My 84 extra cab is gone. Tacoma build now.
Started by Hyena, November 21, 2004, 12:25:12 PM
i had cryoed longs, a dual ultimate, and bald 35's!  it was locked front and rear, and it was snowing.  but that was like 4 yars ago, it has changed a lot since then.
it could be my TG pump.  turned it on again today and it still wined.  but there is still air in the system since i can see little bubbles in fluid.  then it started to smoke from the pump i think, so i shut if off. i am getting sick of this thing.
Ramrod
dont be a girl, finish the other stuff and worry about the little things later.  that free valve might be a bust
dude, there isn't much left to do.  the front axle should be together by monday, if i get the u-joint in the mail by this weekend.  then it is just brake lines, front bumps which i have, and coild overs.  not to mention find out whats wrong with the steering.
slorunner85
dude my trail gear pump sounds like its trying to skin a cat its brand new.trail gear says normal i say crap.they said theyd take it back,anyone ive talked to says they're noisy too.
'85 4ruggy linked ft and rr
42"iroks
pro rock 60 arb
14bolt spooled
5.13
marlins dual ultimate
toy4x4ota
ya i wheel with somebody with the tg pump and it is pretty noisy too
LIFTED TRUCKS ARE GAY
sounds like a regular pump with no fluid in it!
KYOTA
have you tried taking the cylinder off the axle and letting it hang by the hoses fittings up overnight? never know it took me along time to get all the air out of mine.  :twocents:
the ram is the lowest point of the system anyway and the fittings do point up!  i will mess with it more tomarrow.
Ramrod
does it steer?  your motor still runs?
kiyul4130
ditch that thing and throw in a KRC pump brad. it will basically bolt right in. you can get the pump and a 3.17 gpm flow valve for like $190. thats what me, callen and colby all run.
-kiyul-
ECV 7-11
KYOTA FOREVER
im gonna run it till it blows.  it steers fine but that is with the tires off.   now the problem is the damn tryck won't start.  fired it up like 3 times this morning testing the steering.  then went to start it up again and it turns over a little and starts clicking.  wow just wow, what else can go wrong?
it starts now, guess the battery is lasting too long.
Doof
kiyul4130
like 2 years, not that old (this is brad)
-kiyul-
ECV 7-11
KYOTA FOREVER
locktup
Its getting there Brad. Are you shooting to have it done for the Hammers?
I wont be at the Hammers this year  :sad2:
Jason
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
www.LOCKTUPFABRICATION.com
ya it should be done by the hammer for sure.  hopefully have it on a run before that to test it out.  it just needs coil overs now.  got the brakes in the mail and need to build the bump stops but that is easy stuff.
boggerunner
Doof
Ramrod
you gonna cap off the outside also? weld the nut to the inside first
nah, i'll probably leave it open.
LilChief87
95SAS
1986 extracab, SAS 38.5's Locked Duals, truggyfied, beadlocks
1988 2wd bagged and body dropped 3'' with a healthy 22r....
my build
http://board.marlincrawler.com/index.php?topic=35602.0
the bumpstops need a little adjustment so they aren't done yet.  and the steering is way messed up.  i am pretty sure the pump almost burned to the ground it got so hot in only a minute of running.  it is at full bump in the front and about ride height in the rear.
lilbuddy
Quote from: Hyena on November 30, 2008, 02:18:12 PM
Looks sick tight bro...
RIP Kyota.... you are the man
GET IT!!!
KYOTA
nice work b rad. you using the brake at work? brackets turned out sweet as candy
TheCookieMonster
nice...its good to see that beast out of the garage  :beerchug:
Quote from: KYOTA on November 30, 2008, 03:40:06 PM
Thanks!  Ya the brake at work isn't as precise as what ballistic has but it gets the job done!
