SqWADoosh's 85 Runner Build Thread
Started by SqWADoosh, December 03, 2014, 12:07:54 PM
OVRAROK
maybe the arm wasn't laying flat :dunno:
SqWADoosh
mdtrail-toy
Craziest thing how that happens but I know I've had the same situation. Have a problem, can't reasonably figure it so just take it apart, find nothing , but yet you fixed it :smack:  That's one of those things that could drive you nuts...
megaphoneman
sorry man...im def retarded when it comes to the English language..
what i am saying is if the ram is still attached to the lines and you are testing this out with the truck running, and your having an issue...then most likely you have a seal inside the ram that is going..it will allow pressure from both sides of the ram to work against each other... the only other thing i could have thought of is you messed with the caps, and trunion bearings...
anyways..if your having the issues still and the ram is connected to the pressure lines and you started the truck to test it, then its the ram...
ChadStich
Quote from: SqWADoosh on March 12, 2016, 08:32:46 AM
That is the one that I am running. The PSC version has been heavily changed.
With the pump your running now does the steering lag with ram assist?
94 2wd extra cab sas, 3rz, 4.30 e-lockers f/r, dual stock cases with marlin adapter, longs, 35s, RUF, Chevy 63's
http://board.marlincrawler.com/index.php?topic=99269.0
SqWADoosh
Quote from: ChadStich on March 13, 2016, 11:12:27 PM
I haven't had a chance to wheel with it yet but yeah the steering does seem laggy/less easy than I think it should be.
SqWADoosh
So when I greased the steering arm male end that goes into the trunion bearing some got on the mating flange of the steering arm as well. Could this have caused it? The grease between the mating flange of the arm and knuckle?
Rockcrawlintoy
all the hydro I had driven has always had a little bit of lag esp with quick steering movements.
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
OVRAROK
Quote from: SqWADoosh on March 14, 2016, 08:01:32 AM
I don't think so, unless there was debris in the grease
Dingman.
 You could imagine dirt and such as extra thickness, simliar to adding another shim.  Adding shims decrease preload and make it easier to turn.
SqWADoosh
Well I was wrong the problem persists. Though it is not as bad as before.
mudmaster
Are you sure all the air is bled out?
Time to go wheelin!
SqWADoosh
Quote from: liveoak on March 15, 2016, 08:52:49 AM
try tightening the PS belt some more?   :crossed:
It is tight.
Quote from: mudmaster on March 15, 2016, 09:06:55 AM
Pretty sure. No bubbles, ram is functioning properly in both directions, and the steering to the left is good.
Rockcrawlintoy
Did you ever take off the drag link and eliminate the box as the culprit or the tie rod to narrow down what size it is
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
SqWADoosh
Quote from: RockcrawlinJK on March 15, 2016, 09:34:24 AM
No i plan on doing that in the next couple days. Need to get a pickle fork.
John Doe
I used a pickle fork for a good few years until recently using a buddies tie-rod removal (similar to pictured) I will never use a pickle fork for a tie-rod again!
H8PVMNT
Did you try just beating on things with a mallet?  Sometimes that really works.
– Steve McQueen
H8PVMNT
Actually in all seriousness, after using the pickle fork and a TRE tool, I have the best success on tie rod ends with a nice hefty brass drift on the slightly loosened castle nut, backed off  like 1/16" or so, then give the drift a good whack with a hammer and the taper unseats itself.  The brass is soft and won't mangle anything. Everybody needs a good brass drift in their trail box.
– Steve McQueen
SqWADoosh
Quote from: H8PVMNT on March 16, 2016, 07:15:27 AM
Oh I've got a brass drift alright. That's a good idea. Hey go buy in on the dates in the pnw mini roundup thread, would ya?
SqWADoosh
49. Install soft top (Killer Toy Tops)
Axman
Now take it through the car wash to test its water permeability!  :gap:
I did this once in high school with the old mans soft top on his jeep, let me tell you, zippers are not water proof to jets of water...  :yupyup:
1984 Toyota Ext Cab
- 22r Weber 38, Offy intake, header & full exhaust, 9.5:1, ported and oversized valves
- 36x13.5 Irok bias, 4.56, spool & Detroit, Dual Cases, Longfield Birfs
blackdiamond
Looks good. How about a picture of the back?  First impressions?
SqWADoosh
Quote from: blackdiamond on March 16, 2016, 08:41:37 PM
I'm for the most part happy. Definitely some gaps where water is going to get in though. We will see how bad it is this week and next. Its going to get some rain. I'll take a pic of the back tomorrow.
blackdiamond
Quote from: SqWADoosh on March 16, 2016, 08:44:45 PM
I can see a couple of minor differences.
I would assume the potential leaks are around the rear window?  My Velcro rear window is a pain to put in, but it keeps it weather tight.
SqWADoosh
Quote from: blackdiamond on March 16, 2016, 08:48:22 PM
No actually that area looks very good. It is around where it mounts to the cab.
blackdiamond
Quote from: SqWADoosh on March 16, 2016, 08:56:49 PM
Interesting, I have never had any issues so you may be ok. The top has a Velcro strip at the cab that is several inches wide. I have had the Velcro come loose on one of the side panels but I am pretty sure it is a "one of" type of deal. It was just the bottom corner than came loose.
blackdiamond
What brake upgrade are you looking at doing?  Did the weight and size of the PBRs have a significant impact on your braking?
When was the last time you rebuilt your front axles?  I would guess that you had completely overhauled everything since you've owned your truck which mean within the past couple years, right?  I know next to nothing about trunion bearings, but I'm assuming that the theory is that something happened while installing the ARP studs or just unlucky timing or the bigger tires and hydro steering pushed it over the edge?
SqWADoosh
#927
Quote from: blackdiamond on March 17, 2016, 11:26:50 AM
Yes the knuckles were rebuilt when I did my elockers. Very recently. This is a foul up on my end of not seating the arm in the bearing when doing the ARP studs. I'll find out for sure tonight.
I'm going to do IFS hub swap and 02 tacoma rotors and brakes on the FROR bracket.
SqWADoosh
Went and got a ball joint/tie rod separator from Harbor Freight today after work and got into finding out what the hell is going on with my steering. Started by pulling tie rod off right steering arm and jacking up that wheel and checking for resistance in that knuckle when turning wheel both ways. No resistance at all. I then disconnected the Drag link from the pitman arm. Turned wonderfully with no resistance both ways. I then went to the right knuckle. Here are the results:
Dingman.
Remove the felt rings off the back, the clip off your birfield (if you have this), and the high steer arm.  You can pull the whole knuckle off the axle ball this way.  Inspect the trunnions and let us know how they look!
