0 Members and 11 Guests are viewing this topic.
So I measured for the 3rd time yesterday. This time with my new rear shaft actually on the vehicle rather than doing the broomstick method. My number for the amount of rotation needed is 9.5* from where it stands now. Taking into account my current 2* shim that puts me at a final total of 11.5*. This is far too large of a shim to run in my opinion.
Agree on the angle being too high, but the angle of the installed driveshaft will be higher than a measurement between the flanges because the u-joint at the differential will shift the point of angle over several inches.
It was only a difference of a degree so it really isn't going to effect much. Bottom line is that I need to have the pinion rotated rather than shim.
get some perches, we'll do it
You've got an overflowing plate as it is. Especially if you are coming later.
I like to eat big meals, then dessert
Do you have a plan yet for rear differential rotation?
Yes, me and zippo will be tackling it this weekend. Going to try and solve my up travel as well.
How many sticks does one man need?Looks good!
I'm rocking 5
i don't care where you got the parts, I want to know where you got that zippo. I need one of those.
How many transmissions do you have?
But wont your boots leak now?
nice, thats why i always go High angle for my driveline needs....because i want that baller paint they use lolnow that u have duals i want to see some double low full throttle assaults.
What is the big puffy black thing on the left?
I will try and remember to check If I still have a spare when I get home. Save you a lot of room.
hey Andrew, I just ordered and received the same Nippon radiator that you got. looks identical only problem is that its advertised as a dual core 2 row and looking inside it only has a single core. have you looked inside yours to verify? It appears this radiator is the same one low range was selling for $79 last year. I contacted the seller in Fontana,CA for a return. http://www.ebay.com/itm/151644042831?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Started by trax28to Project Research and Build-Ups
Started by Dingman. « 1 2 ... 58 59 » Project Research and Build-Ups
Started by Yoat Goat General 4WD Discussion
Started by Jason E. « 1 2 » Project Research and Build-Ups
Started by Cheesemaker Chit Chat Camp
