SqWADoosh's 85 Runner Build Thread
Started by SqWADoosh, December 03, 2014, 12:07:54 PM
blackdiamond
Quote from: SqWADoosh on December 22, 2015, 10:12:30 PM
This all started when I put duals in. Putting the driveshaft into phase didn't change anything. Next up to try is to drop the crossmember to the lower position so that my cases are not contacting the body.
I'll have to check this.
How is your driveshaft marked?  My High Angle driveshafts have red arrows to make easy to know which way they go.
If the transfer cases are contacting the body I would expect vibration. If it's light contact the weight of a passenger just might be enough to damp it. I suspect you'll resolve the issue by lowering the crossmember.
redneckcustoms13
Also what mount are you using for the tcase?
01 double cab hunting truck
06 tacoma street truck
SqWADoosh
SqWADoosh
daniresch
SqWADoosh
Quote from: daniresch on December 23, 2015, 02:52:50 PM
making room for 37s right? :)
Eventually. The immediate need is to clear my damaged passenger rear fender from my flop this summer. It is starting to rust and is unsightly.
Dingman.
Just spray some wd40 on it and wheel on!!
:jk:
blackdiamond
Quote from: SqWADoosh on December 23, 2015, 02:25:37 PM
Going to attempt to trim my fenders this weekend. Going to follow this guy's method: http://www.pirate4x4.com/forum/toyota-truck-4runner/1048224-4runner-rear-fender-cut.html  :crazy:
Looks like a good way to go.  Hope it goes smoothly for you.
redneckcustoms13
Doesn't that mount use poly bushings? If so did you run that before the vibrations started? I noticed mine vibes a bit especially at idle with the poly mounts on the tcase.
SqWADoosh
Spent the day trimming 2" out of my rear fenders today to remove damage from my flop as well as part of the preparation for 37s.  :willynilly:
Going to let the seam sealer dry over night then hit that with some sand paper in the morning followed up by paint.
blackdiamond
SqWADoosh
Quote from: blackdiamond on December 27, 2015, 08:50:26 PM
Looks to be turning out well.
All of my damage/dents made it very difficult and it is not going to turn out very clean because of it. Oh well though  :dunno:
redneckcustoms13
Looks good to me. It's amazing how good of shape yalls vehicles are up there in the snow environment. Normally the salt kills vehicles how do you guys find them that nice
SqWADoosh
Quote from: redneckcustoms13 on December 27, 2015, 09:15:47 PM
West coast doesn't use salt. Thats why.  :thumbs:
OVRAROK
SKULLYOTA
such a cool build thread.  I wish I would've kept and SAS'd my 4runner now  :rivers:
85 x-cab- duals, flatbed, locked, 33's....
70 FJ55-in pieces
SqWADoosh
Quote from: ovrarok on December 28, 2015, 06:09:57 AM
looking good andrew :thumbs:
Thanks Dave.
Quote from: SKULLYOTA on December 28, 2015, 12:29:20 PM
Thanks, man.
H8PVMNT
Lookin good, keep it up.  Custom body work is time consuming but worth the effort.  I have a bit of a stretched wheel base and I had to lengthen my rear wheel wells. Seam sealer is cool.
– Steve McQueen
daniresch
Looks like you got most of the dents out!
what do you plan on using for paint, black or color matched red?
zippo
Make sure you go from the inside and por 15 the weld!
If you see it, its for sale.
SqWADoosh
Quote from: zippo on December 29, 2015, 08:38:39 AM
I used seam sealer.
SqWADoosh
Finished up my fenders yesterday as well as got some more armor refresh done.
My rear bumper was in really bad shape. Had to grind away a lot of rust from rock rash that I let sit for too long. Got it all out though and looks like new.  :yesnod:
BigBluePile
Definitely something I need to do to all my tube.  Repaint because it looks terrible.  Lol.  Nice job!
Sent from my 0PJA2 using Tapatalk
'86 4Runner SR5 TRD 5VZ-FE
...slightly modified from OEM...
84_yota_4wd
 :biggthumpup: I dig it man! Its time consuming but worth it
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
SqWADoosh
So I'm finishing up my armor refresh in my last couple days of my break. Next up on the road to 37s is going to be a steering overhaul. I need a new pump first and foremost. I will be utilizing this method which uses the Chillkat TC bracket coupled with an Autozone sourced TC pump. Then I will need to source a separate reservoir for the new pump as well as some new lines to run it all. This will solve my whining 3rz pump as well as give me extra power for turning my 37s. At the same time I'd like to solve my pitman arm hitting my springs problem which I will solve with the Sky's 3/4 less drop pitman arm. I'm not sure what is going to need to be done to clear the 37s in my front wheel wells. I'm hoping that I can further pound the :pokinit: out of the pinch weld and that will do the trick.  :crossed: Other things I'm looking at is doing the IFS hub swap + taco or FJ cruiser brake upgrade. It is all going to boil down to what the tax man giveth back to me next month and what I can allocate to the truck before April.
SqWADoosh
#715
Ugh I'm so close to being done. Got the other slider done and my front bumper. All that is left is my axles now.
:_order:
BigBluePile
I'd need a nice warm day out to clean all my metal off to prep for paint.  Looks good!
SqWADoosh
Quote from: BigBluePile on January 03, 2016, 12:42:22 PM
Or you can just close yourself in your garage and turn the heater on for like 5 hours and breathe in fumes! YAY!   :hammerhead:
redneckcustoms13
Just get you an old school smut pot and roll it around where your working.
SqWADoosh
That must be a southern thing...No idea what you are talking about.  :conf:
