SqWADoosh's 85 Runner Build Thread
Started by SqWADoosh, December 03, 2014, 12:07:54 PM
0 Members and 8 Guests are viewing this topic.
zippo
So SqWADoosh foolishly left some third members at my house, So I  pilled the side gears. Wonder if he will notice? This first diff has bad bearings.
If you see it, its for sale.
SqWADoosh
Quote from: zippo on May 12, 2015, 09:47:54 PM
I appreciate you doing that last night dude. I just placed my order with ECGS to the tune of $1080  :yikes: they are going to be drop shipping it to Performance Cryo which will likely be another couple hundred dollars. Its going to be one spendy set of thirds when it is all said and done. Hopefully should be worth it though! So looking at the picture of the side gears is it just me or are the two pairs different?
zippo
They are two different ones peer diff. It is how it locks a coupler slides over one.
SqWADoosh
I know its been a while since I updated. Its been another case of piling money and handing over my wallet to vendors. Tomorrow and Sunday myself, zippo, and helipilot will be diving into a complete overhaul on my front axle (knuckle rebuild, new RCV axle shafts, new RCV hub gears, Aisin hubs, backing plate eliminators, new elocker 3rd, strip, paint, knuckle gusset, etc.) as well as overhauling my new IFS width rear axle (rebuild, strip, paint, new elocker 3rd, etc.). Time to turn the pile of parts into something   :flamer:
Huge shoutout to Dave Jester at www.jesterfab.com . I just came back from dropping by his shop to pickup my RCV axle shafts and hub gears (for the best price anywhere $612 out the door) and he threw in the knuckle gussets you see above for free. Awesome guy with some great products at great prices. Check him out if you are looking for DIY beadlocks, custom gussets, RCV products, backing plate eliminators, and more.
jangelfire
I advise against the backing plate eliminators.i did that to mine and the damn brakes squeal and squeak and drive me nuts! Next time i pull the rotors im putting mine back on.just my .02
SqWADoosh
Quote from: jangelfire on June 12, 2015, 04:50:47 PM
How did getting rid of the backing plates cause this?
jangelfire
Little rocks and sand or mud get in there.pisses me off!
SqWADoosh
Quote from: jangelfire on June 12, 2015, 05:06:07 PM
Hmmm I thought the whole purpose of these was to prevent that exact thing from happening. Well good looking out. I will throw them on and hold onto my backing plates in case this happens to me as well.
toyodaaddict
I like to trim the stock backing plates, leaving the tab that holds the brake line. I've never had an issue running multiple trucks that way for years.
Those RCV's sure look good. I bought my current Longfields  about 9 months before the whole TG thing went down, but Ive been tempted to buy some RCV's just for the nice '' C' ya mister '' tribute to Bobby  :usa:
SqWADoosh
Quote from: toyodaaddict on June 12, 2015, 05:40:47 PM
Yeah they are pretty damn cool. I've already paid for these eliminators so I'm going to give them a shot.
twistedtoy92
No complaints with my eliminators. Those axles are damn sexy!!! :beerchug:
BigBluePile
That's a sweet pile of parts you got there!!!   One of these days I'll swap in my longs and hi-pinion elocker in mine.  One day.....or year
Sent from my HTCONE using Tapatalk
'86 4Runner SR5 TRD 5VZ-FE
...slightly modified from OEM...
dropzone
i got rid of my backing plates 6 years ago and have never had any issues.
Like Logan said, nice pile o'parts  BBP send me your elocker, my front axle is still stripped while I negotiate with the missus for an ARB, so I guess I can settle for an ELocker
81 Toyota Trekker 221:1
BigBluePile
Quote from: dropzone on June 12, 2015, 11:46:43 PM
Ya right. Took me over six months to track down that elocker!!!!
You just need to buy the ARB and THEN negotiate......[emoji16]
Dingman.
x2 i always cut the stock backing plates to make "eliminators"  i have never had an issue either.
jangelfire
Quote from: Dingman. on June 13, 2015, 01:44:49 PM
Even after gettin her all muddy?
Dingman.
Quote from: jangelfire on June 13, 2015, 02:05:15 PM
Never had any squeaks unless it was from my brake pads needing to be replaced.
Even with my vented/drilled rotors i never had any bad effects yet.
twistedtoy92
I cut my factory ones down as well to save some coin.
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
SqWADoosh
Quote from: RockcrawlinJK on June 13, 2015, 09:29:57 PM
How did the install go?
