11, 2016, 11:48:08 AM
Looking like we are going to postpone until next weekend. The weather is supposed to be very nice then.
Quote from: SqWADoosh on March 11, 2016, 11:53:04 AM
That'll give you more time to get the ARP stuff (that I'm very excited about) and the soft top installed.  When do you anticipate the stuff being delivered on Saturday?
SqWADoosh
Quote from: blackdiamond on March 11, 2016, 11:57:19 AM
Well the ARP studs are coming in the mail so early afternoon on those. No telling on the soft top.
SqWADoosh
Nevermind the ARP studs were here today when I checked the mail. I'm gonna be able to get them done first thing in the morning.  :yesnod:
J_Cole92
http://www.pirate4x4.com/forum/toyota-truck-4runner/630765-installing-tc-saginaw-pump-toyota-22r-cheap.html
or get this one. Its the exact same pump as the PSC. A Saginaw TC style pump is what the PSC and Trail Gear both use. Notice they look exactly the same. I bought mine from auto zone for $78 modified it and its been working awesome. Just my thoughts. Runners looking good!  :smokin:
92 4Runner built on Toyota axles
84 Xtra Cab stock Daily Driver
55 Willy's Pickup Cab
Can't find it grind it
4runner build: http://board.marlincrawler.com/index.php?topic=96221.0
SqWADoosh
Quote from: J_Cole92 on March 12, 2016, 08:30:07 AM
That is the one that I am running. The PSC version has been heavily changed.
SqWADoosh
48. Replace steering knuckle studs with ARP studs
Well I spent the day working on the truck. I started by installing my new ARP studs in my knuckles. Went easy enough, utilizing the two nut method to remove stock studs and install new ones.
After I got that done I moved on to replacing my 10" Bilsteins in the rear with 12"s. Should get me where I want to be with my droop in the rear.
I also went and got some abrasion guard or whatever the hell you call this stuff, and put it around all my new hydraulic lines.
Also my killer toy top showed up
So after all this I go to pull my truck out of the garage to pull my hard top off and put my new soft top on. My steering is fighting me when attempting to turn right. I don't understand what I could have done. I think it is just a coincidence that it happened when it did and I'm thinking it is an air bubble in my ram or something to do with the hydro assist. Its fighting me when the truck isn't moving. I took it for a drive and it did fine on the road turning right. I was exhausted and decided to call it a night. I'm going to try and figure it out in the morning. I took the cap off of the reservoir and I'm hoping it will bleed some more tonight.  :dunno: I'm open to suggestions on what I could have done to cause this while upgrading my studs.
cant wait to see that top on there, that's going to look nice :drooling:
Quote from: ovrarok on March 12, 2016, 06:37:57 PM
Me too.  I am curious to see what, if anything, is different from mine.  It is supposed to be updated, but the pictures on the website are the same ones from when I got mine.
SqWADoosh
So after sleeping on it I thought of one possibility. I found a loose castle nut on one of my tie rod ends. I tightened it down. I'm wondering if it is possible to over tighten the TRE to the point that it would cause my difficulty turning right?
Quote from: SqWADoosh on March 13, 2016, 10:55:39 AM
no, I don't think that's possible, the TRE is tapered, unless the tapered diameter was to small or the hole on steering arm was wallowed out
how does castle nut come loose ?, was the cotter pin missing  :headscratch:
SqWADoosh
Quote from: ovrarok on March 13, 2016, 11:08:51 AM
No it had the cotter pin still. It was loose down to the cotter pin.
SqWADoosh
So I tried troubleshooting some more today. I took the ram off and checked its function. It is working properly. I removed the TRE that I suspected I had overtightened, and re-torqued it to spec. That didn't solve it either. I am completely lost on this one.  :inthedark:
Quote from: SqWADoosh on March 13, 2016, 01:12:04 PM
Does it turn fine on jack stands or just with weight on the ground?  Did it turn ok with the ram removed?
SqWADoosh
Quote from: blackdiamond on March 13, 2016, 01:33:49 PM
It turned the same with the ram removed.
Quote from: SqWADoosh on March 13, 2016, 01:35:00 PM
Sounds like it is unrelated to the ram then.
Any chance the steering stabilizer developed a hitch?
SqWADoosh
Quote from: blackdiamond on March 13, 2016, 02:01:42 PM
Steering stabilizer was removed when I did the hydro.
Quote from: SqWADoosh on March 13, 2016, 02:03:09 PM
Is it continuous restistance or a bump that you can get past?
megaphoneman
did you just remove the ram from steering? or did you pull it and plug lines? if your testing with the truck on? you have a bad seal in your ram.. allowing fluid to work against it self.. if you the truck is off i would remover the TRE at the pitman arm and see if you have that same issue did you over tighten or shim it wrong with the new studs
Blaaaahhhhhhhh
SqWADoosh
Quote from: megaphoneman on March 13, 2016, 02:25:25 PM
Blaaaahhhhhhhh
I'm having a hard time understanding a lot of that mega. I unbolted the ram from the tie rod and tested it with it still bolted to the bracket on the axle. I used the same shims as were beneath the arms before. I tightened to 71 foot pounds as is called out.
SqWADoosh
Took apart the right side again. Ensured that I wasn't crazy and that the shims were there and that there wasn't anything wrong with the trunion. I then tested the movement of the knuckle when not attached to the steering. It moved very easily as it should. I then buttoned everything back up and the problem seems to be gone.  :dunno:
