My 84 extra cab is gone. Tacoma build now.
Started by Hyena, November 21, 2004, 12:25:12 PM
finally got the rear winch wired to the incab switch.  that only took 4 months lol.
kiyul4130
-kiyul-
ECV 7-11
KYOTA FOREVER
gotrocks
Jack8542
Lookin good, when u gonna start on mine?  :flamer:         :usa:
RIP SSg Sizemore, Sgt Mock, Spc McGuness, Pfc Hill, Pfc Marsh, Pfc   Garcia, Pfc Hardge, Ssg Campos. You will be missed greatly by all of C-Rock.
#2494
Quote from: Jack8542 on August 30, 2008, 07:01:01 PM
find a front 60 for cheap over there and send it to me.  i can throw that under your truck no problem!  hahaha
Doof
brad you might as well start your own fab shop... you have bumpers down, and now your going into 60 swaps... nice little side job for when welding gets slow
kiyul4130
he doesnt know what hes doing. :)
-kiyul-
ECV 7-11
KYOTA FOREVER
Doof
experience...forgot about that lil guy
well i got the new seals for the shifters. shouldn't have any water (oil) falls out of my t-cases anymore.  te only sucky thing is i am not going to pull my t-case just to install the twin stick so it will look like a twin stick, but not be functional like one.
why not functional? you stil single case?
kiyul4130
no, hes dualed up. pull that beezy. that or im sure you will when its time for the truck to get a move on.
-kiyul-
ECV 7-11
KYOTA FOREVER
i would have to pull them out to take the pin out between the two shifting rods.  it it hell to take these cases out so i am not going to do it.
gotrocks
you have a PM I need to know if you want the hubs so they can get down there for the roundup if you want free shipping
Doof
is it a pain to pull the cases since you did the old school flat belly by lifting the drive train?
ya!  i have to pull both my seats out and do a little cutting on the mount.
kiyul4130
-kiyul-
ECV 7-11
KYOTA FOREVER
got an idea how to reinforce the steering arms even more by adding a 5/8's bolt to each one.  should be pretty indestructable after that!
kiyul4130
drilling and tapping everything? you gunna have much material left?
-kiyul-
ECV 7-11
KYOTA FOREVER
nah, tying it into the stock tierod location!  bling bling
Jud
"bout tree fiddy"
ordering the caliper brackets tomarrow from screamin seeman offroad.
#2511
here is a list of the stuff that needs to be finshed.
buy caliper brackets
buy wheel hubs, bearings and studs
buy drive flanges
buy axle shafts and joints
buy shocks, coil overs for the front for sure, might end up running 2.5 air shocks in the back
finish hydrolic steering lines
finish brake lines
build front shock mounts
buy cromo output shaft and reseal t-case
mount plastic skidplate
reinforce steering arms
build front bumpstops
Shamb
have you ran coilovers/airshock combo before?  or know anyone who has?
It's probably a cheaper alternative for now but from what i've been told the rear get's way over worked because of the coils in the front.
Just something to think about..
no but i know i want coil overs in the front.  i think the 2.5 air shocks should be able to handle the load in the back.
Shamb
what I mean by it is that say for example your front driverside tire is on a rock, the weight of the truck will start to distribute to the rear passenger which is going to collapse alot easier then the driverside front because instead of just an airshock.. you'll have a coil wrapped around that airshock.
if the air shock is pressurized right then it should collapse at the same time (or with the same force) as the coil over.
Shamb
yea but it's going to take more pressure to push down a pressurized airshock with a coil wrapped around it as appose to just a pressurized airshock by itself.
Edit: I had to re-read your post again, i'm a tard late at night.. yea as long as it's adjusted accordingly then i'm sure it'll be fine.
Edit Again:  But we all know how much "fun" adjust airshocks can be!   :thumbdown:   :hahaha:
Quote from: Shamb on September 28, 2008, 10:19:05 PM
yep
Ramrod
like I said before, put some coils in it and run it