Its going take us longer than we thought. Only going to be able to get the rear done this weekend.
Rockcrawlintoy
One is better than none. I drove around for like 3 months with no gears locker or front axle shafts before I could get my front gears installed.
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
SqWADoosh
#351
26. TRD ELocker for Rear
27. IFS width rear axle swap (1995 4Runner shafts + 88 housing)
28. Re-gear rear differential to 5.29 (Nitro 5.29 gears via East Coast Gear Supply)
29. Cryo treat 5.29 R&P, side gears, and bearings (Performance Cryogenics)
Worked with HeliPilot and Zippo on my axle overhauls this weekend. We ended up putting in 2 very long days on Saturday and Sunday. In the end our goal of getting the new rear axle built and put in as well as my front was not to be. We did get the rear fully modified, assembled, and bolted into place with the newly built zippo Elocker diff installed. It was a very long and ardous weekend and I can't thank Nate and Jason enough for their help. They are the best friends a guy can have.
Me and Nate convoyed from his house down to Jason's on Saturday morning bright and early. We got stuck into it right away with Jason building the diff while me and Nate worked on the axle housing modifications needed for the 3rd locker to fit. We found out pretty quickly that there was a lot more work involved than we had initially thought. Jason had to fab quite a few custom specialty tools to assemble the diff and we had a hard time drilling the new holes in the housing straight and true. This caused a lot of re-work which really slowed us down. Getting frustrated with his current press after breaking it, Jason decided it was time to get a new press as well. After Nate ran to Harbor Freight and picked up the new press it definitely made things a whole lot easier in the pressing department.
The numerous attempts at getting the studs to line up straight caused the need to weld, flap wheel, power wash, and dry with the torch quite a few times. We sure were lucky that Jason had all those at our disposal or the long weekend would have been an even longer one.
Pulling out my current axle and putting in the new one was done with the always sketchy double hi-lift method. Followed by laying the ass end down on the springs while I finished painting the new axle and the boys went to go get lunch. Jason had to go to a prior commitment around 2 o'clock on Sunday so me and Nate put in the new axle and bolted it up. We then found that the parking brake cables I had purchased would not work without some major modifications so as of right now I am without a parking brake. Me and Nate then bled the brakes and he had to run as well. I set about filling up the new 3rd with oil and putting on the finishing touches. About an hour after Nate left Jason got back and I told him that on my test drive I heard a terrible scraping and I was pretty upset  :headshake: as I thought it was the differential scraping against the housing (I thought that we hadn't clearanced it enough during our modifications). It turned out that it was the backing plate on the new axle's drum brakes was rubbing against the cover plate of the brakes as the truck drove. That was a huge relief as it was a 10 minute fix rather than the massive undertaking the alternative would have been. I also told Jason that during my test drive I had almost no brakes and that my foot was going to the floor before any braking happened. So me and him set about bleeding the brakes again as well as the proportioning valve. They got a little better but are still only working on the last 1/4 of down travel of the pedal. Jason told me that this is due to the much larger brake cylinders in the much larger drum brakes of my new axle. My poor little 85 brake master cylinder can't keep up causing the pedal issue. So I have an FJ80 1" master that Nate gave me a while back that I will need to put in to solve the issue. I had already planned on doing this upgrade as well as the dual diaphragm brake booster. It has just now been bumped up on the totem pole. So I gingerly drove her home with no problems. I had to give it a little touch up paint this afternoon as we scraped a bit off bolting it up. The end result looks great and I can't wait to put it into action.
Once again huge thanks to Nate and Jason for all their hard work this weekend. You guys are the real deal.
jangelfire
SqWADoosh
twistedtoy92
never fails.... always takes longer than expected... awesome upgrade, i'd like to wheel with guys someday :beerchug:
SqWADoosh
Quote from: twistedtoy92 on June 15, 2015, 05:04:10 PM
Come on up.  :thumbs:
Miller
93 Runner, 86 Runner build, 85 Bobbed, 85 Xcab for parts
twistedtoy92
Id like to do a mini naches run!
blackdiamond
H8PVMNT
I second that.  I did the backing plate elimination when I originally did my SAS and hated it.  It's probably fine it you live in a dry clean climate but it gave me problems for snow wheeling when chunks of concrete like mud/ice freeze on the rotors and when you start moving again, horrible ker-pow!.  Somehow the backing plates keep your rotors way cleaner. We have miles of gravel here and I got the gritty scraping nasty itchies without the backing plates. Backing plates rule.
– Steve McQueen
